    stepper precision
    3D Printing General Chat
    6.0k
    • arhiundefined
      arhi
      I just wrote a huge post and ff crashed when I drag-dropped images to it so 😞 .. uh .. from scratch .. here are images first
      • arhiundefined
        arhi
        idea came from here: https://forum.duet3d.com/topic/20582/stepper-precision-5
        I borrowed some 16bit encoder from a client to do a test, long story short @mendenmh suggested a solution with python library and it worked to talk to the encoder
        encoder and motor are attached with painters tape enforced with zip ties
        rpi (pin12 step, pin13 direction) with a hat that has 74hct14 to up the signals to 5V and tmc2208 on header (default factory config with ms0 and ms1 connected to 5v)
        • arhiundefined
          arhi
          GSD file (modified as full GSD is not supported by the library)
          #Profibus_DP
          GSD_Revision = 3
          Vendor_Name           = "Kuebler GmbH"
          Model_Name            = "Sendix Singleturn Encoder 58X8 "
          Revision              = "1.2"
          Ident_Number          = 0x5868
          OrderNumber           = "8.58X8.XX3X.3102"
          Protocol_Ident        = 0
          Station_Type          = 0
          ;FMS_supp              = 0
          Hardware_Release      = "1.0"
          Software_Release      = "2.2"
          ;DP_Encoder_profile_version                 = "1.1"
          ;DP_Encoder_class                           = 2
          ;DP_Encoder_manufacturer_specific_functions = 1
          9.6_supp              = 1
          19.2_supp             = 1
          45.45_supp            = 1
          93.75_supp            = 1
          187.5_supp            = 1
          500_supp              = 1
          1.5M_supp             = 1
          3M_supp               = 1
          6M_supp               = 1
          12M_supp              = 1
          MaxTsdr_9.6           = 15
          MaxTsdr_19.2          = 15
          MaxTsdr_45.45         = 15
          MaxTsdr_93.75         = 15
          MaxTsdr_187.5         = 15
          MaxTsdr_500           = 15
          MaxTsdr_1.5M          = 25
          MaxTsdr_3M            = 50
          MaxTsdr_6M            = 100
          MaxTsdr_12M           = 200
          Redundancy            = 0
          Repeater_Ctrl_Sig     = 0
          24V_Pins              = 0
          Implementation_Type   = "SPC3"
          Bitmap_Device         = "5868_PB"
          ;Bitmap_Diag           = "5868_PBD"
          ; *** Slave-Specification ***
          Slave_Family          = 7
          Freeze_Mode_supp      = 1
          Sync_Mode_supp        = 1
          Auto_Baud_supp        = 1
          ;Set_Slave_Add_Supp    = 1
          Min_Slave_Intervall   = 1
          Modular_Station       = 1
          Max_Module            = 2
          Modul_Offset          = 1
          Max_Input_Len         = 8
          Max_Output_Len        = 4
          Max_Data_Len          = 12
          Max_User_Prm_Data_Len = 10
          Max_Diag_Data_Len     = 57
          ; *** Parameter Texts ***
          PrmText = 1
          Text(0) = "Increasing clockwise (0)"
          Text(1) = "Increasing counter clockwise (1)"
          EndPrmText
          PrmText = 2
          Text(0) = "Disabled"
          Text(1) = "Enabled"
          EndPrmText
          PrmText = 3
          Text(0) = "Standard (MUR + TMR)"
          Text(1) = "Alternative (NDR + TMR)"
          EndPrmText
          ; *** Parameters ***
          ExtUserPrmData = 1 "Code sequence"
          ;Bit(0) 0 0-1
          Prm_Text_Ref = 1
          EndExtUserPrmData
          ExtUserPrmData = 2 "Class 2 functionality"
          ;Bit(1) 1 0-1
          Prm_Text_Ref = 2
          EndExtUserPrmData
          ExtUserPrmData = 3 "Scaling function control"
          ;Bit(3) 1 0-1
          Prm_Text_Ref = 2
          EndExtUserPrmData
          ExtUserPrmData = 4 "Scaling type"
          ;Bit(7) 0 0-1
          Prm_Text_Ref = 3
          EndExtUserPrmData
          ExtUserPrmData = 5 "MUR(Standard) / NDR(Alternative)"
          ;Unsigned32 65536 1-65536
          EndExtUserPrmData
          ExtUserPrmData = 6 "TMR"
          ;Unsigned32 268435456 1-268435456
          EndExtUserPrmData
          ; *** Module Definition List ***
          Module = "32 Bit Input/Output, consistent"   0xF1
          Ext_Module_Prm_Data_Len = 10
          Ext_User_Prm_Data_Const(0) = 0x00,0x0A,0x00,0x01,0x00,0x00,0x10,0x00,0x00,0x00
          Ext_User_Prm_Data_Ref(1) = 1 ; Code sequence
          Ext_User_Prm_Data_Ref(1) = 2 ; Class 2 functionality
          Ext_User_Prm_Data_Ref(1) = 3 ; Scaling function control
          Ext_User_Prm_Data_Ref(1) = 4 ; Scaling type
          Ext_User_Prm_Data_Ref(2) = 5 ; MUR (Standard) / NDR (Alternative)
          Ext_User_Prm_Data_Ref(6) = 6 ; TMR
          EndModule
          Module = "32 Bit Input, consistent"          0xD1
          EndModule
          Module = "16 Bit Input/Output, consistent"    0xF0
          EndModule
          Module = "16 Bit Input, consistent"           0xD0
          EndModule
          Module = "MUR=13 Bit Singleturn"             0xF1
          Ext_User_Prm_Data_Const(0) = 0x00,0x0A,0x00,0x00,0x20,0x00,0x00,0x00,0x20,0x00
          EndModule
          Module = "MUR=16 Bit Singleturn"             0xF1
          Ext_User_Prm_Data_Const(0) = 0x00,0x0A,0x00,0x01,0x00,0x00,0x00,0x01,0x00,0x00
          EndModule
          Module = "Speed (RPM) = 16 Bit Input"         0xD0
          EndModule
