DWC 3.1.1
What are you doing when that error message shows up?
HO FATTO MENU FILAMENT IN SD CARD
ECCO
SE TOCCO PIANO-SONDATO .CSV SI BLOCCA TUUO.
This post is deleted! -
DA L ERRORE QUANDO ARRIVA SUL PIATTO ED ESTRAE LA SONDA HO UN BBLTouch
Please post all your config files. config.g homeall.g homex.g homey.g homez.g homedelta.g bed.g deployprobe.g retractprobe.g
Do you have a file called mesh.g in the system folder?
no non ho la mesh.g G29 Esegui il file sys / mesh.g, o se quel file non viene trovato, esegui G29 S0 ho fatto cosi errore:
G29 S0
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)...ora confronto ifail detti da te config files. config.g homeall.g homex.g homey.g homez.g homedelta.g bed.g deployprobe.g retractprobe.g con i vecchi senza problema se non risolvo li posto ,
@luca-Massimiliano said in DWC 3.1.1:
RISOLTO
COME DICEVI TE NO ERA NASCOSTO NEL FILE DELOYPROBLE.G -
non penso sia correto,
VORREI USARE REPETIER HOST TRAMITE WIFI , NON SO COME FARE , MI PUOI INDIRIZZARE ?
I WOULD LIKE TO USE REPETIER HOST VIA WIFI, I DON'T KNOW HOW TO DO IT, CAN YOU ADDRESS ME?
I do not know how to use repetier host.
COSA USI PER STAMPARE?
I upload the sliced file directly from the slicer to the Duet over the network.
@luca-Massimiliano You upload gcode files to the 'Jobs' screen in DWC, print from there!
See: https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_JobsIan
@droftarts STL OK?
