Poor print quality with RRF3 - especially 3.2.2.
@deckingman said in Poor print quality with RRF3 - especially 3.2.2.:
Any filament that is more than year old gets discarded (or I might use it in desperation but would be highly suspicious of any parts made with it).
Does that include original vacuum sealed packages that were never opened ?
@jens55 said in Poor print quality with RRF3 - especially 3.2.2.:
No. I date them when I open them (break the seal). IMO, anything else is pointless unless they have a manufacturing date on them, which I've rarely seen. No system is perfect as one could get a reel that's been in storage for months or (even years conceivably) before one made the purchase.
Even then, I've had bad reels but it tends to be kind of obvious. Since a very bad experience with the eSun PET-G, I've learned to be suspicious of the first print with a new reel - foil and vacuum packed or otherwise.
I have a feeling that reel of eSun PETG fell overboard somewhere in the South China sea, was fished out after a months immersion, and only then put into a vacuum packed foil bag. I don't see how else it could have got so wet. I passed it on to a friend who spent hours and hours drying it but he never had much luck with it. Never bought any eSun filament since (although others swear by it).
Good ... you had me worried there for a bit because I have a fairly substantial stock pile. I buy a year's estimated supply at boxing day prices and have filament that is more than 2 years old but in the original sealed vacuum package.
I use mostly black and white but also have some coloured filament that is sealed but is rarely used. -
@jens55 Different filaments have different properties. I'm told that Nylon is a bugger for absorbing water (never used it myself) but PLA is reasonably forgiving. On the other had, it seems to go brittle if left on the machine too long but often, pulling out a couple of metres or so will sort it out. There is a school of thought that say UV light plays a part in that.
What you doing is probably fine. If you didn't buy a batch at a time and store it at home, it'd likely sit in Amazon's warehouse until you or someone else bought it. Just be on the lookout for print defects when you first fit a new reel, or again, if you know the filament has been opened and sitting around for a while.
Personally I prefer to buy it more sort of "as and when" I need it. There is less chance of getting a number of bad reels because they all come from the same (bad) batch. I stick with the same supplier - they've served me well over the years and I know they'd likely do a refund or send another reel if I came across a bad one.
@deckingman, you can have an Ender 3 on the side, as a reference for filament quality.
@zapta said in Poor print quality with RRF3 - especially 3.2.2.:
Not sure why people are so fixated about this print to print variability being due to filament. Not impossible but the idea that nnn metres could produce a bad print and the next nnn metres of the same reel could produce an acceptable print, is among the least plausible I'd have thought.
@deckingman
Your filament storage method is out off question for me, but I still stick to somethings wrong with cold start.
Might be, the firmware(s) of the boards involved click together easier after a reboot. I have created the habit, to issue an emergency stop from DWC, after I've played around with mesh bed leveling or Z-probe adjustment.
Just to give MCU and memory a clean wipeout. -
@o_lampe Looking through these forums, there are numerous instances where cycling power often seems to fix things. It makes one wonder......Perhaps an electrical component somewhere which performs differently when it's warm/cold?
One could speculate forever. All I can do is keep plugging away and doing what dc42 asks. Maybe something will show up with the diagnostics that 3.3 beta will provide and which I plan to do later.
And when someone says "well what do you expect? you are using beta firmware!", as has happened before, I'll likely commit murder....
@deckingman well what do you expect? you are using ... oh, never mind.
Ian (feeling a little scared)
@droftarts I know who you are (but I don't know where you live so you are safe .......for now).
@deckingman yes, you do, you sent me a roll of 3mm clear filament! Oh no! Heβs got my address! Going into hiding...
