    mesh leveling help
    410
    • usas12undefined
      usas12
      Is someone able to tell me how to set up bed compensation with the Z endstop switch that comes mounted on the E3d toolchanger. All i've been able to find is the G29 S0 code to use a probe. Please dumb your answers down, i'm new at his lol. I have the duet 2 with RR 3.2 firmware. Thanks for your help.
      Regards
        A noob with a tool changer? Jumping into the deep end to learn how to swim?
        To use the switch as a probe you'd have to configure your M558 to use that switch as the probe.
        Where is that switch wired to? You'll need to know the pin name.
        M558 P5 C"^zprobe.in" H5 F120 T6000
        P5 is for switch probe type
        C is the pin name to watch for trigger. That's where your switch is wired to. In this example it's using the zprobe.in pin, but you're switch probably connected to something else.
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M558_Set_Z_probe_type
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        usas12undefined 1 Reply Last reply Reply Quote 0
        • usas12undefined
          usas12
          Thanks for the reply, Yep straight to the deep end for me, thank god for forums. It's in the "Z stop"
          • usas12undefined
            usas12 @Phaedrux
            @Phaedrux
            I have this
            M574 X1 Y1 S3 ; Set X / Y endstop stall detection
            M574 Z1 S1 P"zstop" ; Set Z endstop probe
            M558 P7 X0 Y0 Z2 H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
            G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
            M557 X10:290 Y20:180 S40 ; Define mesh grid
            on a G29 S0 call I'm getting the Error: z probe 0 not found.
            The switch works fine when homing
            I've tried adding
            M558 P7 C"^Zstop" H5 F120 T6000
            Same result: z probe 0 not found.
            • o_lampeundefined
              o_lampe @usas12
              @usas12 said in mesh leveling help:
              I've tried adding
              Maybe it's zstop**.in**?
              Just guessing...
              • usas12undefined
                usas12
                found out that v3+ firmware cannot have a Zstop work as a end stop and a probe.
                So I tried this
                M574 X1 S3 ; Set X endstop stall detection
                M574 Y1 S3 ; Set Y endstop stall detection
                M574 Z0 P"nil" ; No Z endstop @used by DC42 using G30 homing
                M558 P8 C"zstop" H5 F120 T10000 A5 S0.01 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds @DC42
                G31 Z0 ; Set Z probe trigger value, offset and trigger height
                M557 X4:292 Y4:185 S16:15 ; Set Z probe: Define mesh grid
                M574 C1 S3 ; Stall detect coupler at low end of its range
                Still getting the "z probe 0 not found" error message
                  jay_s_uk
                  Can you confirm you are running RRF3 by sending and posting the output of M115.
                  Also remove
                  as its not required
                  usas12undefined 1 Reply Last reply Reply Quote 1
                  • usas12undefined
                    usas12
                    This post is deleted!
                    • usas12undefined
                      usas12 @jay_s_uk
                        jay_s_uk
                        @usas12
                        If you run
                        M98 P"config.g"
                        Any errors should be shown.
                        Can you also post your full config file.
