    D-Bot/CrusaXY mash up (CoreXY iDEX)
    My Duet controlled machine
    8
    40
    2.6k
    • Rushmere3Dundefined
      Rushmere3D
      Hi all,
      So I thought as I'm now a Duet3D convert I should post my new printer build. First this to say it's still very much a work in progress, it's going to be an iDEX printer but currently only has one tool carriage installed, while I get to grips with the firmware side of things. This is my first Duet3D board so it's be a learning experience but once I got my head around it, it's going well.
      So spec are currently,
      Duet 3 0.6 with 3.1.1 firmware with a raspberry pi 3B attached.
      300mm on X, 270mm on Y and 300mm on Z.
      It has a Prusa MK3 extruder on a magnetic carriage system, allowing for quick hotend swaps.
      E3D V6 hotends 24v.
      700W Keenovo 240V AC bed attached to a 5mm Aluminium Tooling Plate.
      Bed leveling is via a PINDA v1 from my old MK2.
      So when I say it's a D-Bot/CrusaXY mash up that basically means I used my 300mm D-Bot (Link) for parts to make the printer designed by Hunter Bernstein on thingiverse (Link). The parts I printed are version 1 and they have been updated but I'm going to use this for now. The idea behind Hunter's design is to use a Creality3D CR-10 S5 and convert it to an iDEX printer, I didn't have a CR-10 so when the D-Bot conversion route.
      So on to some pictures, I will be updating this thread as I add the extra tool etc but for now this is what it looks like.
      So as you can see I'm using a quick disconnect extruder board, these are connected with a 26pin ribbon cable and so far works great, I remixed some things of thingiverse to make a bracket that holds the cable and I used some flat 9.5x0.3mm spring steel to support the cable (Like the E3D tool changer)
      Well that's about it for now, I'll post updates soon.
      Thanks,
      James.
      Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
      • Vetiundefined
        Veti
        a duet 3 toolboard would be a good fit for that setup i think
        Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
          Rushmere3D @Veti
          @Veti
          It would but for the cost of the PCB's and connectors this is far far cheaper and simpler to setup.
          I'm thinking about adding an extra stepper motor for dual Z motor control, that would be via a duet expansion board.
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @Rushmere3D
            @Rushmere3D said in D-Bot/CrusaXY mash up (CoreXY iDEX):
            thats twice the price of a Duet 3 Toolboard 1LC (which contains 1 stepper driver)
              Rushmere3D @Veti
              @Veti
              I can use a Tool board for a Z stepper driver?
              • Vetiundefined
                Veti @Rushmere3D
                @Rushmere3D
                you could, but it makes more sense to drive the stepper motor on the extruder with it and free up the driver on the duet 3 board for the second z
                  Rushmere3D @Veti
                  @Veti
                  Oh right I see now, yeah that's a good idea. Thanks I'll consider it.
                  • Vetiundefined
                    Veti
                    it has the same mounting option as your board.
                    https://www.duet3d.com/Duet3Toolboard1LC
                    and you only need 4 wires.
                    2 wires for data and 2 for power.
                      Good to see a dbot get some love.
                        Rushmere3D
                        First few prints off the printer.
                        • matt3oundefined
                          matt3o
                          great work. you guys are all better than me at producing great printers 👅
                            Rushmere3D
                            Hey all,
                            Thought I'd post some more pictures of the extruder setup I'm currently using, just to have a complete record on this thread.
                            First up in the PINDA probe mount
                            And here the magnetic extruder mounts
                            And a better view of the extruder board, this is the second tool, so the bed leveling headers aren't soldered in
                            • T3P3Tonyundefined
                              T3P3Tony administrators
                              Nice work @Rushmere3D I will move this post to the "may duet controlled machine" category so its easier to find for people wanting to do something similar.
                              www.duet3d.com
                                Rushmere3D @T3P3Tony
                                @T3P3Tony
                                Thank you, it wasn't until after I made the thread I realised there was a better category but couldn't change it myself?
                                  Rushmere3D
                                  Hi all,
                                  So I'm finally getting around to adding the second extruder to my iDEX printer and I was wondering if someone knowledgeable would be kind enough to take a look at my config I've made? I'm waiting on a few connectors and tool so the printer isn't currently moving so I've take a guess on some of the offsets but some advice with that would also be appreciated but it's more the setup and naming of things I'm unsure of.
                                  Edit to remove config files, as I'm making changes to my config. Will request help again soon 😜
                                  Thanks in advance, James.
                                    Rushmere3D
                                    Quick question, am I right in thinking if I want to run two Toolboards on a duet3 I also need a Distribution Board?
                                    Thanks,
                                    J.
                                    jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      Rushmere3D
                                      Another question while I think of it. Can you modify macros on the paneldue?
                                        Rushmere3D
                                        Anyone able to answer my two questions?
                                        Thanks.
                                          jay_s_uk @Rushmere3D
                                          @Rushmere3D
                                          Thanks,
                                          J.
                                          Yes, you'll need a distribution board
                                          no, you can't
                                          Rushmere3Dundefined 1 Reply Last reply Reply Quote 1
                                            Rushmere3D @jay_s_uk
                                            @jay_s_uk
                                            Thank you.
