    Error: Attempting to extrude with no tool selected
    2.8k
    • Vetiundefined
      Veti
      @sgk said in Error: Attempting to extrude with no tool selected:
      Error: Invalid extruder number '1'
      M572 D1 S0.275 ; Set bowden extruder elasticity compensation for E1
      i think it might be that statement
        A Former User
        I must put 0
        M572 D0 S0.275; Définir la compensation d'élasticité d'extrudeuse Bowden pour E1
        • Vetiundefined
          Veti
          you already have a line like that in your config
            A Former User @Veti
            @Veti oh yes
            I understood I have a double line
            thank you very much
              A Former User
              I still have the same error
              14:29:50Error: Attempting to extrude with no tool selected.
              14:29:46Error: Attempting to extrude with no tool selected.
              14:29:42Error: Attempting to extrude with no tool selected.
              14:29:38Error: Attempting to extrude with no tool selected.
              engikeneerundefined 1 Reply Last reply Reply Quote 0
              • engikeneerundefined
                engikeneer @A Former User
                @sgk post the gcode file you're printing with. My guess is that you have a rogue T-1 or T1 command in there.
                Did you also try Veti's suggestion of disconnecting the Panel Due? I've seen before where interference in the wires to the Panel Due corrupts the data flow and gives similar issues.
                i3 clone with a bunch of mods
                  A Former User @engikeneer
                  @engikeneer ecrou poupee gbb.stl
                    A Former User
                    it does it to me since the update of 2.03 2.05 3.0 3.1 3.2
                    with all files from all slicers
                      @sgk upload the sliced gcode file, not the stl.
                      Did you try disconnecting the panel due?
                        A Former User
                        yes the same
                          A Former User
                          it's crazy since I was in 3.2 I have this problem
                          • Vetiundefined
                            Veti
                            did you disconnect the paneldue?
                              engikeneer
                              @Phaedrux or @T3P3Tony (or one of the other moderators), it seems @sgk has been blocked from posting (getting flagged as spam by Akismet.com). Can you help with this please? 🙂
                                T3P3Tony administrators @engikeneer
                                @engikeneer thanks for the heads up. this is the first time i have seen it with someone who is already posting successfully. Akismet is a bit of a black box, can you ask him to email info@duet3d.com and we can try and trouble shoot through this.
                                  @sgk You must post the sliced gcode file so we can see what the slicer is adding.
                                  • Thaliosundefined
                                    Thalios
                                    Do you have something defined in config-override.g concerning tools?
                                    Might be weird, but did you try to remove the tool label S"T0" in M563?
                                    Mine is like this:
                                    M563 P0 D0 H1 F1                                   ; define tool 0
                                    G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                                    Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                    Heavily modified Ender 3 Pro (Duet 3 6HC)
                                    Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                    CR-10S Pro V2 (Duet 3 Mini 5+)
                                    and a bunch of SLA printers..
                                      droftarts administrators @A Former User
                                      @sgk Try moving the 'Tool' section of your config.g to after the fan definitions. At the moment it is defining the tool with a fan (F1, which is the thermostatic hot end fan, so I think it should be F0, the tool fan) before the fan has been defined. This wasn't a problem in the old version of the firmware, as fans were defined by default, but in RRF3 there are no default definitions.
                                        A Former User
                                        hello everyone thank you very much for all of your help.
                                        I post my gcode
                                        https://drive.google.com/drive/folders/1ryDNZchhWtu0Z5FudB5cCDygz8ms5czn?usp=sharing
                                          A Former User
                                          for info I disconnected my panelduo and I managed to print
                                          1 time
                                          • Vetiundefined
                                            Veti @A Former User
                                            @sgk
                                            ok see if you can route the paneldue cable not near any power or stepper cables