          Module = "Speed (Steps/sec) = 32 Bit Input"   0xD1
          EndModule
          • arhiundefined
            arhi
            config file
            arhi_readencoder.conf
            [PROFIBUS]
            debug=0
            [PHY]
            type=serial
            dev=/dev/ttyUSB0
            rtscts=False
            dsrdtr=False
            baud=19200
            [FDL]
            [DP]
            master_class=2
            master_addr=125
            [SLAVE_0]
            name=encoder
            addr=63
            gsd=encoder.gsd
            sync_mode=0
            freeze_mode=0
            group_mask=1
            watchdog_ms=0
            ;module_0=MUR=13 Bit Singleturn
            module_0=MUR=16 Bit Singleturn
            output_size=4
            input_size=8
            • arhiundefined
              arhi
              main code
              #!/usr/bin/env python3
              import pyprofibus
              import time
              import RPi.GPIO as GPIO
              def main(watchdog=None):
                      master = None
                      try:
                              config = pyprofibus.PbConf.fromFile("arhi_readencoder.conf")
                              master = config.makeDPM()
                              outData = {}
                              for slaveConf in config.slaveConfs:
                                      slaveDesc = slaveConf.makeDpSlaveDesc()
                                      master.addSlave(slaveDesc)
                                      outData[slaveDesc.slaveAddr] = bytearray((0x00, ))
                              master.initialize()
                              GPIO.setmode(GPIO.BCM)
                              GPIO.setup(12, GPIO.OUT)
                              GPIO.setup(13, GPIO.OUT)
                              GPIO.output(12, GPIO.LOW)
                              GPIO.output(13, GPIO.LOW)
                              roundandroundwego = False
                              firstread = True
                              startvalue = 0
                              totalsteps = 0
                              while not roundandroundwego:
                                      done = False
                                      counter = 0
                                      average = 0
                                      while not done:
                                              outData[slaveDesc.slaveAddr] = bytearray((0x00,0x00,0x00,0x00, ))
                                              for slaveDesc in master.getSlaveList():
                                                      slaveDesc.setOutData(outData[slaveDesc.slaveAddr])
                                              handledSlaveDesc = master.run()
                                              if handledSlaveDesc:
                                                      inData = handledSlaveDesc.getInData()
                                                      if inData is not None:
                                                              print(inData[3] + inData[2]*256)
                                                              average = average + inData[3] + inData[2]*256
                                                              counter = counter + 1
                                                              if (counter > 9):
        done = True
        average = average / 10
                                              if watchdog is not None:
                                                      watchdog()
                                      print("AVERAGE: ", totalsteps, ", ", average,  flush=True)
                                      # did we make full circle
                                      if firstread:
                                              startvalue = average
                                              firstread = False
                                      else:
                                              if abs(startvalue - average) < 20:
                                                      roundandroundwego = True
                                      # now do a step
                                      GPIO.output(12, GPIO.HIGH)
                                      time.sleep(0.0001)
                                      time.sleep(1)
                                      totalsteps = totalsteps + 1
                                      if totalsteps > 400*32:
                              totalsteps = totalsteps - 1
                              print("Total steps: ", totalsteps);
                      except pyprofibus.ProfibusError as e:
                              print("Terminating: %s" % str(e))
                              return 1
                      finally:
                              GPIO.cleanup()
                              if master:
                                      master.destroy()
                      return 0
              if __name__ == "__main__":
                      import sys
                      sys.exit(main())
              • arhiundefined
                arhi
                first test with e3d's "Super Whopper Motor" MOTECH MT-1705HS200AE
                if you look at the code after the step there is delay(1), 1 second delay, I initially started with delay(0.1) so 100ms delay and I seen ton of vibrations ?!?!? even with microstepping, very slow movement, I see vibrations. If you look at the code, I read encoder 10 times, I read it very slow (19200bps), and I see vibrations after 100ms of delay after step before reading?!?!?!?
