    thermistor bad reading
    753
    • ninniundefined
      ninni
      good evening everyone. I open this topic because I realized that the sensors of the bed and the hotend show temperatures that are not quite correct already at room temperature. the thermistors are of the type NTC 100k 3950. have you already faced this problem? thanks in advance
      Vetiundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @ninni
        @ninni
        ntc 3950 are really bad
        the beta value of 3950 refers to the temperature range from 25-50 degrees.
        Beyond that it changes from thermistor to thermistor. you can easily have temperature differences of 20C
        if you want accurate readings i recommend semitec-104nt or pt1000
          droftarts administrators @ninni
          @ninni Duet type? Firmware version? config.g, or at least thermistor configuration? How much temperature difference are you actually seeing? Please supply at least some useful information so that we can help you! See https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
          For general thermistor information, see https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors
          If you suspect the Duet or firmware, try putting a 100k ohm resistor on the Duet temperature pins, and see what temperature it reports.
          ninniundefined 2 Replies Last reply Reply Quote 1
          • ninniundefined
            ninni
            This post is deleted!
            • ninniundefined
              ninni
              @Veti may you link me the website where i can buy it?
              • ninniundefined
                ninni
                  Phaedrux Moderator @ninni
                  @ninni said in thermistor bad reading:
                  https://e3d-online.com/products/thermistor-cartridge
                  ninniundefined 1 Reply Last reply Reply Quote 0
                  • ninniundefined
                    ninni @Phaedrux
                    @Phaedrux sorry i dont understand
                    veti said me that semitec-104nt o pt1000 is very ood sensor
                    • ninniundefined
                      ninni @droftarts
                      • ninniundefined
                        ninni @droftarts
                        @droftarts ; Drives
                        M569 P0 S0 ; physical drive 0 goes forwards
                        M569 P1 S0 ; physical drive 1 goes forwards
                        M569 P2 S0 ; physical drive 2 goes forwards
                        M92 X200.00 Y200.00 Z800.00 E873.08 ; set steps per mm
                        M566 X600.00 Y600.00 Z18.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X9000.00 Y9000.00 Z240.00 E1200.00 ; set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                        M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X230 Y210 Z210 S0 ; set axis maxima
                        M574 X1 S1 P"xstop" ; configure active-low endstop for high end on X via pin xstop
                        M574 Y1 S1 P"ystop" ; configure active-low endstop for high end on Y via pin ystop
                        M574 Z2 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
                        M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                        M557 X0:22 Y0:22 S20 ; define mesh grid
                        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                        M143 H0 S250 ; set temperature limit for heater 0 to 120C
                        M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                        M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                        M106 P1 S1 H1 T1 ; set fan 1 value. Thermostatic control is turned on
                        M563 P1 D0 H1 F0 ; define tool 1
                        G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
                        G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                        T1 ; select first tool
                          I linked you to the E3D Semitec-104GT thermistor cartridge which is what I think Veti was referring to. I don't think you'll find a better or easier to obtain thermistor with known values and appropriate form factor.
                          • ninniundefined
                            ninni @Phaedrux
                            @Phaedrux ok tu so Much
                              Does your hotend heat block take a cartridge thermistor or a glass bead?
                              • ninniundefined
                                ninni @Phaedrux
                                @Phaedrux block thermistor
                                  Does it look like the little metal tube in the E3D link above, or does it look like a little glass bead?
                                  • ninniundefined
                                    ninni @Phaedrux
                                    @Phaedrux small metal tube
                                      Then that E3D thermistor is the one you want.
                                      • Vetiundefined
                                        Veti
                                        https://de.aliexpress.com/item/32859917151.html
                                        this is the alternative pt1000
                                        • ninniundefined
                                          ninni @Veti
                                          @Veti ok we Will see
                                          • ninniundefined
                                            ninni
                                            also I would like to report a bug. when the endstop is positioned upwards for the z axis the platter stops when it touches the endstop but if you give the command again it continues to rise ignoring that the limit switch was already pressed
                                            ; homeall.g
                                            ; called to home all axes
                                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 13:33:30 GMT+0200 (Ora legale dell’Europa centrale)
                                            G91 ; relative positioning
                                            G1 H1 X-235 Y-215 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                            G1 H1 X-235 ; home X axis
                                            G1 H1 Y-215 ; home Y axis
                                            G1 X5 Y5 F6000 ; go back a few mm
                                            G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
                                            G1 H1 Y-215 ; then move slowly to Y axis endstop
                                            G1 H1 Z205 F360 ; move Z up stopping at the endstop
                                            G90 ; absolute positioning
                                            G92 Z0 ; set Z position to axis maximum (you may want to adjust this)
                                            ;G91 ; relative positioning
                                            ;G1 Z5 F100 ; lift Z relative to current position
                                            ;G90 ; absolute positioning
                                            ; homez.g
                                            ; called to home the Z axis
                                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 26 2020 13:34:47 GMT+0200 (Ora legale dell’Europa centrale)
                                            G1 H1 Z205 F1800 ; move Z up until the endstop is triggered
                                            config.g
                                            M208 X0 Y0 Z-200 S1 ; set axis minima
                                            M208 X230 Y210 Z0 S0 ; set axis maxima
                                            M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                                            droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
