    BL Touch
    126
    6.9k
    • peter247undefined
      peter247 @peter247
      @peter247
      Self test is when you first switch on the machine / give it power , the pin will deploy than retract and go solid red.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      Gost101undefined 1 Reply Last reply Reply Quote 0
      • Gost101undefined
        Gost101 @peter247
        @peter247 It hasn't done that yet so far even after multiple reboots.
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @Gost101
          @Gost101
          if it doesn't do that it is a bltouch fault and not a configuration fault.
          pull the pin and see if it is bent
          • Gost101undefined
            Gost101
            I legit unplugged the bl touch wires and plugged them back in. It did the move thing and actually homed z. lol
            • peter247undefined
              peter247 @Gost101
              @Gost101
              if you get the red flash the deploy and retract doesn't work until you reset it.
              reset it by power recycle OR S160 , eg M280 P3 S160
              • Gost101undefined
                Gost101
                Granted it didnt stop and kept going but progress
                • Gost101undefined
                  Gost101 @Gost101
                  The Z axis wont stop moving down even after the plunger is pushed in.
                  • peter247undefined
                    peter247 @Gost101
                    @Gost101
                    can you deploy and retract the probe ?
                    • Gost101undefined
                      Gost101 @peter247
                      @peter247 I can deploy and retract the probe
                      • Vetiundefined
                        Veti
                        the wires that come with the bltouch are notoriously bad.
                        • Gost101undefined
                          Gost101
                          @Veti Also not long enough to reach my board. lol
                          • peter247undefined
                            peter247 @Gost101
                            @Gost101
                            Look like you are using G30 to lower the head on homing .
                            Can't see a fault on your config.g , but i'm on version 3.1.1 which is different.
                            • Gost101undefined
                              Gost101
                              @peter247 Now the printer wont home Z. lol here is the code for home all. I cannot pin up and down:
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:27 GMT-0600 (Mountain Daylight Time)
                              ; Y-Axis
                              G91                ; relative positioning
                              G1 S1 Y-505 F1800  ; move quickly to Y axis endstop and stop there (first pass)
                              G1 Y5 F500         ; go back a few mm
                              G1 S1 Y-505 F360   ; move slowly to Y axis endstop once more (second pass)
                              G90                ; absolute positioning
                              ; X-Axis
                              G1 S1 X-505 F1800  ; move quickly to X axis endstop and stop there (first pass)
                              G1 X5 F500         ; go back a few mm
                              G1 S1 X-505 F360   ; move slowly to X axis endstop once more (second pass)
                              ; Z-Axis
                              M280 P7 S160
                              M280 P7 S120
                              M280 P7 S90 I1         ; Probe Up
                              M280 P7 S10 I1         ; Probe Down
                              G1 X15 Y15 Z10 F500
                              G30 		       ; Do a single probe to home our Z axis
                              G90 		       ; Make sure we are in absolute mode
                              G1 Z10 F6000           ; Rapidly move the Z axis to Z=10.
                              • Gost101undefined
                                Gost101
                                @peter247 said in BL Touch:
                                M280 P3 S160
                                The only way to clear the blinking red light is to manually unplug the red wire: alt text
                                • Gost101undefined
                                  Gost101
                                  This isn't a actually picture of my board just one I found online.
                                  • Gost101undefined
                                    Gost101
                                    @peter247 I tired the M280 P7 S160 through both the gcode console and in home all and it dindn't work
                                    • peter247undefined
                                      peter247 @Gost101
                                      @Gost101
                                      Does the up down up down up down work ?
                                      • Gost101undefined
                                        Gost101
                                        Nope. lol. I manually reset the bl touch but am curious if there is a reset g code for this problem.
                                        • peter247undefined
                                          peter247 @Gost101
                                          @Gost101
                                          this my reset code for the bltouch M280 P0 S160
                                          • peter247undefined
                                            peter247 @peter247
                                            @Gost101
                                            does this work ?