                        • usas12undefined
                          usas12 @jay_s_uk
                          @jay_s_uk said in mesh leveling help:
                          M98 P"config.g"
                          G21 ; Work in millimetres
                          ; Read https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                          M550 P"ToolChanger" ; Set machine name
                          M552 S1 ; Enable Networking
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S0 ; Disable FTP
                          M586 P2 S0 ; Disable Telnet
                          M667 S1 ; Select CoreXY mode
                          M574 Z1 S2 ; Set Z endstop probe
                          ; Drive direction
                          M569 P0 S0 ; Drive 0 X
                          M569 P1 S0 ; Drive 1 Y
                          M569 P2 S1 ; Drive 2 Z
                          M569 P3 S0 ; Drive 3 E0
                          M569 P4 S0 ; Drive 4 E1
                          M569 P5 S1 ; Drive 5 E2
                          M569 P6 S1 ; Drive 6 E3
                          M569 P7 S0 ; Drive 7 COUPLER
                          M569 P8 S0 ; Drive 8 UNUSED
                          M569 P9 S0 ; Drive 9 UNUSED
                          M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
                          M208 X-35:328.5 Y-49:243 Z0:300 C0:260 S0 ; Set axis maxima & minima
                          M350 C8 I0 ; Configure microstepping without interpolation
                          M350 X16 Y16 Z16 E16:16:16:16 I1 ; Configure microstepping with interpolation
                          M92 X100 Y100 Z1600 C100 E834:834:834:834 ; Set steps per mm
                          M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
                          M201 X6000 Y6000 Z400 C400 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
                          M906 X2000 Y2000 Z1330 C400 E1680:1680:1680:1680 I30 ; Set motor currents (mA) and motor idle factor in percent
                          M84 S120 ; Set idle timeout
                          ;Stall Detection
                          M915 C S5 F0 H200 ; Coupler
                          ;Stall Detection
                          M915 X Y S5 F0 H400 ; X / Y Axes
                          M305 P0 T100000 B4725 C7.06e-8 ; Set thermistor
                          M143 H0 S225 ; Set temperature limit for heater 0 to 225C
                          M305 S"T0" P1 T100000 B4725 C7.06e-8 ; Set thermistor
                          M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                          M305 S"T1" P2 T100000 B4725 C7.06e-8 ; Set thermistor
                          M143 H2 S300 ; Set temperature limit for heater 2 to 300C
                          M305 S"T2" P3 T100000 B4725 C7.06e-8 ;Set thermistor
                          M143 H3 S300 ; Set temperature limit for heater 3 to 300C
                          M305 S"T3" P4 T100000 B4725 C7.06e-8 ; Set thermistor
                          M143 H4 S300 ; Set temperature limit for heater 4 to 300C
                          M563 P0 S"T0" D0 H1 F2 ; Define tool 0
                          G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
                          G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C
                          M563 P1 S"T1" D1 H2 F4 ; Define tool 1
                          G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
                          G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C
                          M563 P2 S"T2" D2 H3 F6 ; Define tool 2
                          G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
                          G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C
                          M563 P3 S"T3" D3 H4 F8 ; Define tool 3
                          G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
                          G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C
                          M106 P0 S0 ; UNUSED
                          M106 P1 S255 H1 T70 ; T0 HE
                          M106 P2 S0 ; T0 PCF
                          M106 P3 S255 H2 T70 ; T1 HE
                          M106 P4 S0 ; T1 PCF
                          M106 P5 S255 H3 T70 ; T2 HE
                          M106 P6 S0 ; T2 PCF
                          M106 P7 S255 H4 T70 ; T3 HE
                          M106 P8 S0 ; T3 PCF
                          M593 F50 ; cancel ringing at 50Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
                          ;M376 H15 ; bed compensation taper
                          ;tool offsets
                          ; !ESTIMATED! offsets for:
                          ; V6-tool: X-9 Y39 Z-5
                          ; Volcano-tool: X-9 Y39 Z-13.5
                          ; Hemera-tool: X-37.5 Y43.5 Z-6
                          G10 P0 X-9 Y39 Z-5 ; T0
                          G10 P1 X-9 Y39 Z-5 ; T1
                          G10 P2 X-9 Y39 Z-5 ; T2
                          G10 P3 X-9 Y39 Z-5 ; T3
                          ;deselect tools
                          T-1
                          ;M572 D0 S0.2 ; pressure advance T0
                          ;M572 D1 S0.2 ; pressure advance T1
                          ;M572 D2 S0.2 ; pressure advance T2
                          ;M572 D3 S0.2 ; pressure advance T3
                          M501; load config-override.g
                            jay_s_uk
                            @usas12
                            The config you have posted is for RRF2.
                            I suggest you look at these files https://github.com/Duet3D/RRF-machine-config-files/tree/master/E3D_Tool_Changer/dc42-wifi-centreZero-quadTitan
                            • usas12undefined
                              usas12 @jay_s_uk
                              @jay_s_uk WOW that made a big difference, Thank you!
                                Phaedrux Moderator @o_lampe
                                @o_lampe said in mesh leveling help:
                                I've tried adding
                                Just guessing...
                                Nope. zstop is correct in this case. https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names
