Confused on wiring for Ender 3 Pro Conversion
So I finally bit the bullet and started making extensions for my Maestro 2 board and though LED's are lighting up, my PanelDue 7i just sits there and says "Connecting". Now I was looking over the guide and it says that I can just snip off the little tabs on the connectors and they should slide right into the connectors on the Maestro 2 board. But then looking at the wiring diagram, it shows that 1a and 1b are in 2 different spots between the 2 boards. I've tried both ways and still, the 7i says "Connecting". So now I have no idea how to assess this and fix my issue. Honestly, not even sure what my issue is.
I do have the 24v fan that is supposed to be on all the time, plugged in. It's not spinning at all.
I did see on one of the pages that there was a Configuration tool, but that link just leads to a dead page. When I connect my Maestro 2 by Ethernet, I can see it and I do have it updated to the most recent live version. 3.1.1.
did you enable paneldue support in the config?
Ah, I assumed that since they are both products from Duet3D, that they may have just worked with each other. Am I able to send that as a M code? Can't find my longer ethernet to access by IP. But I have a PC close enough to connect by the USB cable that came with the board.
hi
please dont connect the usb while other power is connected.
see https://duet3d.dozuki.com/Wiki/USB_ground_loopshave you read this guide?
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37the config tool is here
https://configtool.reprapfirmware.org/Start
When ever I connect by USB, I have the power supply cable unplugged from it. I'll check out the guide again and see what it says. Thanks.
EDIT And this is the guide I have already been using.
This post is deleted!
if you set a password its in the config.g that you generated
i.e
M551 P"test" ; set password
@Veti Yeah, I went back and set an actual password. Thank you.
Now when I start the E3P and everything works fine except I get "ERROR: Temperature reading fault on heater 1: open circuit" I followed all the steps in the setup guide you have linked above. Though the configurator is different than in the guide, it's still pretty straight forward.
Current temp is showing -273.1c. And when I go to test the heaters, it throws off a bunch of errors and nothing heats up.
what is this test heater macro? that seems to test a second heater that you did not configure.
this means that your thermistor is shorted out and has no resistance. check the wiring.
@Veti I'm using the Test button that's on the web interface and also on the 7i when I'm looking at that panel. I cut and termed the wires with the pins and connectors for the Duet board. When I copied over from diagram to diagram, it showed the same error. Switched the 2 wires thinking that I may have read it wrong, same error.
@Destruct0Dan said in Confused on wiring for Ender 3 Pro Conversion:
the macro is certainly not for your printer and does not work.
check the wire with a multimeter.
@Veti Well, guess I have to wait for that to come in. Don't have one. Once I get this, how do I need to test to make sure everything is okay?
does the bed temperature work?
@Destruct0Dan FYI, the 'test_xxx' macros (that you're seeing) are the ones that come on the SD card from the factory. They are the end of line tests that Duet3d run with their test setup to check the board, so won't work for your setup. Recommendation is to delete them
@Veti No, bed temp won't turn on either.
@engikeneer Ah okay, thanks. How can I or how do I remove those?
@Destruct0Dan via the web control, go to macros to find them, right click and delete.
Otherwise, put the sd card in your PC and delete them.
Might be a way through Paneldue, but I don't have one so wouldn't know how...
@engikeneer said in Confused on wiring for Ender 3 Pro Conversion:
Nope.
@Destruct0Dan When you first turn the printer on what do the heater temps report?
Can you post a picture of how you have the thermistor and heater wires connected on the board?
Also post your config.g and the results of sending M122 and M98 P"config.g"
; Configuration file for Duet Maestro (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.9 on Sat Nov 28 2020 10:13:54 GMT-0800 (Pacific Standard Time); General preferences
M550 P"Ender3ProMaestro2" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M551 P"REDACTED" ; set password
M552 P192.168.1.23 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.1.254 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P3 S0 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z260 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T9880 B4185 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M308 S1 P"e0temp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
M106 P2 S0 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P0 S"HotEnd" D0 H1 F0:1:2 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M575 P1 S1 B57600 ; enable support for PanelDue; Miscellaneous
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0 ; select first tool
From the M122:
M122
RepRapFirmware for Duet 2 Maestro version 3.1.1 running on Duet Maestro 1.0
Board ID: 08DLM-9T6R1-MA3TN-6JKD4-3SW6J-KFZKP
Used output buffers: 3 of 24 (10 max)
Static ram: 21924
Dynamic ram: 93124 of which 32 recycled
Exception stack ram used: 176
Never used ram: 15816
Tasks: NETWORK(ready,472) HEAT(blocked,548) MAIN(running,1996) IDLE(ready,84)
Owned mutexes:
Last reset 00:01:23 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 19672 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 23.6, current 30.1, max 30.2
Supply voltage: min 0.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, read errors 0, write errors 0, ifcount 7, reads 3338, timeouts 0
Driver 1: standstill, read errors 0, write errors 0, ifcount 7, reads 3338, timeouts 0
Driver 2: standstill, read errors 0, write errors 0, ifcount 7, reads 3338, timeouts 0
Driver 3: standstill, read errors 0, write errors 0, ifcount 7, reads 3338, timeouts 0
Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 3339, timeouts 0
Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3345
Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 3344
Date/time: 2020-11-28 14:20:09
Slowest loop: 3.01ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 15.0MBytes/sec
SD card longest read time 0.7ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 56.41ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplex
And then with the last request:
