    Duet 3 Mini 5+ sensorless homing configuration
    solved
    8
    42
    4.2k
    • floblerundefined
      flobler @dc42
      @dc42 I think I made progress.
      I am still only trying to home X for testing purposes. Here is the config: homex.g
      config.g
      Initially when first I power on the printer and then try to home X, it does result in a crash. But if I then press the emergency stop to end the crash and tell X to home again, X homes successfully (not elegant yet but it homes).
      Homing then works until I power cycle the printer or use the emergency stop. Once I do that I am back at the start. Homing X results in a crash, then I use the emergency stop and after that I can repeatedly home X successfully until I power cycle the printer or use the emergency stop again.
      I suspect this must have something to to with how I configured homex.g...
        You need to run the stealthChop tuning procedure first. You can do this is the homing files.This is what I suggest:
        1. Execute a tiny move (1 or 2 microsteps) away from the homing direction.
        2. Pause for 100ms using G4.
        3. Execute a small move away from the homing direction, e.g. 10mm.
        4. Execute the homing move.
        Don't forget to reduce current for the homing move (M913).
        floblerundefined 1 Reply Last reply Reply Quote 1
        • floblerundefined
          flobler @dc42
          @dc42 thanks, I am not sure if I am doing this correct though. So far I am still getting quite mixed results (stalling after power cycle before home point is reached and after that only homing correctly when the extruder is within 10mm of the homing location, and then also not all the time).
          I am trying the following (again only trying X for now):
          1. Set stall detection sensitivity and reduce V+H+T parameter
          2. Run tuning procedure and reduce motor current
          3. Homing move
          4. Reset sensitivity, V+H+T and return current to 100%
          The above is all my homex.g contains... Is there still something I am doing obviously wrong?
          • Sindariusundefined
            Sindarius
            I have been running sensorless homing on my Bear using the Mini5 since it was implemented a few weeks back.
            These are my settings in my config.g for the x axis
            M569 P0.0 S0 D3 V100                                         ; physical drive 0.0 goes forwards (x)
            M574 X1 S3 												; configure sensorless endstop for low end on X  (Sensorless)
            My homex.g
            M400 						; wait til stuff stops
            M574 X1 S3 			  ; use stall guard for endstops
            M913 X60 Y60  		; drop motor currents to 50%
            M201 X1000 Y1000	 ; reduce acceleration on X/Y to stop false triggers
            M915 X S0 R0 F0 H200	;  Sensitivity 4, don’t take action, don’t filter, 400steps/sec
            G91 											; set relative
            G1 H2 Z5 F1200
            G1 H1 X-250 F3000			 ; move left 250mm, stopping at the endstop
            G1 X10 F1200							; move away from end
            G1 H2 Z-5 F1200
            G90 												; back to absolute positioning
            M400										 ; wait again
            M913 X100 Y100 					 ; motor currents back to 100%
            M201 X500 Y500			 ; accel back to original
            M915 S63 X Y R0					 ; Disable Logging and lower stall detection
            Feel free to give it a shot and tweak it as needed. I have not spent a lot of time trying to fine tune it but it works well.
            • floblerundefined
              flobler @Sindarius
              @Sindarius thank you, I will try that! Are you using Pruse MK3 LDO motors?
              What part in your homex.g is covering the tuning procedure that David described above?
              Sindariusundefined 1 Reply Last reply Reply Quote 0
              • floblerundefined
                flobler
                Ok, so I tried this @Sindarius. It definitely works the best it has so far, thanks for sharing!
                A couple of things are not working yet though:
                1. After a power cycle, when I try to home the axis, it detects a home instantly, before the actual home position and then moves away 10mm. Each homing command moves the axis therefore 10mm further away from its homing position.
                2. After an emergency stop, I can get it to home correctly, that works as many times I want as long as I do not make any other moves in between and as long as I am within 10mm of the actual homing position. As soon as I move e.g. 100mm away from the homing position and I try to re-home then, I get a crash.
                  Sindarius @flobler
                  @flobler I am using a different set of motors for my bear build. Mine was done with some trial and error and tweaking settings I used on my Duet 2 wifi. I would only use what I have as a start point and incorporate dc42’s recommendations. Don’t trust my comments since the numbers won’t match everywhere.