Let's hope it's just a firmware issue and not a hardware thing. There are so many threads about CAN-stuff going wild...it might be interference or crosstalking. AFAIK, it's their first attempt to implement CAN. And according to German Automobile Clubs, electric failure is the most frequent reason for parking your car unvolontary. (Cars are full of CAN-devices)
@dc42 David,
I've installed 3.3.beta1 on all boards. I cleared the console, ran M122 on all boards after the instal, then downloaded the console output as a text file. Then I homed the printer, and repeated the "clear console - run M122s -download text" sequence again. Then started a print and repeated that M122 sequence again mid print. And finally, one more time at the end. I've created a folder on Google drive and put each of those 4 console.txt files in a separate folder. So it should be self explanatory - here is a link https://drive.google.com/drive/folders/1m1BnwUsU035TQT_76kcl3Yiz4BPApXg8?usp=sharing
I don't see any of the non zero oos on the expansion boards but I do see some send timeouts on the main board for the mid print and post print reports (102 mid-print and 373 post print).
The print itself if still cooling down on the build plate so I haven't looked closely at it but it doesn't look good. Not as bad as some that I've seen, but not as good as "acceptable" ones either.
HTH
@droftarts Fortunately for you, I didn't keep a record or your address - so you can come out from under the duvet now.
@deckingman, thanks for those M122 logs. If the print quality is between the bad ones and the acceptable ones, that is confusing! Can you confirm that you have been running with the same pressure advance setting (perhaps none) throughout all the recent prints?
As you said, you are getting a nonzero number of send timeouts. In theory this should mean that some messages (probably movement messages) have been lost; but in that case the expansion boards should have reported some 'oos' (out-of-sequence) errors. So I am still trying to work out the reason for this apparent conflict. The other user I was working with had a similar effect: a small number of 'oos' errors (and corresponding defects in the print) but several hundred times as many send timeouts.
My suspicion is that the CAN peripheral is delaying the reporting of successful transmissions by longer than the timeout period. However, I would like to eliminate the send timeouts as a possible reason for the issue you are seeing. So please upgrade once more, this time to the firmware binaries at https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0. These are later versions of 3.3beta1 and fully compatible with them. So no need to do anything different this time. I expect these binaries to get rid of the send timeouts, and also to get rid of the spurious 'bm' errors reporting on the 3HC after homing.
@dc42 Ref the print quality - let's go with bad rather than acceptable. But the way things have been, it's possible that the next print might be worse (or better).
I can confirm that everything is exactly the same - including PA (and it's still the same reel of filament. I tell a lie - the part cooling fans are no longer connected since one of the most acceptable prints was done without any part cooling.
I've downloaded the binaries - it might be a day or two before I get chance to instal them and run another print.
As I'm running a beta, is there anything else you'd like me to check?
@deckingman did you swap extruders?
@droftarts said in Poor print quality with RRF3 - especially 3.2.2.:
Er no. I thought it best to only change one thing - in this case the firmware. But thanks for reminding me. I'll do another print "as is" with David's latest binaries, then I'll change to another extrude and repeat.
What filament are you printing with? If it's PLA then please reconnect the print cooling fans, because in my experience print cooling makes a huge difference with PLA, and some of the issues with the prints you posted before looked to me like the effects of insufficient cooling. If you are using PETG then print cooling seems to me to be far less important.
@dc42 That's not born out by previous prints https://drive.google.com/drive/folders/1XmFXYBGnj3rXJRLg1muSNBd18AbP2ZDl?usp=sharing. The reason why I disconnected the fans was because people were talking about intermittent fan issues. So I disconnected them completely to see just how bad it would be, and was surprised when I ended up with one of the best prints of the batch. Therefore I deduced that running without fans would eliminate one potential variable (knowing that decent prints could be produced with that configuration).
I use the auto cooling feature of Slic3R in any case so the fans don't do much if the layer time is less than circa 15 seconds or if it's doing bridges. And the fans are arranged so that no direct air flows over the nozzle. It's something that I have played around with a lot over the years.
Maybe it's because I print temp towers without fans and so end with using lower temperatures than a lot of people. Again, something that I've played around with a lot over the years.
