Yet more conditional gcode help required
Here is the scenario. On my CoreXYUVAB, the XY gantry and UV gantry are coupled together with wires and bowden tubes which means that each one only has about 15mm of allowable movement in respect to the other, before nasty things happen. So I have to take great care using the jog buttons on DWC and in fact, they are pretty useless in my particular usage case.
So, I've bought a simple joystick which has 4 microswitches. Let's call them NSE and W. I plan to connect each switch to an io pin and the usen trigger macros. So for example, "E" = left and is connected to io4.in and will run trigger 4 which will jog all 3 gantries by doing G1 X-n U-n A-n.
I'd like to use a loop so that the gantries will continue to jog while the joystick is being held in that position. Something like
echo "Joystick left while sensors.gpIn[4].value=0 G1 X-1 U-1 A-1 F6000; move M400; wait for move to finish
So question 1 - Will that work? That is to say, is it OK to poll the same pin that initially triggered the macro?
Part 2. This joystick can also trigger two switches concurrently. So as well as NSE and W, I could also do 45 degree moves. i.e. If "E" is trigger 4, that macro could also poll the "N" and "S" switches and if either of those is also closed, then do G1 Xn Yn Un Vn An Bn (either + or - depending on which switch was closed). So the loop would get extended to include an
if sensors.gpIn[6].value=0, then move YV and B as well else only move XU and A ( or some such).
Obviously all 4 trigger macros would need to check the state of two other switches as well as the one which caused the trigger. i.e. "E" would also need to check the state of "N and "S" . The problem with that is, if I do a (say) NE move on the joystick, this will cause two trigger events - one for each switch. But the firmware states "Polling for further trigger conditions is suspended until the trigger macro file has been completed", so I guess as long as each macro checks all the switch combinations, then it ought to work. i.e. if E also checks N and S, and N also checks E and W then if the joystick is moved to the NE position, it won't matter which trigger occurs first as the outcome will be the same (either macro will do a 45 degree move).
Does that make sense? Will it work?
Maybe something to do in daemon.g file? This way, you don't need to use trigger events, and you can poll all you want...
I think the best option may be to use a single trigger macro that responds to all 4 switches, that reads all 4 switches directly from the object model and makes appropriate movements, until none of the 4 switches is triggered.
@fma said in Yet more conditional gcode help required:
That's something I hadn't considered. But I'd need to restrict any movement to only happen when NOT printing. This will be possible using the R2 parameter in M581. Can the same thing be achieved with daemon.g?
@dc42 said in Yet more conditional gcode help required:
Ahh. That sounds a better option. I wasn't aware that a trigger could be initiated with any one of multiple pins. Can you point me to the command I'd need to use.
See https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later. The P parameter accepts multiple GpIn pin numbers.
OK, I think I've sussed it but would appreciate a sanity check.
Config.g now has this......
M950 J5 C"^0.io5.in" ; main board(0) io5, joystick left M950 J6 C"^0.io6.in" ; main board(0) io6, joystick right M950 J7 C"^0.io7.in" ; main board(0) io7, joystick forward M950 J8 C"^0.io8.in" ; main board(0) io8, joystick backwards M581 P5:6:7:8 T5 R0 S0 ;Run trigger5 macro - (joystick left,right, forward or backwards) ; *** Note to self - change R0 to R2 after upgrading to firmware 3.2 **
.....and the macro looks like this.....
; ******Trigger 5 - Joystick left,right, forward or backwards ******** ; IO Pin to switch connections J5=left, J6=Right, J7=Forward, J8=Backward G91; Set relative M400; wait for any moves to finish G1 F6000 ; set feedrate to 100mm/sec while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0 ; joystick left G1 X-1 U-1 A-1 elif sensors.gpIn[6].value=0 ; joystick right G1 X1 U1 A1 elif sensors.gpIn[7].value=0 ; joystick forwards G1 Y-1 V-1 B-1 elif sensors.gpIn[8].value=0 ; joystick backwards G1 Y1 V1 B1 elif sensors.gpIn[5].value=0 & sensors.gpIn[7]; joystick left and forward G1 X-1 U-1 A-1 Y-1 V-1 B-1 elif sensors.gpIn[5].value=0 & sensors.gpIn[8]; joystick left and backwards G1 X-1 U-1 A-1 Y1 V1 B1 elif sensors.gpIn[6].value=0 & sensors.gpIn[7]; joystick right and forward G1 X1 U1 A1 Y-1 V-1 B-1 elif sensors.gpIn[6].value=0 & sensors.gpIn[8]; joystick right and backward G1 X1 U1 A1 Y1 V1 B1
I'm not sure about the "while". What I'm trying to say is while any one of those 4 pins is being pulled low by a switch do the following.
After that, I've used 8 "if" or "elif" statements to define what happens with the various switch combinations that are possible. Is that the way to do it?
@deckingman You'll probably need to move the dual input directions in front of the uni-input directions.
Otherwise they won't execute using elif because each combination move will have previously equated to true in the single input section. -
@OwenD said in Yet more conditional gcode help required:
Otherwise they won't execute using elif because each combination move will have previously equated to true in the single input section.Ahh - good point. Does the rest of it look reasonable?
@deckingman said in Yet more conditional gcode help required:
Looks reasonably sane.
You may need an M400 in each elif.
I'm not sure what the cycle time will be so you might experience an accumulation of moves by the time you take your hand off the joystick -
That's unusual for me - I spend most of my time doing crazy stuff
Good point - I'll plaster a few more M400s around
Yes I had considered that - hence the 1mm "nudge move" length to start with. Guess I could either shorten that to (say) 0.1mm and/or scatter a few G4 commands around.
