    Resonance Compensation
    Firmware developers
    853
    • dgrat
      dgrat last edited by dgrat
      See: https://www.klipper3d.org/Resonance_Compensation.html
      Looks like for Delta printers it would be even simpler, because all towers are equal.
      Paper: https://www.researchgate.net/publication/224606974_Input_shaping_for_nonlinear_systems
      • sebkritikel
        sebkritikel last edited by sebkritikel
        Discussed some here:
        https://forum.duet3d.com/topic/18529/input-shapers-klipper/9?_=1602859383989
        But I would LOVE to see this implemented in RRF. DAA is useful, but this appears to be much, much more powerful.
        • T3P3Tony
          I looked into the klipper implementation of this earlier in the week (as it was mentioned at VERRF) and as far as I can see they are all a centred on single frequency and are just a band of frequencies of different ranges that are filtered. I presume the downside of this is that this start to limit the allowable accelerations, as the band increases.
          @dc42 would need to confirm but AFAIK DAA is a single frequency, not a narrow band (its certainly not a wide band).
          Overall though this is really useful research. It fits loosely to experimental work we are doing to improve printing so I will certainly delve further!
          Duet Hardware Designer
          www.duet3d.com
          GeneRisi 1 Reply Last reply Reply Quote 0
          • Robthide37
            Robthide37 last edited by
            Klipper doesn't adjust accel and it has ability for 2 frequencies currently plus you can do the sam ething as daa and use a multiple if you have alot of frequencies. The best thing about input shaping is it actually alters toolpath so their is no loss of speed
            arhi 1 Reply Last reply Reply Quote 0
            • arhi
              arhi @Robthide37 last edited by
              @Robthide37 alters toolpath? in what way? I'm not sure I'd like toolpath to be changed?
                Phaedrux Moderator @arhi last edited by
                @arhi said in Resonance Compensation:
                What if altering the tool path slightly ends up with a physical result closer to the actual desired tool path?
                • arhi
                  arhi @Phaedrux last edited by
                  @Phaedrux dunno, have hard time believing that will be a universal solution
                  Robthide37 1 Reply Last reply Reply Quote 0
                  • Robthide37
                    Robthide37 @arhi last edited by
                    @arhi it is not universal you need to tune it or you can even use an accelerometer to provide the feedback you need to set the frequency and dampening level
                    • GeneRisi
                      GeneRisi @T3P3Tony last edited by
                      @T3P3Tony , I use klipper on my modified BigBox printer. Compensation can be done for both X and Y axis' . The result on my printer, with two lightweight carriages in an IDEX configuration, is pretty amazing (I can watch ringing ripples disappear when using their test pattern). Also, there are multiple algorithms that are available now for the resonance compensation, so I think Dmitri's work will be a great resource for development!
