Duet 3 : No tool nor bed shown
@Veti My duet web control is 3.1.1
Hum the macro is not saved in the micro SD ... I think the problem is from here ...
@Donpi If you're using SBC, you shouldn't have an SD card in the Duet! The O: directory is a virtual SD drive on the Raspberry Pi. See https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Virtual_SD_card
Where is your config.g? On the SD card in the Duet, or on the Raspberry Pi?
@droftarts
Of cours in the raspberry
There is no card on de Duet -
Hooo... could it be that the partition I see on windows is the one for the Duet in standalone mode.
And that the partition use by the Raspberry Bi is not visible on windows ? -
@Donpi said in Duet 3 : No tool nor bed shown:
And that the partition use by the Raspberry Bi is not visible on windows ?Very likely!
All that for this ...
Sorry for the time lost -
you are making the changes on the sd card in windows?
@Veti Yes
why are you not using the editor on the web interface?
@Veti Now I use IT
