    Duet 2 wifi failures
    1.9k
    • tia79undefined
      tia79
      Hi!
      Its taken me a 4 months and i can say i have finally installed my first duet2 wifi on an Anycubic Predator. What a stressful project this has been for someone not at all good at wiring, but ive managed well and i will probably upgrade my other printers! It was fun and a learning curve with alot of research. However. I have some problems.
      After i did a M587 my interface page did not load, i tried to reinstall everything on the sd card and it still does not work. I also tried to redo the M587 and it failed. I also tried M997 to load the WifiServer.bin but no luck there either and then i saw another post and i tried M21 and it didn't load the sd card. So how do i fix this? In advance thank you for replies.
      And for those asking if this is a original duet, heres the box https://cdn.discordapp.com/attachments/466162216903901205/820637152508641300/20210314_133823.jpg
      M587 S"AndroidAPF018_RPT" P"***"
      SENDING:M587 S"AndroidAPF018_RPT" P"***"
      M587: Failed to add SSID to remembered list
      ok B:2000.0 /0.0
      M997 S1
      SENDING:M997 S1
      M997: File DuetWiFiServer.bin not found
      SENDING:M21
      M21: Cannot initialise SD card 0: Card is unusable
      SENDING:M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
      droftartsundefined Vetiundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @tia79
        @tia79 are you following the “getting connected” guide? Specifically from here: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
        It’s important to turn off WiFi, and then turn it on in idle mode, before adding SSID. So
        M552 S-1
        M552 S0
        Regarding the SD card, see https://duet3d.dozuki.com/Wiki/SD_Card which has recommendations on how to set up SD Card, and troubleshooting advice.
        • tia79undefined
          tia79
          @droftarts Cool that did it!
          However i get the message on the page now "Your Duet rejected the HTTP request: page not found
          Check that the SD card is mounted and has the correct files in its /www folder"
          The SD card contains the same files as described on https://duet3d.dozuki.com/Wiki/SD_Card
          I read from another post on the forum that this is a firmware mismatch error but theres no info on how to fix that.
            @tia79 now it’s a SD card reading issue. Did you reformat the card? Don’t use Windows quick format, use the proper tool. What file did you decompress into the www folder? Post an image of the SD card contents, if possible. The matching version of DWC for RRF v2.03 you have installed is DuetWebControl-1.22.6.zip from here: https://github.com/Duet3D/RepRapFirmware/releases/tag/2.03
            • tia79undefined
              tia79
              @droftarts
              I decompressed the sd_content zip onto the sd card.
              https://cdn.discordapp.com/attachments/549857567342592002/821667844776919080/Screenshot_1.png
              https://cdn.discordapp.com/attachments/549857567342592002/821667845926682644/Screenshot_2.png
              https://cdn.discordapp.com/attachments/549857567342592002/821667848749056000/Screenshot_30.png
                @tia79 that all looks correct. Still not connecting?
                • tia79undefined
                  tia79
                  @droftarts No it doesn't.
                  It doesn't even connect to my wifi. I installed the Web Interfacing matching the firmware but now it doesn't even connect to wifi.
                  • Vetiundefined
                    Veti @tia79
                    @tia79 said in Duet 2 wifi failures:
                    can you try a different sd card.
                    make sure its fat formated
                    • tia79undefined
                      tia79
                      @Veti Gotta go buy one then, i don't have this small cards. But i will try in a few days and let you know.
                      • Vetiundefined
                        Veti
                        what card sizes do you have?
                        • tia79undefined
                          tia79
                          @Veti Only those that comes with Anycubic Predator and Chiron. 🙂
                          • Vetiundefined
                            Veti
                            check in a computer which filesystem you put on the sd card
                            • tia79undefined
                              tia79
                              @Veti https://cdn.discordapp.com/attachments/549857567342592002/821709016430018610/Screenshot_3.png
                                @tia79 did you format the SD card with the formatting tool from https://www.sdcard.org/downloads/formatter/index.html ? If it’s not the one supplied with Duet, what make, model and speed is it? Or post picture.
                                • tia79undefined
                                  tia79
                                  @droftarts It is the original Duet sd card. I got the page up again but its giving me "Your Duet rejected the HTTP request: page not found
                                  Check that the SD card is mounted and has the correct files in its /www folder" even tho the content on the card is correct.
                                    @tia79 how did you enable networking? By sending M552 S1 via USB? If so, the network is not being enabled because the config.g file is not being read. This will be because either the SD card isn’t working in the Duet, or the Duet SD card socket is faulty. With the information you have supplied, I don’t know which it is. So:
                                    1. Format the SD card with the SD card formatting tool, copy configuration and www files on to the SD card and try again.
                                    2. If that doesn’t work, inspect the SD card socket as described here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
                                      If the socket looks like the one in the picture, take a picture of yours and post it here, and we’ll work out if you need a warranty replacement.
                                    • tia79undefined
                                      tia79
                                      @droftarts I tried to reformat the sd card but no luck. its still the "Your duet rejected the HTTP request".
                                      I give up trying to fix this.
                                      SD card socket pic: https://cdn.discordapp.com/attachments/549857567342592002/821769534707990558/20210317_154424.jpg
                                        Do you have some compressed air to blow off the board and the slot? It's possible there is some dirt and debris in there blocking the SD card contacts.
                                        • tia79undefined
                                          tia79
                                          @Phaedrux Dirt and debris? You sound like i used the card while i was making mudcakes 🙄
                                            Instant mudcakes. Just add water. 😜
