    Duet 3 Mini 5+ sensorless homing configuration
    solved
    8
    42
    4.2k
    • gregsaunundefined
      gregsaun
      Thanks everyone for helping @flobler , he is working on an official Bear config for the Mini 5+ 🙂
      github.com/gregsaun - Papa Bear
      • floblerundefined
        flobler
        Yeah, thanks for the help everyone, really appreciated!
        I just wanted to add that I am using version 0.4 of the Mini 5+. I also tried all the above and sensorless homing did not work for me. Motor was operating in stealthChop.
        • floblerundefined
          flobler
          Actually, that combo got it to stall the first time I tried homing X. It stalled immediately when trying to move.
          homex.g config.g
          What is weird though is that it did not work afterwards again. I need to power cycle the printer (emergency stop did not do it) for it to work again and then again it only works on the first try. This worked 5/5 times so far.
            Bear in mind that you need to execute a tuning procedure when using stealthChop mode.
            floblerundefined 1 Reply Last reply Reply Quote 0
            • floblerundefined
              flobler
              Thanks! Just found the docs on that. Will apply and report back.
              • floblerundefined
                flobler @dc42
                @dc42 I think I made progress.
                I am still only trying to home X for testing purposes. Here is the config: homex.g
                config.g
                Initially when first I power on the printer and then try to home X, it does result in a crash. But if I then press the emergency stop to end the crash and tell X to home again, X homes successfully (not elegant yet but it homes).
                Homing then works until I power cycle the printer or use the emergency stop. Once I do that I am back at the start. Homing X results in a crash, then I use the emergency stop and after that I can repeatedly home X successfully until I power cycle the printer or use the emergency stop again.
                I suspect this must have something to to with how I configured homex.g...
                  You need to run the stealthChop tuning procedure first. You can do this is the homing files.This is what I suggest:
                  1. Execute a tiny move (1 or 2 microsteps) away from the homing direction.
                  2. Pause for 100ms using G4.
                  3. Execute a small move away from the homing direction, e.g. 10mm.
                  4. Execute the homing move.
                  Don't forget to reduce current for the homing move (M913).
                  floblerundefined 1 Reply Last reply Reply Quote 1
                  • floblerundefined
                    flobler @dc42
                    @dc42 thanks, I am not sure if I am doing this correct though. So far I am still getting quite mixed results (stalling after power cycle before home point is reached and after that only homing correctly when the extruder is within 10mm of the homing location, and then also not all the time).
                    I am trying the following (again only trying X for now):
                    1. Set stall detection sensitivity and reduce V+H+T parameter
                    2. Run tuning procedure and reduce motor current
                    3. Homing move
                    4. Reset sensitivity, V+H+T and return current to 100%
                    The above is all my homex.g contains... Is there still something I am doing obviously wrong?
                    • Sindariusundefined
                      Sindarius
                      I have been running sensorless homing on my Bear using the Mini5 since it was implemented a few weeks back.
                      These are my settings in my config.g for the x axis
                      M569 P0.0 S0 D3 V100                                         ; physical drive 0.0 goes forwards (x)
                      M574 X1 S3 												; configure sensorless endstop for low end on X  (Sensorless)
                      My homex.g
                      M400 						; wait til stuff stops
                      M574 X1 S3 			  ; use stall guard for endstops
                      M913 X60 Y60  		; drop motor currents to 50%
                      M201 X1000 Y1000	 ; reduce acceleration on X/Y to stop false triggers
                      M915 X S0 R0 F0 H200	;  Sensitivity 4, don’t take action, don’t filter, 400steps/sec
                      G91 											; set relative
                      G1 H2 Z5 F1200
                      G1 H1 X-250 F3000			 ; move left 250mm, stopping at the endstop
                      G1 X10 F1200							; move away from end
                      G1 H2 Z-5 F1200
                      G90 												; back to absolute positioning
                      M400										 ; wait again
                      M913 X100 Y100 					 ; motor currents back to 100%
                      M201 X500 Y500			 ; accel back to original
                      M915 S63 X Y R0					 ; Disable Logging and lower stall detection
                      Feel free to give it a shot and tweak it as needed. I have not spent a lot of time trying to fine tune it but it works well.
                      • floblerundefined
                        flobler @Sindarius
                        @Sindarius thank you, I will try that! Are you using Pruse MK3 LDO motors?
                        What part in your homex.g is covering the tuning procedure that David described above?
                        Sindariusundefined 1 Reply Last reply Reply Quote 0
                        • floblerundefined
                          flobler
                          Ok, so I tried this @Sindarius. It definitely works the best it has so far, thanks for sharing!
                          A couple of things are not working yet though:
                          1. After a power cycle, when I try to home the axis, it detects a home instantly, before the actual home position and then moves away 10mm. Each homing command moves the axis therefore 10mm further away from its homing position.
