    BL Touch
    126
    6.9k
    • Gost101undefined
      Gost101
      @droftarts Tunning for the bed failed again.
      • Gost101undefined
        Gost101
        @droftarts Is there a way to increase the time before the heater faults for rising to slowly?
        • Gost101undefined
          Gost101
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 07:45:49 GMT-0600 (Mountain Daylight Time)
          M550 P"A.C.E."                                     ; set printer name
          M918 P1 E4 F2000000                                ; configure direct-connect display
          M551 P"SpaceForceHu2020!!"                         ; set password
          M569 P0 S1                                         ; X physical drive 0 goes backwards
          M569 P1 S1                                         ; Y physical drive 1 goes backwards
          M569 P2 S0                                         ; Z One physical drive 2 goes forwards
          M569 P3 S0                                         ; E physical drive 3 goes backwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E415.00                  ; set steps per mm
          M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
          M208 X500 Y500 Z500 S0                             ; set axis maxima
          ;Filiment Out Sensor
          M591 D0 P1 C"e0stop" S1                            ; filiment out sensor
          M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
          M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F600 T9000                ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X37 Y0 Z2.150                               ; set Z probe trigger value, offset and trigger height
          M557 X30:470 Y30:470 S25                           ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 A340.0 C140.0 D600 S1.00 V0.0 B1           ; enable bang-bang mode for the bed heater and set PWM limit
          M143 H0 S72                                        ; set temperature limit for heater 0 to 72C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin e0temp
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
          M563 P0 S"Hot end" H1 D0 F1:2                      ; define tool 1
          G10 P0 X0 Y0 Z0                                    ; set tool 1 axis offsets
          G10 P0 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
          • fcwiltundefined
            fcwilt @Gost101
            @Gost101 said in BL Touch:
            From the docs:
            If auto tuning fails with a message that the temperature is not rising fast enough, this indicates that either you are using too low a P value in the M303 command, or the dead time in the existing model is much too low for your heater. You can increase the dead time using the M307 command. For example, sending M307 H0 D30 will increase the dead time to 30 seconds. The actual dead time will be known after a successful auto tuning.
            • Gost101undefined
              Gost101
              @peter247 @droftarts @fcwilt @Phaedrux @jay_s_uk @dc42 @Veti Everything works now. Here is the files for them: !!Update I'm unable to upload anything to this form for some reason so the code will be here instead!!
              Config:
              M906 X800 Y1200 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
              M307 H0 A340.0 C140.0 D600 S1.00 B1           ; enable bang-bang mode for the bed heater and set PWM limit
              bed:
              ![0_1601478305928_be382bf7-6196-4141-a7b8-e83585cb6c91-image.png](Uploading 100%) code_text
              home all:
              ; homeall.g
              ; called to home all axes
              G91                      ; relative positioning
              G1 H2 Z5 F9000           ; lift Z relative to current position
              G1 H1 X-505 Y-505 F21600 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F9000        ; go back a few mm
              G1 H1 X-505 Y-505 F7200  ; move slowly to X and Y axis endstops once more (second pass)
              G90                      ; absolute positioning
              G1 X250 Y250 F9000       ; go to first bed probe point and home Z
              G30                      ; home Z by probing the bed
              G1 Z10                   ; raise Z 10mm
              ;G91                     ; relative positioning
              ;G1 Z5 F150              ; lift Z relative to current position
              ;G90                     ; absolute positioning
              home z:
              ; homez.g
              ; called to home the Z axis
              G1 X15 Y15 F9000 ; go to first probe point
              home x:
              ; homex.g
              ; called to home the X axis
              G1 H1 X-505 F21600 ; move quickly to X axis endstop and stop there (first pass)
              G1 H2 X5 F9000     ; go back a few mm
              G1 H1 X-505 F7200  ; move slowly to X axis endstop once more (second pass)
              G1 H2 Z-5 F9000    ; lower Z again
              home y:
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-505 F21600 ; move quickly to Y axis endstop and stop there (first pass)
              G1 H2 Y5 F9000     ; go back a few mm
              G1 H1 Y-505 F7200  ; move slowly to Y axis endstop once more (second pass)
              Time to break it more lol. I'm now trying to use both z axis independent of each other to calibrate them with a BL Tocuh.
