Error: Attempting to extrude with no tool selected
hello everyone every time a part prints my filament stops outputting and i have an error but the printer keeps printing
thank youadvance
Do you have a tool selection in your code?
i.e
T0 in your config.g or your start.g code?
M80 ; Turns on the ATX power supply
M550 P"sgk008" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable TelnetM669 K1 ; select CoreXY mode
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on ZM575 P1 S1 B57600 ; Set things up for the PanelDue
; Filament sensor
M591 D0 P1 C"e0stop" S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0; Drives
M569 P0 S0 ; Drive 0 goes backwards blv: its was S1
M569 P1 S0 ; Drive 1 goes backwards blv: its was S1
M569 P3 S1 ; Drive 3 goes backwards WAS 0
M569 P4 S0 ; Drive 4 goes forwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M92 X200 Y200 Z400 E415.178 ; Set steps per mm for Bondtech.
M566 X600 Y600 Z1000 E200 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
M203 X20000 Y20000 Z600 E2000 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X-23 Y0 Z0 S1 ; Set axis minima
M208 X320 Y321 Z350 S0 ; Set axis maxima; Z-Probe
M558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
G31 P500 X-2 Y-16.4 Z0.310 ; Set Z probe trigger value, offset and trigger height
M557 X20:270 Y20:270 S240 ; Define mesh grid; Heaters
M307 H0 R0.277 C337.2 D9.55 S1.00 V23.7 ; Set PID for heated bed values
M307 H1 R2.105 C132.8 D9.06 S1.00 V23.6 ; Set PID for hotend values
M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 R4700 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C0.0000000706 R4700 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S260 ; set temperature limit for heater 0 to 260C
M308 S2 P"mcu-temp" Y"mcu-temp" A"Duet Board" ; Configure MCU sensor; Tools
M563 P0 S"T0" D0 H1 F1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Access point is configured manually via M587 by the user
;M586 P0 S1 ; Enable HTTP
;M586 P1 S1 ; Enable FTP
;M586 P2 S1 ; Enable Telnet;Hot End fan tool
M106 P1 C"HE Fan" S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on 100% at 45deg;Tool Fan/ Layer Fan
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off;MB cooling fan layer
M106 P2 C"MB Fan" S1 H2 T35:55 ; set fan 2 value. Thermostatic control is turned on Temp Range of 35 - 55 deg; Custom settings
M572 D0 S0.275 ; Set bowden extruder elasticity compensation for E0
M572 D1 S0.275 ; Set bowden extruder elasticity compensation for E1
M207 S4.0 F2400 Z0.075 ; Set firmware retraction parameters; Scanner support (debug)
;M750; Set up DHT sensor on channels 101-102
;M305 P101 X405 S"DHT temperature" T11
;M305 P102 X455 S"DHT humidity [%]" T11; Automatic power saving
M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
T0 ; select first tool
@sgk said in Error: Attempting to extrude with no tool selected:
try disconnecting the paneldue.
also post the output of M98 P"config.g"
@Veti said in Error: Attempting to extrude with no tool selected:
M98 P "config.g"
12:47:21M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Invalid extruder number '1'
Warning: Macro file config-override.g not found
12:47:15Message Log cleared!
M572 D1 S0.275 ; Set bowden extruder elasticity compensation for E1i think it might be that statement
I must put 0
M572 D0 S0.275; Définir la compensation d'élasticité d'extrudeuse Bowden pour E1
you already have a line like that in your config
@Veti oh yes
I understood I have a double line
thank you very much
I still have the same error
14:29:50Error: Attempting to extrude with no tool selected.
14:29:46Error: Attempting to extrude with no tool selected.
14:29:42Error: Attempting to extrude with no tool selected.
14:29:38Error: Attempting to extrude with no tool selected.
@sgk post the gcode file you're printing with. My guess is that you have a rogue T-1 or T1 command in there.
Did you also try Veti's suggestion of disconnecting the Panel Due? I've seen before where interference in the wires to the Panel Due corrupts the data flow and gives similar issues.
it does it to me since the update of 2.03 2.05 3.0 3.1 3.2
with all files from all slicers
@sgk upload the sliced gcode file, not the stl.
Did you try disconnecting the panel due?
yes the same
it's crazy since I was in 3.2 I have this problem
did you disconnect the paneldue?
@Phaedrux or @T3P3Tony (or one of the other moderators), it seems @sgk has been blocked from posting (getting flagged as spam by Akismet.com). Can you help with this please?
@engikeneer thanks for the heads up. this is the first time i have seen it with someone who is already posting successfully. Akismet is a bit of a black box, can you ask him to email info@duet3d.com and we can try and trouble shoot through this.
@sgk You must post the sliced gcode file so we can see what the slicer is adding.
Do you have something defined in config-override.g concerning tools?
Might be weird, but did you try to remove the tool label S"T0" in M563?
Mine is like this:
; Tools M563 P0 D0 H1 F1 ; define tool 0 G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
@sgk Try moving the 'Tool' section of your config.g to after the fan definitions. At the moment it is defining the tool with a fan (F1, which is the thermostatic hot end fan, so I think it should be F0, the tool fan) before the fan has been defined. This wasn't a problem in the old version of the firmware, as fans were defined by default, but in RRF3 there are no default definitions.
hello everyone thank you very much for all of your help.
I post my gcodehttps://drive.google.com/drive/folders/1ryDNZchhWtu0Z5FudB5cCDygz8ms5czn?usp=sharing
for info I disconnected my panelduo and I managed to print
1 time
@sgk
ok see if you can route the paneldue cable not near any power or stepper cables
