    M307 in startup gcode gives heater over-powered warnings
    1.7k
    • DanS79undefined
      DanS79 @Veti
      @Veti said in M307 in startup gcode gives heater over-powered warnings:
      update to 3.2 and you wont get the message
      What does 3.2 do to make them go away?
      • Vetiundefined
        Veti
        introduce a new heater tuning
        DanS79undefined 1 Reply Last reply Reply Quote 0
        • DanS79undefined
          DanS79 @Veti
          That seems unlikely. If it was related to the algorithm, i'd expect it to complain no matter how the parameters where loaded.
          • DanS79undefined
            DanS79
            For @dc42 or any of the other developers you might look at this.
            Board: Duet WiFi 1.02 or later + DueX5
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
            Duet WiFi Server Version: 1.23
            • A Former User?
              A Former User @DanS79
              @DanS79 said in M307 in startup gcode gives heater over-powered warnings:
              Additionally If I remove the M307 from my startup gcode and put them in config.g (the exact same commands) i get no warnings.
              You still get the warning, it's just a one time thing at boot instead of each print
              • A Former User?
                A Former User
                @bearer said in PanelDue 7i - warning message at start-up:
                const float noWarnTemp = (temperatureLimit - NormalAmbientTemperature) * 1.5 + 50.0; // allow 50% extra power plus enough for an extra 50C
                not sure if that panned out for that guy, but the issue is the firmware has calculated the theoretical maximum temperature for the heater if left on, and if that exceeds the formula above the warning is issued ... so in theory increasing the allowable temperature so the noWarnTemp becomes higher than what the warning is for then no warning (maybe)
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M143_Maximum_heater_temperature
                • deckingmanundefined
                  deckingman @DanS79
                  @DanS79 The warning is just that. It's a warning that the heater is over powered and so, if a MOSFET was to fail, there is a potential fire hazard. IIRC, it was introduced a few years back, along with a couple of other features when a user did in fact have such a fire, and complained that the firmware did not report that the hazard existed. IIRC, the other features which were introduced at the same time were checking for erratic temperature excursions which might indicate that a heater cartridge had fallen out or other such potential faults.
                  So you might find a way to remove the "annoying" warning, but you'll be left with the fundamental problem of using over powered heaters and the potential fire hazard that causes. You might find that a fire will be somewhat more annoying than the warning message. If I were part of the Duet team, and because we live in a world of litigation, I would most certainly not remove what is essentially a safety feature from the firmware because a user with over powered heaters found the warning message annoying.
                  • engikeneerundefined
                    engikeneer @DanS79
                    @DanS79 I would also add that you won't see the warning when in config.g because it is run at boot, so dwc hasn't started yet so you won't see the message. If you run M98 P"config.g" from console, it will re run your config file and you will see the warning message.
                    You will also have seen the warning message when you originally tuned the heaters.
                    i3 clone with a bunch of mods
                    • DanS79undefined
                      DanS79 @engikeneer
                      @engikeneer said in M307 in startup gcode gives heater over-powered warnings:
                      I tried the M98, and did indeed get the warnings. Yes, I got them when i did the pid tune, but thats really the only place I would expect to see them.
                      Everytime they get loaded is almost like annoyware imo.
                        Phaedrux Moderator @DanS79
                        Does the seatbelt light in your car annoy you too?
                        DanS79undefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                        • DanS79undefined
                          DanS79 @Phaedrux
                          @Phaedrux said in M307 in startup gcode gives heater over-powered warnings:
                          Yes, and while i can't disable the light I did disable the annoying chime....
                          • A Former User?
                            A Former User
                            did you even try M143 or are you confident enough to complain without trying it?
                            DanS79undefined 2 Replies Last reply Reply Quote 0
                            • Vetiundefined
                              Veti
                              he just wants to complain
                              • DanS79undefined
                                DanS79 @A Former User
                                This post is deleted!
                                • DanS79undefined
                                  @bearer said in M307 in startup gcode gives heater over-powered warnings:
                                  I did the math and that would require raising the HE limit to 582°C. That's well above even the theoretical maximum recommended by the manufacture, so i disregarded that as an option.
                                  dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
                                  • DanS79undefined
                                    DanS79 @Veti
                                    You can shove off!
                                      dc42 administrators @DanS79
                                      In that case, the estimated hot end temperature reached if you were unlucky enough to get a stuck heater would be even more above the manufacturer's recommended limit, probably enough to melt the heater block if it is aluminium.
                                      • A Former User?
                                        lol, its not gonna change the teperature to set the m413 before and after m307 ... you'll still have an overpowered heater if you do or you don't.
                                        think of it like printing a dummy seatbelt clip to get rid of the pesky sounds in the car...
                                        • DanS79undefined
                                          DanS79 @dc42
                                          @dc42 said in [M307 in startup gcode gives heater over-powered warnings]
                                          It's an E3D copper block, so its recommended max is 500°C.
                                            deckingman @Phaedrux
                                            A better analogy would be a smoke alarm going off when the OP burns the toast. Methinks the OP has removed the batteries from said alarm (if he has any).