                example:
                58593
                58592
                58592
                58592
                58592
                58591
                58591
                58591
                58591
                58591
                AVERAGE:  1 ,  58591.6
                58576
                58575
                58575
                58575
                58574
                58574
                58574
                58574
                58574
                58574
                AVERAGE:  2 ,  58574.5
                58557
                58556
                58555
                58555
                58555
                58554
                58554
                58554
                58554
                58554
                AVERAGE:  3 ,  58554.8
                58537
                58537
                58536
                58536
                58535
                58535
                58535
                58535
                58535
                58535
                AVERAGE:  4 ,  58535.6
                It's not "that terrible" but cmon, 100ms delay, ZERO LOAD, vibrations... not expected....
                When I up the delay to 1sec the motor "calms down" and there are no vibrations, example:
                23335
                23335
                23335
                23335
                23335
                23335
                23335
                23335
                23335
                23335
                AVERAGE:  1 ,  23335.0
                23312
                23312
                23312
                23312
                23312
                23312
                23312
                23312
                23312
                23312
                AVERAGE:  2 ,  23312.0
                23287
                23287
                23287
                23287
                23287
                23287
                23287
                23287
                23287
                23287
                AVERAGE:  3 ,  23287.0
                23264
                23264
                23264
                23264
                23264
                23264
                23264
                23264
                23264
                23264
                AVERAGE:  4 ,  23264.0
                • arhiundefined
                  arhi
                  few raw files attached (zip still not allowed ?!?!?!)
                  2208-SuperWhopper-1000ms-singleturn-run2.txt
                  2208-SuperWhopper-1000ms-singleturn-run1.txt
                  2208-SuperWhopper-100ms-multiturn.zip.renametozip.pdf
                  • alankilianundefined
                    alankilian
                    In my experience doing this kind of thing, you need to use a bellows coupling between the motor and encoder to get reading that will be useful for your purpose.
                    Painters tape and zip ties will introduce all kinds of strange angle changes between those two mechanical parts that do not represent the actual position of the stepper motor shaft.
                    arhiundefined 1 Reply Last reply Reply Quote 0
                    • arhiundefined
                      arhi @alankilian
                      @alankilian said in stepper precision:
                      bellows coupling
                      I ordered new couplings but not sure if they would arrive before I need to return the encoder. bellows coupling actually ring more than painters tape, painters tape is very stiff, it behaves for this type of testing (no load!! only the very low inertia of the encoder) perfect. For e.g. I'm not able to move a shaft without encoder catching and a very fast stop (pliers) and no ringing on the encoder... anyhow running multiple turns you see it's pretty repeatable even tape
                        alankilian
                        Try gathering data for one-turn slowly clockwise and one turn slowly counterclockwise.
                        If the data is within your error expectations, you have a good system.
                        I predict (and I may well be wrong) when you compare those two datasets you will see great variation from one to another and that tells you that your measurements are as accurate as the difference between those to readings.
                        Another test is to move 180-degrees, take a reading, move 180-degrees the other direction, take a reading and do that back-and-forth movement/reading for many samples.
                        When you compare multiple reading at the same step location, you will see variation. This also is a measurement of the variation in your measuring setup.
                        • arhiundefined
                          arhi @alankilian
                          already done 🙂 the data is spot on, +-0.0 🙂 comparing directions
                            alankilian
                            What's the angular resolution if your encoder?
