Solved DWC not opening
I'm not able to open DWC. I was using DHCP. duettest.loacl/ and myPrinterName.local/ didn't work . I tried so even after setting MAC address.
Then I shifted to static IP.
I tried:
M552 P192.168.1.119 ; (0 = DHCP)
M554 P192.168.1.1 ; Gateway
M553 P255.255.255.0 ; Netmask
but it didn't work.So i Tried following:
my config.g :
M540 BE:7B:50:3E:51:37
M552 S1
M552 P192.168.42.187
M553 P192.168.42.129
M554 P255.255.255.0I tried opening DWC using IP i.e. 192.168.42.187 , duettest.local/ , myPrinterName.local/ .but nothing worked for me.
Even after setting a fixed IP , I/m getting this output on executing M552:
why is actual IP : 0.0.0.0 ????
I've connected my duet board with my Pc via USB cable. Nothing else is connected to board right now but SD card . My PC is getting net via USB tethering from my mobile.
I've kept latest DWC version in /www SD too.
Printer type : cartesian
RRF version-3.2
Board: Duet 3 MB 6HC -
when setting the static IP address, did you disable and then re-enable the network interface?
i.e.M552 S-1 M552 S1
If that fails, try setting the duet up in access point mode to determine everything is functioning correctly -
@jay_s_uk yup .I did:
M552 S0
M552 P<my ip>
M552 S1above didin't work too.
I've tried everything even after connecting duet with ethernet... But nothing seems to work for me!! -
@User3D said in DWC not opening:
Because no Ethernet link has been established. If you run M122 on the Duet, it will probably show "Establishing link" as the network connection status.
What exactly are you connecting to? A switch? Router?
When you had the Duet set to obtain a DHCP address, what did it give you?
Were you able to ping that address?
On your PC it looks like you're in subnet 192.168.42, but is the Duet on the same subnet?
If you manually set an IP on the duet and on your PC and connect them together port to port are you then able to reach DWC by IP address?
@dc42 that i figured out yesterday only.
even after connecting ethernet it didn't work!! -
- connected to a switch
- Ping failed!
How do I check if my Duet is on same subnet??
@Phaedrux said in DWC not opening:
I tried setting manual IP on my PC.
ipconfig confirms that Pc is running on set IP.
config.g:
on M552 :
ping failed!! DWC still not opening using 192.168.1.100....
I don't know what i'm missing here!
Do you get any lights on the duet ethernet port when connected directly to your PC?
When connected like that can you also connect via USB terminal and send M122 and post the results?
Try another cable?
When I connect duet via USB and nothing else but SD card is connected then ethernet light doesn't glow. It glows only after ethernet is connected. I am able to communicate using YAT.
Try another cable?
YUP! Tried the same with different cable on different PC. STILL NOT OPENING.
Still haven't seen an M122 result yet.
@Phaedrux
=== Diagnostics ===<LF>RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
<LF>Board ID: 08DJM-956BA-NA3TN-6J1DJ-3S86L-1TB6T<LF>Used output buffers: 1 of 40 (3 max)<LF>=== RTOS ===<LF>Static ram: 149788<LF>Dyna
mic ram: 92908 of which 28 recycled<LF>Never used RAM 116108, free system stack 190 words<LF>Tasks: NETWORK(ready,408) ETHERNE
T(blocked,194) HEAT(blocked,188) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,360) TMC(blocked,65) MAI
N(running,1134) IDLE(ready,19)<LF>Owned mutexes: USB(MAIN)<LF>=== Platform ===<LF>Last reset 00:03:05 ago, cause: power up<LF>Last s
oftware reset details not available<LF>Error status: 0x00<LF>Aux0 errors 0,0,0<LF>Aux1 errors 0,0,0<LF>MCU temperature: min 21.7, cu
rrent 35.0, max 35.2<LF>Supply voltage: min 0.1, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0, pow
er good: no<LF>12V rail voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0<LF>Driver 0: position 0, ok, reads 0,
writes 0 timeouts 0, SG min/max 0/0<LF>Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0<LF>Driver 2: pos
ition 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0<LF>Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min
/max 0/0<LF>Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0<LF>Driver 5: position 0, ok, reads 0, write
s 0 timeouts 0, SG min/max 0/0<LF>Date/time: 1970-01-01 00:00:00<LF>Slowest loop: 5.20ms; fastest: 0.06ms<LF>=== Storage ===<LF>Free
file entries: 10<LF>SD card 0 detected, interface speed: 25.0MBytes/sec<LF>SD card longest read time 3.1ms, write time 0.0ms,
max retries 0<LF>=== Move ===<LF>DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000<LF>=== MainDDARi
ng ===<LF>Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1<LF>===
AuxDDARing ===<LF>Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA sta
te -1<LF>=== Heat ===<LF>Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1<LF>=== GCodes ===<LF>Segment
s left: 0<LF>Movement lock held by null<LF>HTTP is idle in state(s) 0<LF>Telnet is idle in state(s) 0<LF>File is idle in state(s) 0<LF>
USB is ready with "M122" in state(s) 0<LF>Aux is idle in state(s) 0<LF>Trigger is idle in state(s) 0<LF>Queue is idle in state(s)
0<LF>LCD is idle in state(s) 0<LF>SBC is idle in state(s) 0<LF>Daemon is idle in state(s) 0<LF>Aux2 is idle in state(s) 0<LF>Autopause
is idle in state(s) 0<LF>Code queue is empty.<LF>=== Network ===<LF>Slowest loop: 0.19ms; fastest: 0.02ms<LF>Responder states: HTTP
(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions<LF>HTTP sessions: 0 of 8<LF>- E
thernet -<LF>State: active<LF>Error counts: 0 0 1 0 0<LF>Socket states: 2 2 2 2 2 2 0 0<LF>=== Filament sensors ===<LF>Extruder 0 senso
r: ok<LF>=== CAN ===<LF>Messages queued 735, send timeouts 1662, received 0, lost 0, longest wait 0ms for reply type 0, free b
uffers 47<LF>ok<LF> -
Change your line feed settings in YAT and try again
Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
@Phaedrux
M122
Static ram: 149788
Dynamic ram: 92908 of which 28 recycled
Tasks: NETWORK(ready,408) ETHERNET(blocked,194) HEAT(blocked,188) CanReceiv(blocked,927) CanSender(blocked,371) CanClock
(blocked,360) TMC(blocked,65) MAIN(running,1134) IDLE(ready,19)
Last reset 00:01:05 ago, cause: power up
Last software reset details not available
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU temperature: min 20.3, current 32.8, max 32.8
Supply voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
=== Storage ===
Free file entries: 10
SD card longest read time 3.1ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Queue is idle in state(s) 0
=== Network ===
Slowest loop: 0.16ms; fastest: 0.02ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 0 of 8- Ethernet -
State: active
Extruder 0 sensor: ok
=== CAN ===
Messages queued 255, send timeouts 583, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
ok
- Ethernet -
So when you were using DHCP with a router, was the Duet pulling a DHCP address?
@Phaedrux
This is happeningM552 S0 Network stopped ok M552 P0.0.0.0 S1 ok M552 Ethernet is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0 ok
Hiiiii @Phaedrux ,
Issue is resolved. It was internal network issue. For security purposes, It was blocked by the administrator. I am grateful of your efforts. Thank You so much! -
Glad you were able to figure it out.
