    Duet 3 MH6HC with Duet expansion 1XD, configuration issue
    1.4k
    • dkraja42undefined
      dkraja42
      Hii,
      I have Duet 3 Main board with Pannel due7", currently i am using small stepper motors, that works fine,
      now we purchase "NEMA34 12Nm motor 86EBP181ALC and driver ZDM-2HA865 closed loop stepper motor drive", and also purchase "Duet3Expansion1XD" for 4 external stepper drive.
      but in Rip Rap configuration not showing any option to configure the Duet3Expansion1XD. so how can be configured. if anyone have config file for external 1xd running Cartesian printer.
      Please check the attachment........
        Have you seen this?
        https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD
        dkraja42undefined 1 Reply Last reply Reply Quote 0
        • chrishammundefined
          chrishamm administrators
          We're still working on the configtool to add support for the 1XD. In the meantime you'll probably be able to choose tool boards as a replacement but the CAN addresses will be off (121 vs 122).
          Please follow the EXP1XD documentation for further information.
          Duet software engineer
          dkraja42undefined 2 Replies Last reply Reply Quote 0
          • dkraja42undefined
            dkraja42 @chrishamm
            @chrishamm tommarow we need to start the printing then how can we map X,Y,Z axis of external stepper motor
            • dkraja42undefined
              dkraja42 @chrishamm
              @chrishamm [0_1606676388351_config (20).zip](Uploading 100%)
              • dkraja42undefined
                dkraja42
                can you send config. file then we edit manually 1xd expansion board mapping.config.json
                • dkraja42undefined
                  dkraja42 @Phaedrux
                  @Phaedrux can you send sample config. with mapping of 1-X axis, 2-Y axis and 2-Z axis using EXP1XD .config.json
                    You're going to have to do some reading.
                    https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD#Section_Sample_configuration_examples
                    • dkraja42undefined
                      dkraja42 @Phaedrux
                      We have configured the 1XD external driver: But showing following errors:
                      30/11/2020, 12:07:39 M32 "0:/gcodes/config.g"
                      File 0:/gcodes/config.g selected for printing
                      Error: Setting not available for external drivers
                      Ethernet is enabled, configured IP address: 0.0.0.0, actual IP address: 192.168.0.120
                      Finished printing file 0:/gcodes/config.g, print time was 0h 0m
                      30/11/2020, 12:07:38 Upload of config.g successful after 0s
                      Config .g code here:
                      ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 11:43:55 GMT+0530 (India Standard Time)
                      M550 P"Duet 3" ; set printer name
                      M569 P40.0 S1 R1 ; change enable polarity, active = disable drive
                      M569 P41.0 S1 R1 ; change enable polarity, active = disable drive
                      ;M569 P42.0 S1 R1 ; change enable polarity, active = disable drive
                      M584 X40.0 Y41.0 Z0.2 E0.3
                      ;M584 X40.0 Y41.0 Z42.0 E0.3 ; set X, Y, Z, Extruder drivers
                      ;M569 P0.0 S1 ; physical drive 0.0 goes forwards
                      ;M569 P0.1 S1 ; physical drive 0.1 goes forwards
                      ;M569 P0.2 S1 ; physical drive 0.2 goes forwards
                      ;M569 P0.3 S0 ; physical drive 0.3 goes backwards
                      ;M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                      M92 X100.00 Y100.00 Z400.00 E90.00 ; set steps per mm
                      M566 X900.00 Y900.00 Z60.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
                      M203 X12000.00 Y12000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
                      M906 X2000 Y2000 Z2000 E2000 ; set motor currents (mA)
                      M84 S0 ; Disable motor idle current reduction
                      M208 X230 Y230 Z230 S0 ; set axis maxima
                      M574 X1 S1 P"!^io3.in" ; configure active-high endstop for low end on X via pin !^io3.in
                      M574 Y1 S1 P"!^io1.in" ; configure active-high endstop for low end on Y via pin !^io1.in
                      M574 Z1 S1 P"!^io2.in" ; configure active-high endstop for low end on Z via pin !^io2.in
                      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                      M557 X15:220 Y15:220 S20 ; define mesh grid
                      M308 S0 P"temp1" Y"thermistor" T100000 B5000 ; configure sensor 0 as thermistor on pin temp1
                      M950 H0 C"out2" T0 ; create bed heater output on out2 and map it to sensor 0
                      M308 S1 P"temp0" Y"thermistor" T100000 B5000 ; configure sensor 1 as thermistor on pin temp0
                      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                      M143 H1 S230 ; set temperature limit for heater 1 to 230C
                      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                      M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
                      ; Custom settings
                      M575 P1 S1 B57600
                      M570 H0 P999 S240
                      M552 S1
                      M552 192.168.0.132
                      JoergS5undefined 2 Replies Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @dkraja42
                        @dkraja42
                        M350 and M906 are not needed for the drives which use the external drivers, because microstepping and current setting are done in the external drivers (either by switches or by firmware setting of the external driver).
