    Error: Attempting to extrude with no tool selected
    2.8k
    • Vetiundefined
      Veti
      @sgk said in Error: Attempting to extrude with no tool selected:
      M575 P1 S1 B57600 ; Set things up for the PanelDue
      try disconnecting the paneldue.
      also post the output of M98 P"config.g"
        A Former User
        @Veti said in Error: Attempting to extrude with no tool selected:
        M98 P "config.g"
        12:47:21M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Error: Invalid extruder number '1'
        Warning: Macro file config-override.g not found
        12:47:15Message Log cleared!
        • Vetiundefined
          Veti
          M572 D1 S0.275 ; Set bowden extruder elasticity compensation for E1
          i think it might be that statement
            A Former User
            I must put 0
            M572 D0 S0.275; Définir la compensation d'élasticité d'extrudeuse Bowden pour E1
            • Vetiundefined
              Veti
              you already have a line like that in your config
                A Former User @Veti
                @Veti oh yes
                I understood I have a double line
                thank you very much
                  A Former User
                  I still have the same error
                  14:29:50Error: Attempting to extrude with no tool selected.
                  14:29:46Error: Attempting to extrude with no tool selected.
                  14:29:42Error: Attempting to extrude with no tool selected.
                  14:29:38Error: Attempting to extrude with no tool selected.
                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @A Former User
                    @sgk post the gcode file you're printing with. My guess is that you have a rogue T-1 or T1 command in there.
                    Did you also try Veti's suggestion of disconnecting the Panel Due? I've seen before where interference in the wires to the Panel Due corrupts the data flow and gives similar issues.
                    i3 clone with a bunch of mods
                      A Former User @engikeneer
                      @engikeneer ecrou poupee gbb.stl
                        A Former User
                        it does it to me since the update of 2.03 2.05 3.0 3.1 3.2
                        with all files from all slicers
                          @sgk upload the sliced gcode file, not the stl.
                          Did you try disconnecting the panel due?
                            A Former User
                            yes the same
                              A Former User
                              it's crazy since I was in 3.2 I have this problem
                              • Vetiundefined
                                Veti
                                did you disconnect the paneldue?
                                  engikeneer
                                  @Phaedrux or @T3P3Tony (or one of the other moderators), it seems @sgk has been blocked from posting (getting flagged as spam by Akismet.com). Can you help with this please? 🙂
                                    T3P3Tony administrators @engikeneer
                                    @engikeneer thanks for the heads up. this is the first time i have seen it with someone who is already posting successfully. Akismet is a bit of a black box, can you ask him to email info@duet3d.com and we can try and trouble shoot through this.
                                      @sgk You must post the sliced gcode file so we can see what the slicer is adding.
                                      • Thaliosundefined
                                        Thalios
                                        Do you have something defined in config-override.g concerning tools?
                                        Might be weird, but did you try to remove the tool label S"T0" in M563?
                                        Mine is like this:
                                        M563 P0 D0 H1 F1                                   ; define tool 0
                                        G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                                        Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                        Heavily modified Ender 3 Pro (Duet 3 6HC)
                                        Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                        CR-10S Pro V2 (Duet 3 Mini 5+)
                                        and a bunch of SLA printers..
                                          droftarts administrators @A Former User
                                          @sgk Try moving the 'Tool' section of your config.g to after the fan definitions. At the moment it is defining the tool with a fan (F1, which is the thermostatic hot end fan, so I think it should be F0, the tool fan) before the fan has been defined. This wasn't a problem in the old version of the firmware, as fans were defined by default, but in RRF3 there are no default definitions.
                                            A Former User
                                            hello everyone thank you very much for all of your help.
                                            I post my gcode
                                            https://drive.google.com/drive/folders/1ryDNZchhWtu0Z5FudB5cCDygz8ms5czn?usp=sharing
