    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.5k
    • shattyundefined
      shatty
      Also, anyway of using the stock screen with the new Beta RR firmware? I saw it now supports 2 other screens. I dont know what chipset the stock screen has
      • Vetiundefined
        Veti
        do you have Heat-shrink tubing? or a solder iron.
        fixing cut wiring is not that difficult
        shattyundefined 1 Reply Last reply Reply Quote 0
        • shattyundefined
          shatty @Veti
          @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
          Yes of course....Im in IT.
          I would rather buy new cables with the 4 pin already on them.
          • shattyundefined
            shatty
            They also have jacketed wire but not terminated. Better protection.
            • shattyundefined
              shatty
              Im just gunna repair it. Not in the mood to change shit around. Let u know what happens tom night. Thanks for the help
              • shattyundefined
                shatty
                Well guess what...............HOMING WORKS!!!! Went to the endstops and stopped! Question...Z axis...positive value is up or down? Z positive and the bed moves down. I have a feeling its supposed to be reversed. I repaired the wire on one of the Z stepper wires.
                Vetiundefined 1 Reply Last reply Reply Quote 0
                • shattyundefined
                  shatty
                  And the BLT is making the bed stop moving up so that works. Now I guess I have to do a test print and adjust the distance from the nozzle to the bed, make sure the BLT is working on leveling, extruder speed, and manual bed leveling before I use the BLT
                  • Vetiundefined
                    Veti @shatty
                    @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                    when the bed is at the bltouch trigger that is z=0 the further the bed moves away from the bltouch, z increases.
                    so for the ender 5 plus i think going down is positive
                    • shattyundefined
                      shatty @Veti
                      OK so its correct then. Whats my next step? BLT distance ? Extruder motor speed and stuff? I have a Micro Swiss direct drive all metal installed. I was reading the directions and they said 1 or 2 things have to be changed. As far as leveling, manual first then use the BLT? I guess use the wheel adjustments in each corner? How do I know when its correct? Should I use a level? Any way for the machine to tell me?
                      • Vetiundefined
                        Veti @shatty
                        @shatty
                        yes calibrate the z probe.
                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                        then do a mesh bed leveling and look at the bed. (post a picture)
                        then calibrate your e steps
                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                        then pid tune your bed and hotend.
                        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                        then print a benchy and asses.
                        shattyundefined Vetiundefined 3 Replies Last reply Reply Quote 0
                        • shattyundefined
                          shatty @Veti
                          This post is deleted!
                          • shattyundefined
                            shatty
                            All the steppers are quiet except the 2 Zs. Normal?
                            • shattyundefined
                              shatty @Veti
                              You want me to print a replica of my ass? LOL
                              • Vetiundefined
                                Veti @shatty
                                @shatty
                                funny typo i mean assess.
                                what exactly do you mean by quiet?
                                stand still noise?
                                https://duet3d.dozuki.com/Wiki/Reducing_Stand-Still_Noise
                                • shattyundefined
                                  shatty @Veti
                                  @Veti
                                  When the Z's are going up and down during the mesh test, they are louder than others
                                  • Vetiundefined
                                    Veti @shatty
                                    @shatty
                                    yes, z movement with a leadscrew is noisier than other movements.
                                    • shattyundefined
                                      shatty
                                      I dunno why that corner is so off
                                      • shattyundefined
                                        shatty @Veti
                                        @Veti Hows the bed leveling?
                                        • Vetiundefined
                                          Veti
                                          looks good, just dont printer on the borders of the bed, continue on.
                                          • shattyundefined
                                            shatty
                                            Getting error on bed heat....saying its not rising fast enuf...1.7c a sec. I also have the bed connected to the mosfet that came with the stock setup.
