    First Layer and Extrusion Problems
    6.0k
    • fcwiltundefined
      fcwilt @A Former User
      @CaLviNx said in First Layer and Extrusion Problems:
      @fcwilt
      so does that one above......................
      But if you have to set the Z=0 datum somewhere else you have to remember to use those same values.
      • Frederikundefined
        Frederik
        so i hope i changed everything accordingly.
        after i run a mesh i got this hightmap
        and this the consol putput:
        20.11.2020, 22:08:00	G32
        Leadscrew adjustments made: 0.283 0.880 0.293, points used 3, (mean, deviation) before (0.453, 0.263) after (-0.000, 0.000)
        Leadscrew adjustments made: -0.044 0.333 -0.061, points used 3, (mean, deviation) before (0.053, 0.172) after (-0.000, 0.000)
        Height map loaded from file heightmap.csv
        20.11.2020, 22:05:43	G29
        156 points probed, min error -0.837, max error 1.678, mean 0.186, deviation 0.523
        Height map saved to file heightmap.csv
        • A Former User?
          A Former User @fcwilt
          @fcwilt said in First Layer and Extrusion Problems:
          why would a beginner (as it was you that put the beginner thing out there) require to be going down the route of setting a Z=0 elsewhere ?
          • A Former User?
            A Former User @Frederik
            @Frederik
            do you have a picture of your setup ? (as in the printer itself)
            Frederikundefined 1 Reply Last reply Reply Quote 0
            • Frederikundefined
              Frederik @A Former User
              @CaLviNx IMG_20201120_221537.jpg IMG_20201120_221704.jpg IMG_20201120_221621.jpg
              My Printer is a Ratrig VCore Pro Kit with the EasyMod and EVA Carriage.
              I startet my journey into 3d printing around 4 weeks ago with Information gathering etc...
              ... And 4 days ago, I finished the build.
              • A Former User?
                @Frederik
                if it was me I would firstly tension the bed to bed frame springs, then measure them and make they all the same height, perpendicular to the bed frame.
                Then I would home all with the final homing of Z axis taking place with the probe located at the bed centre.
                Then I would have the printer carry out a G32 (more than once) NOTHING else, and allow it to "level" the bed/frame using the three lead screws, and allow it to apply those corrections .
                Then carry out a single G30 probing at the centre of the bed to re-establish the datum point.
                Then finally carry out a G29 and see what it comes up with.
                You need to remember level doesnt mean flat..... and dont get too hung up on the graphic look at the amount of deviation you have.
                how many linear rails does the z axis run on ?
                • Frederikundefined
                  @CaLviNx Ok, i will test this in the morning.
                  I have 2 Linear Rails on z ( left + right in the middle ). The Leadscrews are ~ 6 cm in front of them
                  • A Former User?
                    @Frederik said in First Layer and Extrusion Problems:
                    A very strange (to me anyway) arrangement for linear rails, in that you would expect 3 rails with three lead screws.
                    But if it works then happy days. Personally I always have x3 rails/lead screws and have the bed frame with a degree of articulation to allow the levelling to operate as it should, once you get it setup the levelling gives you great prints
                    • Vetiundefined
                      Veti
                      G30 P0 X2 Y-2 Z-99999 ; Probe near the front left lead-screw
                      G30 P1 X152 Y278 Z-99999 ; Probe near the rear lead screw
                      G30 P2 X290 Y-2 Z-99999 S3 ; Probe near the front right lead-screw
                      M671 X425:200:-25 Y240:-25:240 S1 ; leadscrews at front left, rear middle and front right
                      how are these points near the leadscrews?
                      • Frederikundefined
                        @CaLviNx That´s how this kit is designed. Eventually, I will change it to a kinematic mount without the 2 Linear Rails like the HevOrt. At the moment I have a battle with my E3d Volcano... it is constantly clogging and I don´t know what
                        I´m doing wrong... trying to print PLA with ~ 205 ° Nozzle and 60° Bed.
                        • Frederikundefined
                          Frederik @Veti
                          @Veti i have this settings:
                          M671 X425:200:-25 Y240:-25:240 S3 - position of Spindles with drives 2.3.4
                          and this are the spot i´m probing:
                          G30 P0 X330 Y250 Z-99999 ; Probe near the front left lead-screw
                          G30 P1 X165 Y0 Z-99999 ; Probe near the rear lead screw
                          G30 P2 X0 Y250 Z-99999 S3 ; Probe near the front right lead-screw
                          • Vetiundefined
                            Veti
                            is 0,0 not the bottom left of your printbed?
                            • Frederikundefined
                              Frederik @Veti
                              @Veti x0,y0 ls in my case the right, rear corner
                              Vetiundefined 1 Reply Last reply Reply Quote 0
                              • Frederikundefined
                                Frederik
                                I could only mount the Endstop on the left side of my carriage and the Y Endstop is at the back
                                • Vetiundefined
                                  Veti @Frederik
                                  thats going to be very confusing.
                                  certainly because of that you got the offset of your probe wrong.
                                  Frederikundefined 2 Replies Last reply Reply Quote 0
                                  • Frederikundefined
                                    Frederik @Veti
                                    @Veti should i change it ?
                                    • Frederikundefined
                                      Frederik @Veti
                                      @Veti this is my actual drive mapping and endstop config:
                                      M569 P0.0 S0                                          ; physical drive 0.0 goes backwards
                                      M569 P0.1 S0                                          ; physical drive 0.1 goes backwards
                                      M569 P0.2 S0                                          ; physical drive 0.2 goes backwards
                                      M569 P0.3 S0										  ; physical drive 0.3 goes backwards
                                      M569 P0.4 S0										  ; physical drive 0.4 goes backwards
                                      M569 P0.5 S1                                          ; physical drive 0.5 goes forwards
                                      M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5                      ; set drive mapping```
                                      ;Endstops
                                      M574 X2 S1 P"!io1.in"                                 ; configure active-high endstop for high end on X via pin !io1.in
                                      M574 Y1 S1 P"!io0.in"                                 ; configure active-high endstop for low end on Y via pin !io0.in
                                      M574 Z2 S2                                            ; configure Z-probe endstop for low end on Z
                                      • Vetiundefined
                                        Veti
                                        can you set 0,0 in your slicer to be top right? i just checked in prusaslicer and 0,0 is bottom left
                                        • Frederikundefined
                                          Frederik @Veti
                                          @Veti i have to look. i used cura 4.8.0 at the moment. I didn´t want to spend money on simplyfy 3d bevor the new version 5 is released. Hopefully soon 🙂
                                          • Frederikundefined
                                            Frederik @Veti
                                            @Veti yes, its possible. you can set high or low endstop positions in advanced printer setttings