One suggestion: At the first 4 if statements I would add an "AND" with the negated statements of the last 4 if statements. Otherwise when you push the joystick to left forward the ifs "left", "forward" and "left forward" will be executed.
Or wait I think what I just read is only the case if using if instead of elif ...
That's the right approach, however the if..elif statements are not right. Try something like this:
if sensors.gpIn[5].value=0 ; if left button down if sensors.gpIn[7].value=0 ; if joystick left and forward G1 ... elif sensors.gpIn[8].value=0 ; if joystick left and backwards G1 ... else ; just left G1 ... elif sensors.gpIn[6].value=0 ; right button down if sensors.gpIn[7].value=0 ; joystick right and forwards G1 ... elif sensors.gpIn[8].value=0 ; joystick right and backwards G1 ... else ; just right G1 X1 U1 A1 elif sensors.gpIn[7].value=0 ; if just forwards G1 ... elif sensors.gpIn[8].value=0 ; if just backwards G1 ...
You could also add an "else break" at the end, then you wouldn't need to test all the buttons in the while-part.
@dc42 Thanks. That looks good. From my very limited knowledge, I can see that would be "conflict free" compared to what I had.
@all. Thanks for the input everyone - much appreciated. It'll be a couple of days or so before I get time to get the hardware and wiring sorted. Then I'll either report back with a successful outcome, or I'll be asking for more help........
If he removes the while test of all pins, wouldn't the macro only trigger once (when a switch signal rose/fell)
Or do you just mean use "while true" instead (hence the break statement )
I'm always reluctant to use potentially infinite loops. -
Yes I meant use "while true". Or if you don't like infinite loops, "while iterations < 1000" or similar.
@dc42 Thanks for clarification.
I might have locked up a few machines over the years with my clumsy work when using loops.
I realise it's a valid method for those that think things through more than me before they press "executive" edit: "execute" (Stupid iPhone!!!) -
Err, in view of the above and as a further sanity check on my understanding, here is the full macro that I intend to start with ........
G91; Set relative M400; wait for any moves to finish G1 F6000 ; set feedrate to 100mm/sec while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 G1 X-1 U-1 A-1 Y-1 V-1 B-1 elif sensors.gpIn[8]; joystick left and backwards M400 G1 X-1 U-1 A-1 Y1 V1 B1 else ; joystick left only M400 G1 X-1 U-1 A-1 elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 G1 X1 U1 A1 Y-1 V-1 B-1 elif sensors.gpIn[8]; joystick right and backward M400 G1 X1 U1 A1 Y1 V1 B1 else ; joystick right only M400 G1 X1 U1 A1 elif sensors.gpIn[7].value=0 ; joystick forwards only M400 G1 Y-1 V-1 B-1 elif sensors.gpIn[8].value=0 ; joystick backward only M400 G1 Y1 V1 B1 else break
Is that about right?
To clarify my comments.
A "while" statement will loop if the condition test is true.
In your case by testing all those inputs.If you put
while true G1 X1
Then you have an endless loop as true always equals true, so you're going to crash.
Therefore you must ensure that you put a test in somewhere the calls "break" to get you out of the loop.In the suggested code above that test is satisfied when none of the IF statements resolve to true, so break is called.
OK, so that's all wired up and working. It does what I hoped it would and it respects the axis limits too (of course it does - I never doubted it would
But I'd like to add an embellishment if possible. I've used 1mm as a movement length which is great for reasonably precise positioning but naturally, it's a bit slow if I want to travel the full 400mm or so of axis travel. Increasing the step size to (say) 5mm is about right but then I lose precision. So what I'd like to do is a bit like how one sets the time on some digital clocks. That is to say, the longer one holds the button, the faster the time changes.
So I'd like to alter the code so that if I hold the joystick in one position, it will move in 1mm increments but after (say) 5 iterations, the move length will increase to (say) 5mm). Ideally I'd like to do something a bit more sophisticated still, like keep increasing the move length the longer the joystick is held in one position but I'll settle for just a binary change after say 5 iterations of the same move.
Here is the code that I have now (without the errors that I had in some of the elif commands when I last posted it
G91; Set relative M400; wait for any moves to finish G1 F6000 ; set feedrate to 100mm/sec M118 S"Trigger 5 - Joystick" while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0 if sensors.gpIn[5].value=0; joystick left if sensors.gpIn[7].value=0 ; joystick left and forwards M400 G1 X-1 U-1 A-1 Y-1 V-1 B-1 echo "Left and forward" elif sensors.gpIn[8].value=0; joystick left and backwards M400 G1 X-1 U-1 A-1 Y1 V1 B1 echo "Left and backwards" else ; joystick left only M400 G1 X-1 U-1 A-1 echo "Left" elif sensors.gpIn[6].value=0; joystick right if sensors.gpIn[7].value=0 ; joystick right and forwards M400 G1 X1 U1 A1 Y-1 V-1 B-1 echo "Right and forward" elif sensors.gpIn[8].value=0; joystick right and backward M400 G1 X1 U1 A1 Y1 V1 B1 echo "Right and backwards" else ; joystick right only M400 G1 X1 U1 A1 echo "Right" elif sensors.gpIn[7].value=0 ; joystick forwards only M400 G1 Y-1 V-1 B-1 echo "Forward" elif sensors.gpIn[8].value=0 ; joystick backward only M400 G1 Y1 V1 B1 echo "Backwards" else break