                  • floblerundefined
                    flobler
                    In-cooperating all the above tips with some trial and error got it running. I simply had my current reduced way too much for it to work consistently, which was the last bit that needed adjusting.
                    This is configuration gives good results now homex.g
                    Thanks everyone for your help!
                    • floblerundefined
                      flobler
                      I thought I´d post a quick update for anyone reading this later:
                      I now realized that the bug described here was also contributing to my issues:
                      https://forum.duet3d.com/topic/21108/stall-detection-on-duet-3-mini
                      Taking this into account, it was a breeze finding a good value for sensitivity and getting sensorless homing to work smoothly.
                      Phaedruxundefined 1 Reply Last reply Reply Quote 4
                        Phaedrux Moderator @flobler
                        @flobler Thanks for letting us know it's working well for you. Can you share the config that worked?
                        • floblerundefined
                          flobler @Phaedrux
                          @phaedrux Sure! Sorry I must have missed your message.
                          I have "outsourced" the changes that need applying for homing (motor current, driver tuning, V parameter etc.) from the actual homing moves into a separate macro, so I can tweak this centrally.
                          Here is how I home all axes:
                          ; homeall.g
                          ; called to home all axes
                          M98 P"homing_modifications.g" ; applies necessary modifications for the homing moves
                          ; get Z out of the way
                          G91                    ; relative positioning
                          G1 H2 Z5 F1200         ; lift Z
                          M400                   ; wait for current moves to finish
                          ; home X
                          G1 H1 X5 F1200    ; move slowly away
                          G1 H1 X-255 F3600 ; move to X axis endstop and stop there (first pass)
                          G1 X5 F1200       ; go back a few mm
                          G1 H1 X-10 F3000  ; move to X axis endstop once more (second pass)
                          G1 X10 F1200      ; go back a few mm
                          ; home Y
                          G1 H1 Y5 F1200    ; move slowly away
                          G1 H1 Y-220 F3600 ; move to Y axis endstop and stop there (first pass)
                          G1 Y5 F1200       ; go back a few mm
                          G1 H1 Y-10 F3000  ; move to Y axis endstop once more (second pass)
                          G1 Y10 F1200      ; go back a few mm
                          ; home Z
                          G90                 ; absolute positioning
                          G1 X11.5 Y4.5 F6000 ; go to first probe point
                          G30                 ; home Z by probing the bed
                          G1 Z0.6 F500        ; move Z to origin
                          G1 Z1 F500          ; lift Z relative to current position
                          M400	     	    ; Wait for current moves to finish
                          M98 P"homing_modifications_reset.g" ; resets all modifications applied for the homing move
                          ; homing_modifications.g
                          ; tune motor drivers, set motor current and V parameter for homing moves
                          ; apply modifications
                          M569 P0.1 V10          ; reduce V to ensure stealthChop is enabled for X
                          M569 P0.2 V10          ; reduce V to ensure stealthChop is enabled for Y
                          M913 X70 Y70           ; drop motor current to 50%
                          G4 P100                ; wait 100ms
                          ; tune drivers
                          G1 H2 X0.2 Y0.2 F3000    ; power up motors to ensure they are not stalled
                          ; homing_modifications_reset.g
                          ; reset all homing modifications applied in homing_modifications.g
                          M913 X100 Y100          ; return current to 100% for X and Y
                          M569 P0.1 V2000         ; restore default V for X
                          M569 P0.2 V2000         ; restore default V for Y
                          Here is the configuration of the endstops/stallguard sensitivity:
                          M574 Y1 S3                                            ; configure sensorless endstop for low end on Y
                          M915 X S3 F0 H200 R0                                  ; set the X axis sensitivity
                          M915 Y S3 F0 H200 R0                                  ; set the Y axis sensitivity
                          This works very well for me. I might still tweak it here and there but everything will then be released on the Bear Project GitHub repo.
                          Hope that helps someone looking into this thread later down the line 🙂
                          • FelixHundefined FelixH referenced this topic
                          • FelixHundefined
                            FelixH
                            I am very thankful I found this thread because I was having the very same issue and, after some experimenting with your scripts it works better for me too now.
                            However, I do have a question: why there is no M915 command on these routines? I assume if ignored it assumes a certain value lie S3??
                            I mean, I tried with and without M915 and it works, so... I am confused, somehow
