duet firmware m997 s0
  • m997 s0
    Shutting down USB interface to update main firmware. Try reconnecting after 30 seconds.
    What's wrong?
    @MRJEON how do you mean? That looks like the correct response to sending the upgrade command.
  • After disconnecting the power for 30 seconds and reconnecting, I tried typing m997 s0, but the answer is the same.
    I tried sending the m122 command to see if the firmware was installed properly. It looks good, but I can't connect even if I try to access the wifi web control.
    m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    Board ID: 08DLM-996RU-N85S4-7JTD8-3S46R-9VBVP
    Used output buffers: 1 of 24 (3 max)
    Static ram: 27980
    Dynamic ram: 93236 of which 20 recycled
    Exception stack ram used: 256
    Never used ram: 9580
    Tasks: NETWORK(ready,904) HEAT(blocked,1476) MAIN(running,1656) IDLE(ready,80)
    Owned mutexes:
    Last reset 00:00:15 ago, cause: software
    Last software reset time unknown, reason: Watchdog timeout, spinning module GCodes, available RAM 11680 bytes (slot 2)
    Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x200049d4 Task MAIN
    Stack: 004486cf 0042a316 21000000 3f800000 00000000 00000000 00000000 3331bb4c 40000000 3f317200 b5ddea0e
    Error status: 0
    MCU temperature: min 30.5, current 30.8, max 31.2
    Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Cache data hit count 28622633
    Slowest loop: 99.20ms; fastest: 0.08ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 3.1ms, write time 2.1ms, max retries 0
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is ready with "m122" in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 1.36ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is active
      WiFi module is idle
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:5b:45:b7
      WiFi Vcc 3.36, reset reason Unknown
      WiFi flash size 4194304, free heap 30176
      ok
    @MRJEON please post your config.g and also check that the 3.1.1 release of DWC in in the www. Directory
  • ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 24 2020 16:38:18 GMT+0900 (대한민국 표준시)
    M550 P"My Printer" ; set printer name
    M551 P"CLANE" ; set password
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S1 ; enable FTP
    M586 P2 S1 ; enable Telnet
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X230 Y210 Z200 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M140 H-1 ; disable heated bed (overrides default heater mapping)
    T0 ; select first tool
  • Can't web control be connected if only micro USB is connected?
  • Moderator
    Yes the web interface should work fine when only powered by USB.
    What error message do you get in the browser when you try to connect to the IP address?
    Do you have the DWC files in the /www folder of the sd card?
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
  • @Phaedrux Yes I downloaded it and put it in the www folder. Should I unpack the zip file in the www folder?
  • Moderator
    Yes it needs to be extracted into /www
  • @Phaedrux
    m122 wifi section...
    • WiFi -
      WiFi module is idle
      ok
    and
    m587 command..
    m587
    Remembered networks:
    TNCAPF318D9 IP=192.168.1.24 GW=0.0.0.0 NM=0.0.0.0
    clane IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    clane printer IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    ok
    If you enter 192.168.1.24 in the address bar, doesn't the web control window appear?
    @MRJEON said in duet firmware m997 s0:
    WiFi module is idle
    That's why you can't connect. What happens if you send M552 S1 from USB? You should get a response within 30 seconds.
  • @dc42
    m552 s1
    ok
    WiFi reported error: no known networks found
    WiFi module is idle
    So it can't find your router. Try deleting the stored networks using M588 S"*", then use M587 to enter the router SSID and password again. Note, the SSID and password are case sensitive.
  • @dc42 said in duet firmware m997 s0:
    m588 s"*"
    ok
    m587 s"test" p"dkdlarkt1@"
    ok
    m587 s"test" p"wifi1234"
    ok
    m587
    test IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    ok
    m552 s1
    ok
    WiFi module is idle
  • @MRJEON so sad... what's wrong..
    Do you actually have a router whose SSID is "test" ?
  • @dc42 sorry I couldn't input the correct ssid and pw. Does duet 2 wifi support 5G?
    You need to enter the correct SSID and password for your WiFi router.
    this password...??what...???
  • @MRJEON said in duet firmware m997 s0:
    I guess it's CLANE???
  • @jay_s_uk ok thanks!!