              I have read this: Bed levelling using multiple independent Z motors and the following code is what I have created for it. However the printer will home all as it would before. How do I level each axis via the BL Touch not only as part of Home All & Home Z but also as just a macro to level it.
              config:
              M569 P4 S0                                         ; Z Two physical drive 2 goes forwards
              M584 X0 Y1 Z2:4 E3                                 ; set drive mapping
              M671 X-23:523. Y0:0 S0.5;
              M208 X30:470 Y0:250                                ; X carriage moves from 30 to 470, Y bed goes from 0 to 250
              bed:
              ; bed.g
              G29  ; probe the bed and enable compensation
              G30 P0 X30 Y250 Z-505 ; probe near a leadscrew, half way along Y axis
              G30 P1 X470 Y250 Z-505 S2 ; probe near a leadscrew and calibrate 2 motors
              I've read older topic on this. The z axis lead screws are located at about -23 and 530. However if a leveling is performed it would be best to do it at 30 and 470 while the bed is centered at 250.
              • fcwiltundefined
                fcwilt
                Going from the docs I think you want to remove the G29 and add a G28.
                On my printer, instead of using homing, I just set the Z=0 datum using G1 to move to the center of the bed and G30 to probe.
                • Gost101undefined
                  Gost101
                  @fcwilt tried what you said didn't do what it was supposed to do. I think there is a lot more code that is involved in this.
                  fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt @Gost101
                    Here is my bed.g:
                    M98 P"probez.g"       ; set Z=0 datum (see below)
                    ; specify where bed leveling adjustment screws are located
                    M671 X-160:-160:160  Y-160:160:0 ; positions for adjusting screws 1,2,3
                    ; probe near each adjusting screw and compute results
                    G30 P2 X-140 Y-140 Z-99999   ; probe near an adjusting screw #1
                    G30 P0 X-140 Y140  Z-99999   ; probe near an adjusting screw #2
                    G30 P1 X140  Y0    Z-99999 S3; probe near an adjusting screw #3 and compute results
                    Here is my probez.g:
                    M950 S0 C"duex.pwm5"                                ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H2 F120 T12000 R0.2 A5 S0.01  ; set type for BLtouch and set parameters
                    G31 P25 X0 Y24.5 Z2.500                             ; set trigger value, offset and trigger height (larger = closer)
                    G29 S2                  ; cancel mesh bed compensation
                    M290 R0 S0              ; cancel baby stepping
                    G1 X0 Y-24.5            ; position for probing
                    G30                     ; do single probe - sets Z to probe trigger height
                      Phaedrux Moderator @Gost101
                      You're also going to need an M671 in your config.g to define the location of the lead screws. Review the independent z axis leveling doc again.
                        droftarts administrators @Phaedrux
                        @Phaedrux said in BL Touch:
                        He's got one, config.g line 27:
                        @Gost101 Though delete the trailing '.' after '523'. And this is odd, line 36 config.g
                        M208 X30:470 Y0:250
                        It has two M208 commands following it, which will supersede it, so delete it. Though I thought that X homes off the bed? Or did you move the microswitch so it doesn't?
                        Re bed.g, the G29 should probably be G29 S2 to clear the bed mesh, rather than create a bed mesh. You want home (G28) first, then do the bed levelling (the G30 commands), then create (G29) or apply a saved (G29 S1) bed mesh. So try:
                        ; bed.g
                        G29 S2  ; disable mesh compensation
                        G28 ; home all
                        G29 ; or G29 S1 - create or load bed compensation mesh
                        fcwiltundefined 1 Reply Last reply Reply Quote 1
                        • fcwiltundefined
                          fcwilt @droftarts
                          @droftarts said in BL Touch:
                          M208 X30:470 Y0:250
                          That is an alternate form for M208.
                          The number before the : is the min, after the : is the max.
                          His line is missing the Z values but if they were added it would be perfectly valid - it is the form I use.
                            Phaedrux Moderator @fcwilt
                            @fcwilt Yes it's a valid form, but it's being over written with additional commands so isn't taking effect.
                            • fcwiltundefined
                              fcwilt @Phaedrux
                              Yes, I see that. But I just wanted to make sure that @Gost101 understood about the two forms.