                        You've defined 2 drivers (40.0, 41.0, missing 0.2 and 0.3), but using 4 (XYZE).
                        • dkraja42undefined
                          dkraja42 @JoergS5
                          @JoergS5 can you modify code for our requirement is:
                          1. X axis stepper-01 nos
                          2. Y axis stepper-02 nos
                          3. Z axis stepper-02 nos
                          4. internal extruder
                          • JoergS5undefined
                            JoergS5 @dkraja42
                            @dkraja42 said in Duet 3 MH6HC with Duet expansion 1XD, configuration issue:
                            should be changed to
                            and then in the M584:
                            M584 X40.0 Y41.0 Z42.0 E0.0 ; set X, Y, Z, Extruder drivers
                            so here you map your M569 P numbers to the letters of the drives.
                            And remove X, Y and Z from M350 and M906.
                            • dkraja42undefined
                              dkraja42 @JoergS5
                              @JoergS5 ok. thanks. i will try
                              • dkraja42undefined
                                dkraja42 @JoergS5
                                @JoergS5
                                Error: Bad command: 584 X40.0 Y41.0 Z42.0 E0.0
                                Axis Limits
                                ; Custom settings
                                M575 P1 S1 B57600
                                M570 H0 P999 S240
                                M552 S1
                                M552 192.168.0.132
                                JoergS5undefined 1 Reply Last reply Reply Quote 0
                                  You appear to have lost the M at the start of the M584 line.
                                  • dkraja42undefined
                                    dkraja42 @dc42
                                    @dc42 yes we corrected M584 command line. but not able to move any axis.
                                    30/11/2020, 13:04:11 M32 "0:/gcodes/homex.g"
                                    File 0:/gcodes/homex.g selected for printing
                                    30/11/2020, 13:04:10 Upload of homex.g successful after 0s
                                    30/11/2020, 13:03:59 M32 "0:/gcodes/config.g"
                                    30/11/2020, 13:03:58 Upload of config.g successful after 0s
                                    jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      1. Are the red status LEDs on the expansion boards all blinking in sync with the one on the main board?
                                      2. Have you tested the axis motors individually, using G91 followed by G1 H2 moves, e.g. G91 G1 H2 X10 ?
                                        jay_s_uk @dkraja42
                                        @dkraja42 all your config files are in the folder gcodes rather than the folder sys.
                                        until you move them, they won't work correctly
                                        • dkraja42undefined
                                          dkraja42 @dc42
                                          @dc42 said in Duet 3 MH6HC with Duet expansion 1XD, configuration issue:
                                          ed stat
                                          We have check all the manually G91 code but not able to move.
                                          We have attached Video link and some images. please check ..
                                          https://drive.google.com/file/d/1bjjLoMsEUapcxTMKrXVd_gO4B-17KvXU/view?usp=sharingWhatsApp Image 2020-11-30 at 1.15.21 PM.jpeg WhatsApp Image 2020-11-30 at 1.15.21 PM (1).jpeg
                                          • JoergS5undefined
                                            JoergS5 @dkraja42
                                            @dkraja42 and you removed M350 and M906 completely. Please remove XYZ values for it only, not the command completely. For E you still need the settings:
                                            M350 E16 I1 ; configure microstepping with interpolation
                                            M906 E2000 ; set motor currents (mA)
