    Pressure advance Tuning like Klipper
    15
    1.6k
    • Vetiundefined
      Veti
      I liked to way that klipper does the pressure advance tuning, so i worked out how to do the same for the duet.
      the steps are the same as the klipper guide with the follow differences.
      https://github.com/KevinOConnor/klipper/blob/master/docs/Pressure_Advance.md
      Setting the acceleration is done via
      M201 X500 Y500
      instead of the TUNING_TOWER COMMAND we use a prusaslicer feature.
      In the Printer settings for custom g-code we set the After layer change g-code to
      M572 D0 S{layer_z*0.005}
      or for boden
      M572 D0 S{layer_z*0.02}
      zaptaundefined 1 Reply Last reply Reply Quote 4
      • PCRundefined
        PCR
        Thank you!!!
        • nick9one1undefined
          nick9one1
          A slight addition to this is how to include the starting pressure advance.
          Once you have used the original 'after layer change' code to get a rough idea of where the sweet spot is you can use the gcode below.
          For my printer the sweet spot was about 0.5. So I printed again, starting at 0.4 and up to 0.65
          M572 D0 S{(layer_z*0.005)+0.4}
          • gringoundefined
            gringo
            Do both Lines come into the Slicer in the Custom GCode before Layer Change?
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti @gringo
              @gringo
              only the M572, the M201 you can execute before print starts manually
              • zaptaundefined
                zapta @Veti
                @Veti said in Pressure advance Tuning like Klipper:
                Is there a way to have an expression that will set it up in 'bands' rather than gradual on every layer? May be easier to determine the best value.
                OwenDundefined 1 Reply Last reply Reply Quote 0
                • OwenDundefined
                  OwenD @zapta
                  @zapta said in Pressure advance Tuning like Klipper:
                  You could use something
                  If mod(layer_z,5)==0
                  This would only increment every 5 layers.
                  Note this is untested and Prusa slicer can get funny about if statements in its gcode sections as it trys to evaluate them itself using its own rules
                  You may have to wrap the whole expression in curly brackets or something
                  EDIT: actually I think I recall prusa slicer won't allow indenting in the layer gcode so this may not work
                  EDIT
                  A quick search revealed something like this should work in prusa slicer... again untested
                  {if layer_z % 5 == 0}M572 D0 S{layer_z*0.005}{endif}
                  zaptaundefined 1 Reply Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @OwenD
                    @OwenD said in Pressure advance Tuning like Klipper:
                    Mathematically this seems right. You may want to multiply 0,005 by 5 to have the same range (5 layers per band). Bands make it easier to identify the best value.
                    May be worth replacing the gcode in https://duet3d.dozuki.com/Wiki/Pressure_advance with a simplified one along these lines.
                    • OwenDundefined
                      OwenD
                      actually mod() won't work as layer_z is a floating point number.
                      It would work with layer_num but that makes determining the value used at a specific height different to the example.
                      • oliofundefined
                        oliof
                        In RRF, metacommand function mod works with floats, so use if mod(floor(move.axes.2.machinePosition), 5.0) maybe? Untested.
                        • Vetiundefined
                          Veti
                          if you actually print with the gradual change, its a lot easier to determine where the optimal line is as its a gradual change. and using the calipers gives you an easy way to calculate the right value.
                          • 3dMLundefined
                            3dML
                            @Veti
                            Create a macro and call it at layer change. Much easier to update the macro instead of slicing the file for every change.
                            You can call macros from the macro folder using the full file location similar to
                            M98 P"0:/macros/Calibrate Things"
                            Put something similar to this in the macro. Again this particular code is untested.
                                 echo {move.axes[2].userPosition} ; change 2 in axes[2] to the z axis for your machine
                                 echo {layer_z*0.005}
                            This will report the the z height and the PA value every time it changes.
                            • littlehobbyshopundefined
                              littlehobbyshop
                              Adding to what @3dML said...
                              This macro has been tested and works nicely, change tool no./layer height/increment value to suit. It also covers the case where you want to start from a value other than 0, simply change the first M572 parameter.
                              ;Increase pressure advance by 0.005 every 5 layers
                              if job.layer == 0
                              	M572 D0 S0 ; starting value
                              	echo "Layer " ^ job.layer ^ " started"
                              	echo "Pressure advance reset to " ^ {move.extruders[0].pressureAdvance + 0.000}
                              elif mod(job.layer, 5) == 0 ; no. of layers
                              	M572 D0 S{move.extruders[0].pressureAdvance + 0.005} ; increment
                              	echo "Pressure advance = " ^ {move.extruders[0].pressureAdvance + 0.000}
                              Interestingly the "+ 0.000" is required to force the console to print 3 decimal places, otherwise it rounds down to 2.
                              BLV MGN Cube w/Hemera, K8200, Sunlu S8
                              dc42undefined 1 Reply Last reply Reply Quote 2
                              • SIamundefined
                                SIam
                                small update for the macro the first layer is not == 0 rather == null
                                it seems that the prusaslicer execute the macro first on the 1 layer so the pa value will never resets to 0
                                if job.layer == 1
                                	M572 D0 S{move.extruders[0].pressureAdvance + 0.020} ; increment
                                Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                Duet WiFi 1.02 or later + DueX5
                                RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                Duet WiFi Server: 1.26
                                Duet Web Control 3.4.0beta4 (2021-09-27)
                                  dc42 administrators @littlehobbyshop
                                  @littlehobbyshop said in Pressure advance Tuning like Klipper:
                                  That's because each object model value has its own default number of decimal places, which for pressure advance is 2. If you can show that a difference of less than 0.01 in pressure advance has a measurable effect, I will increase that to 3.
