    Duet 3 : No tool nor bed shown
    1.1k
    • Donpiundefined
      Donpi @droftarts
      @droftarts strange this work well.
      and if I call M308 S0, it says :
      Sensor 0 (bed Temp) type bla bla bla...
      It's like my config.g is not readed or somthing reset everything
      • Donpiundefined
        Donpi @Veti
        @Veti With a complettely new copnfiguration strait from the generator I have the same behaviour
        • Vetiundefined
          Veti
          what version of the duet web control are you running?
          Donpiundefined 2 Replies Last reply Reply Quote 0
          • Donpiundefined
            Donpi @Veti
            @Veti
            I'am a bit puzzled ...
            I have created a macro with my config.g.
            And running the macro I get the tootls and heaters...
            It' just give me this errors
            I don't know why my config.g is ignored...
            • Donpiundefined
              Donpi @Veti
              @Veti My duet web control is 3.1.1
              • Donpiundefined
                Donpi
                Hum the macro is not saved in the micro SD ... I think the problem is from here ...
                  droftarts administrators @Donpi
                  @Donpi If you're using SBC, you shouldn't have an SD card in the Duet! The O: directory is a virtual SD drive on the Raspberry Pi. See https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Virtual_SD_card
                  Where is your config.g? On the SD card in the Duet, or on the Raspberry Pi?
                  Donpiundefined 1 Reply Last reply Reply Quote 0
                  • Donpiundefined
                    Donpi @droftarts
                    @droftarts
                    Of cours in the raspberry
                    There is no card on de Duet
                    • Donpiundefined
                      Donpi
                      Hooo... could it be that the partition I see on windows is the one for the Duet in standalone mode.
                      And that the partition use by the Raspberry Bi is not visible on windows ?
                        @Donpi said in Duet 3 : No tool nor bed shown:
                        Very likely!
                        • Donpiundefined
                          Donpi
                          All that for this ...
                          Sorry for the time lost 😕
                          • Vetiundefined
                            Veti @Donpi
                            @Donpi
                            you are making the changes on the sd card in windows?
                            • Donpiundefined
                              Donpi @Veti
                              @Veti Yes
                              • Vetiundefined
                                Veti
                                why are you not using the editor on the web interface?
                                • Donpiundefined
                                  Donpi @Veti
                                  @Veti Now I use IT 🐷