                          2. After an emergency stop, I can get it to home correctly, that works as many times I want as long as I do not make any other moves in between and as long as I am within 10mm of the actual homing position. As soon as I move e.g. 100mm away from the homing position and I try to re-home then, I get a crash.
                            Sindarius @flobler
                            @flobler I am using a different set of motors for my bear build. Mine was done with some trial and error and tweaking settings I used on my Duet 2 wifi. I would only use what I have as a start point and incorporate dc42’s recommendations. Don’t trust my comments since the numbers won’t match everywhere.
                            • floblerundefined
                              flobler
                              In-cooperating all the above tips with some trial and error got it running. I simply had my current reduced way too much for it to work consistently, which was the last bit that needed adjusting.
                              This is configuration gives good results now homex.g
                              Thanks everyone for your help!
                              • floblerundefined
                                flobler
                                I thought I´d post a quick update for anyone reading this later:
                                I now realized that the bug described here was also contributing to my issues:
                                https://forum.duet3d.com/topic/21108/stall-detection-on-duet-3-mini
                                Taking this into account, it was a breeze finding a good value for sensitivity and getting sensorless homing to work smoothly.
                                Phaedruxundefined 1 Reply Last reply Reply Quote 4
                                  Phaedrux Moderator @flobler
                                  @flobler Thanks for letting us know it's working well for you. Can you share the config that worked?
                                  • floblerundefined
                                    flobler @Phaedrux
                                    @phaedrux Sure! Sorry I must have missed your message.
                                    I have "outsourced" the changes that need applying for homing (motor current, driver tuning, V parameter etc.) from the actual homing moves into a separate macro, so I can tweak this centrally.
                                    Here is how I home all axes:
                                    ; homeall.g
                                    ; called to home all axes
                                    M98 P"homing_modifications.g" ; applies necessary modifications for the homing moves
                                    ; get Z out of the way
                                    G91                    ; relative positioning
                                    G1 H2 Z5 F1200         ; lift Z
                                    M400                   ; wait for current moves to finish
                                    ; home X
                                    G1 H1 X5 F1200    ; move slowly away
                                    G1 H1 X-255 F3600 ; move to X axis endstop and stop there (first pass)
                                    G1 X5 F1200       ; go back a few mm
                                    G1 H1 X-10 F3000  ; move to X axis endstop once more (second pass)
                                    G1 X10 F1200      ; go back a few mm
                                    ; home Y
                                    G1 H1 Y5 F1200    ; move slowly away
                                    G1 H1 Y-220 F3600 ; move to Y axis endstop and stop there (first pass)
                                    G1 Y5 F1200       ; go back a few mm
                                    G1 H1 Y-10 F3000  ; move to Y axis endstop once more (second pass)
                                    G1 Y10 F1200      ; go back a few mm
                                    ; home Z
                                    G90                 ; absolute positioning
                                    G1 X11.5 Y4.5 F6000 ; go to first probe point
                                    G30                 ; home Z by probing the bed
                                    G1 Z0.6 F500        ; move Z to origin
                                    G1 Z1 F500          ; lift Z relative to current position
                                    M400	     	    ; Wait for current moves to finish
                                    M98 P"homing_modifications_reset.g" ; resets all modifications applied for the homing move
                                    ; homing_modifications.g
                                    ; tune motor drivers, set motor current and V parameter for homing moves
                                    ; apply modifications
                                    M569 P0.1 V10          ; reduce V to ensure stealthChop is enabled for X
                                    M569 P0.2 V10          ; reduce V to ensure stealthChop is enabled for Y
                                    M913 X70 Y70           ; drop motor current to 50%
                                    G4 P100                ; wait 100ms
                                    ; tune drivers
                                    G1 H2 X0.2 Y0.2 F3000    ; power up motors to ensure they are not stalled
                                    ; homing_modifications_reset.g
                                    ; reset all homing modifications applied in homing_modifications.g
                                    M913 X100 Y100          ; return current to 100% for X and Y
                                    M569 P0.1 V2000         ; restore default V for X
                                    M569 P0.2 V2000         ; restore default V for Y
                                    Here is the configuration of the endstops/stallguard sensitivity:
                                    M574 Y1 S3                                            ; configure sensorless endstop for low end on Y
                                    M915 X S3 F0 H200 R0                                  ; set the X axis sensitivity
                                    M915 Y S3 F0 H200 R0                                  ; set the Y axis sensitivity
                                    This works very well for me. I might still tweak it here and there but everything will then be released on the Bear Project GitHub repo.
                                    Hope that helps someone looking into this thread later down the line 🙂
                                    • FelixHundefined FelixH referenced this topic
                                    • FelixHundefined
                                      FelixH
                                      I am very thankful I found this thread because I was having the very same issue and, after some experimenting with your scripts it works better for me too now.
                                      However, I do have a question: why there is no M915 command on these routines? I assume if ignored it assumes a certain value lie S3??
                                      I mean, I tried with and without M915 and it works, so... I am confused, somehow
