    IDEX and meshbed. Possible?
    127
    • MaracMB
      MaracMB last edited by MaracMB
      Is it possible, or better said, would it be possible at all to have a meshbed levelling with IDEX machine ran by duet RRF? And if, would Duet2 do the job or would one want/need duet3?
      sebkritikel 1 Reply Last reply Reply Quote 0
        Yes you can use mesh compensation with IDEX and Duet2.
        MaracMB 1 Reply Last reply Reply Quote 0
        • sebkritikel
          sebkritikel @MaracMB last edited by
          @MaracMB said in IDEX and meshbed. Possible?:
          I run an IDEX machine on a Duet2Wifi and Duex5, using mesh compensation. I do use "Bed levelling using multiple independent Z motors" as I have only one Z motor.
          Happy to answer any questions that I can.
          • MaracMB
            MaracMB @Phaedrux last edited by
            @Phaedrux in ditto mode.. i have to add that...
            • sebkritikel
              I cannot guarantee this is correct without doing some searching (cannot recall where I read it!) but in mirror/ditto print I believe the mesh compensation applies only down the length of the shared axis... this needs to be checked up on though.
              • MaracMB
                MaracMB @sebkritikel last edited by
                @sebkritikel
                I have a dual Z axis IDEX. Well, technically it is already a IDDX (dual dual x gantry...on both sides of carthesian)
                But none the less i’d like to know if it’s possible to intepolate the meshbed along the X axis in ditto mode
                sebkritikel Phaedrux 2 Replies Last reply Reply Quote 0
                • sebkritikel
                  @sebkritikel
                  Sounds like a super cool setup, but unfortunately I don't think I can satisfactory answer your query - sorry about that!
                    Phaedrux Moderator @MaracMB last edited by
                    @sebkritikel
                    Photos?
                    MaracMB 2 Replies Last reply Reply Quote 1
                    • MaracMB
                      This post is deleted!
                      • MaracMB
                        @dc42 in this post, you mention that there is a possibility to have dual height map for independant Zs...
                        https://forum.duet3d.com/topic/1363/idex-x-and-u-on-separate-z-leveling-bed-mesh/2?_=1602050345600
                        I am interested in just that for ditto printing.
                        As discussion never sparked there about that, could you elaborate that further?
                        I now have dual dual IDEX, but having an option to make dual Z for the rest of community gathered, i may try to implement that. Or just to have a dual prints meshbedlevelled ability...
                        Thank you
                        • MaracMB
                          @Phaedrux as promissed, the pictures of a build in progress
                          https://ibb.co/9qDPTWn
                          https://ibb.co/CsGbTPb
                          https://ibb.co/6b5DQxL
                          It got pretty compact.
                          Needs a lot of work still to get the flat round cabling routed to both sides of X gantries from the bottom, then flat cables from there to each head, make breakout boards on toolheads for ribbon cables etc.
                          But all in all. There is progress