                              • Gost101undefined
                                Gost101
                                So then how do I do the independent leveling? Here is my config:
                                M671 X-23:523 Y0:0 S0.5;
                                ;M208 X30:470 Y0:250                               ; X carriage moves from 30 to 470, Y bed goes from 0 to 250
                                M208 X0:500 Y0:500 Z0:500                          ; set axis minima
                                ;M208 X500 Y500 Z500 S0                            ; set axis maxima
                                bed:
                                ; bed.g
                                M561                      ; clear any bed transform
                                G29 S2                    ;probe the bed and enable compensation
                                G28                       ; home all
                                home all:
                                ; homeall.g
                                home z:
                                ; homez.g
                                droftartsundefined 2 Replies Last reply Reply Quote 0
                                • Gost101undefined
                                  Gost101
                                  There is a x limit switch at 0, a y limit switch at 0, and the z porbe as the 0.
                                    droftarts administrators @Gost101
                                    First, understand the difference between 'bed (plane) levelling' and 'Bed mesh compensation'. Levelling the bed plane to the nozzle is trying to get the bed square to the XY axis, and has to be done mechanically; using the independent levelling takes some of the hassle out of this, by doing it automatically. However, mesh bed compensation is NOT levelling; it's to account for anomalies in the bed, though it can be used to show that the bed (or X axis) is not level.
                                    As you have a 'bed slinger', with bed moving in Y, and X mounted on Z (rather than any other layout eg CoreXY or Cartesian with bed moving in Z, eg Ultimaker), you actually need to do five things to get everything square:
                                    1. Build the machine square, so that XY, XZ and YZ linear rails are perpendicular with each other (three degrees of freedom - axis skew), and any dual linear rails (X, Y and Z) are parallel (three more degrees of freedom - rotation around axis). This, in itself, is so important and often overlooked. There are some good videos online.
                                    2. Level the X gantry to the frame: you need to do this at least once, so you can reference the bed from the frame.
                                    3. Mechanically level the bed to the nozzle: I expect your bed has levelling screws at the corners, so you have to do this manually. There is a method to do this with the Z probe, or you can do this manually by moving the nozzle to various points on the bed and adjusting the bed adjusters, like everybody did in the 'old' days.
                                    4. Create a bed mesh to account for anomalies in the bed.
                                    5. If printed parts are still not orthogonal (square), see M556, though you've probably not done step 1 right.
                                    You can swap 2 and 3 around, and level the bed to the frame, then level the X axis to the bed, though it's generally more accurate to level the X gantry to the frame.
                                    Steps 1, 2 and 3 should be your initial commissioning, and once done, shouldn't need redoing too often if you don't move the printer. Be aware you really want the printer on something flat, so it doesn't twist the frame. Steps 4 should only need redoing if you're using a different temperature, or you want to check the bed is still level. Step 5 would be if you moved the printer, and didn't want to go back to step 1 again!
                                    Then, each time you turn the printer on:
                                    1. With the bed square to the frame, you can use the independent levelling of the X gantry each time you turn on the printer, to make sure it stays level with the bed.
                                    2. Load the saved bed mesh.
                                    Well, that's the process I use anyway, though rarely even bother with the bed mesh as I have a small bed with 4mm glass on it.
                                    • Gost101undefined
                                      Gost101
                                      @droftarts I appreciate the in depth Exploration. All the axis are level and square. I'm simply trying to keep the x gantry level on the z axis in relation to the bed to make sure it is perfectly level to the bed. What more gcode would I have to incorporate into my config/home all/home z to make this apart of the homing process?
                                        @Gost101 is it that it’s not working? Any error message? My guess is that:
                                        Because of your probe X offfset...
                                        And your bed limits...
                                        X30 is not reachable by the probe. Try X40.
                                        • Gost101undefined
                                          Gost101
                                          @droftarts It's homing as normal. It goes to the x&y endstops then to the center of the bed to probe for z. It is not probing near X30 Y250, X470 Y250. It's only probing the center of the bed. No errors are given. I've tried replacing X30 with X40 as you instructed and no fuzzy dice.
                                            @Gost101 what are you running? Homeall.g? You need to run bed.g, with either G32 or M98 P”bed.g”