                            • arhiundefined
                              arhi @alankilian
                              @alankilian 360/65535 degrees
                                alankilian
                                Well, all I can say is you are getting results that do not match with my experience in such situations.
                                Being able to rotate 180-degrees and repeatable read within 0.005-degree is some kind of black magic indeed. You are a master.
                                • arhiundefined
                                  arhi @alankilian
                                  😄 we'll see how it goes on the "bigger sample" I just let it go 400 steps forwards and 400 steps backwards and store all the data and spit out differences... would be much easier if I knew python (darn thing don't even have proper arrays) ... as for 180degrees back forth that one I did not test ... I just let it run 3200 steps forward and 3200 steps backwards and compared two greps ... let's see how the aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa sh%$#%^# forgot to pipe it into file 😞 .. need to run it again ... brb
                                  mendenmhundefined 1 Reply Last reply Reply Quote 0
                                  • mendenmhundefined
                                    mendenmh @arhi
                                    @arhi As to your comment about array in python: the numpy package is the default scientific array package. It is a lot like matlab. It is extraordinarily powerful. The python 'array' class, and python's own lists and tuples, are for entirely different purposes than handling what you want.
                                    • arhiundefined
                                      arhi @mendenmh
                                      @mendenmh I don't plan to learn python and it's libraries today (I hope never), dunno why it was invented and how the hack it gained popularity but... I'll make it work somehow to get this done.... anyone want to send some code for me to run I'll be happy to 😄 .. my example that's attached is enough for anyone to know how to read the data from encoder and move the motor, so I'll run the code provided and report back results 😄 if anyone is interested ...
                                      attm waiting for this to finish:
                                      import pyprofibus
                                      import time
                                              master = None
                                              forwarddata = []
                                              backwardsdata = []
                                              #poserem se na jezik
                                              for i in range(410):
                                                      forwarddata.append(0);
                                                      backwardsdata.append(0);
                                              try:
                                                      outData = {}
                                                      master.initialize()
                                                      totalsteps = 0
                                                      for i in range(400):
                                                              done = False
                                                              counter = 0
                                                              average = 0
                                                              while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                              forwarddata[totalsteps] = average;
                                                              # now do a step
                                                              time.sleep(0.0001)
                                                              time.sleep(1)
                                                      GPIO.output(13, GPIO.HIGH)
                                                              done = False
                                                              counter = 0
                                                              average = 0
                                                              while not done:
        if (counter > 9):
        done = True
        watchdog()
                                                              backwardsdata[totalsteps] = average;
                                                              # now do a step
                                                              time.sleep(0.0001)
                                                              time.sleep(1)
                                                      for i in range( len(backwardsdata) ):
                                                              print(i, forwarddata[i], backwardsdata[i], forwarddata[i] - backwardsdata[i])
                                                      return 1
                                              finally:
                                                      GPIO.cleanup()
                                                      if master:
                                                              master.destroy()
                                              return 0
                                              import sys
                                              sys.exit(main())
                                        alankilian
                                        I'm having a little trouble analyzing your data.
                                        It looks like you are taking 3201 samples every revolution when I look at the .zip file you uploaded.
                                        I didn't take a look at the Python code since I'm also not a Python expert.
                                        Take a look at when your encoder flips over to it's minimum count and see that there seem to be ( to my eyes) 3201 samples between them.
                                        That makes it a little difficult to analyze.
                                        I'll take a look at your next data set after you upload it.
                                        arhiundefined 2 Replies Last reply Reply Quote 0
                                        • arhiundefined
                                          arhi @alankilian
                                          @alankilian going forward then backward and recording all steps was awesome suggestion ... data is ugly 😞
                                          Untitled 1.ods
                                          • arhiundefined
                                            arhi @alankilian
                                            @alankilian
                                            the "multiturn" file is stepping for a while (whole night) going forward. encoder goes up to 65535 and then to 0 (it is absolute encoder) so it allow multiturn but records only positions inside one revolution
                                            the "single turn" have 2 reasons to figure out it's full turn, one is to read the "similar" (20 less difference) position from the first one it reads when it start, and second reason is if it makes 400*32 steps (I assume 1/32 microstepping .9 degree motor ) .. first run it made 3199 steps in second 3200 steps. Motor is 1.8 degree and microstepping is 1/16 so 3200 steps is ok.
                                            Now, you see "more" data, that's cause I do: Step, read encoder 10 times (output all 10), calc average of those 10 and display average value (add them all together and divide by 10). So for every step there is 11 rows in the txt file...
