    Strange bugs 3.3beta2
    Beta Firmware
    8
    48
    2.5k
      @Dep said in Strange bugs 3.3beta2:
      M376 H20 ; bed compensation taper
      With a taper set the amount moved to compensate is diminished over the duration of the print and for small amounts can make it very hard to see.
      Can you post a screenshot showing your heightmap?
      How often do you re-create the heightmap?
      Depundefined 1 Reply Last reply Reply Quote 0
      • Depundefined
        Dep
        I've done it many times. The print shows that the compensation does not work. I also attach a long stick to the pulley to check if there is movement or not.
        If necessary, I can shoot a video.
        • Depundefined
          Dep @Phaedrux
          @Phaedrux said in Strange bugs 3.3beta2:
          I've tried disabling taper. M376 H0
          Nothing changes.
            jay_s_uk
            add G29 S1 after the G28 in your start script
            • Depundefined
              Dep @jay_s_uk
              @jay_s_uk It is added:
              homeall.g (G29 S1 here)
              ; homeall.g
              ; called to home all axes
              M98 P"homex.g"
              M98 P"homey.g"
              M98 P"bed.g"
              G29 S1
                jay_s_uk @Dep
                @Dep ah, missed that
                  All I can think is that the conditional gcode in your homing files is skipping something.
                  Can you try adding G29 S1 to your slicer start gcode after the purge filament macro?
                  Then check if mesh compensation is active in M122 during the print and see if the Z axis is moving.
                  • OwenDundefined
                    OwenD
                    Could it be that you're not homing Z after you run bed.g ?
                      Phaedrux Moderator @OwenD
                      @OwenD said in Strange bugs 3.3beta2:
                      Bed.g is getting called as part of homeall. bed.g calls homez.
                      • Depundefined
                        Dep
                        The oddities continue. Now there is a problem with the filament monitor: min -5% and printing continues:
                        20.03.2021, 10:39:40	M591 d0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 131 agc 107, measured sensitivity 25.37mm/rev, min -5% max 105% over 153582.5mm
                        20.03.2021, 10:32:45	M591 d0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 131 agc 107, measured sensitivity 25.36mm/rev, min -5% max 105% over 151673.8mm
                        20.03.2021, 10:25:49	M591 d0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 131 agc 107, measured sensitivity 25.36mm/rev, min -5% max 105% over 149761.4mm
                        20.03.2021, 10:22:38	M591 d0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 131 agc 107, measured sensitivity 25.36mm/rev, min -5% max 105% over 148885.3mm
                        20.03.2021, 10:21:55	M591 d0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 131 agc 107, measured sensitivity 25.36mm/rev, min -5% max 105% over 148686.4mm
                        20.03.2021, 10:21:18	M591 d0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 131 agc 107, measured sensitivity 25.36mm/rev, min -5% max 105% over 148515.8mm
                        After the "reset":
                        20.03.2021, 10:52:50	M591 D0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 132 agc 107, measured sensitivity 25.51mm/rev, min 97% max 104% over 2092.2mm
                        20.03.2021, 10:50:15	M591 D0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 132 agc 107, measured sensitivity 25.51mm/rev, min 97% max 104% over 1380.5mm
                        20.03.2021, 10:48:02	M591 D0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 132 agc 107, measured sensitivity 25.53mm/rev, min 97% max 104% over 766.6mm
                        20.03.2021, 10:47:35	M591 D0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 132 agc 107, measured sensitivity 25.54mm/rev, min 97% max 104% over 644.5mm
                        20.03.2021, 10:45:52	M591 D0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 132 agc 107, measured sensitivity 25.57mm/rev, min 97% max 104% over 171.1mm
                        20.03.2021, 10:45:22	M591 D0
                        Duet3D rotating magnet filament monitor v3 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, version 3, mag 132 agc 107, measured sensitivity 25.57mm/rev, min 97% max 101% over 26.5mm
                        20.03.2021, 10:45:02	M292
                        Printing paused at X-21.7 Y-33.3 Z2.5 C40.0
                        20.03.2021, 10:44:51	Resume state saved
                        20.03.2021, 10:44:24	M591 d0
                        Duet3D rotating magnet filament monitor v1 on pin 21.io1.in, enabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, no data received
                        20.03.2021, 10:44:14	M591 d0
                        20.03.2021, 10:43:53	M591 d0
                        20.03.2021, 10:43:39	M591 d0
                        20.03.2021, 10:43:19	M591 d0
                        20.03.2021, 10:42:57	M591 d0
                        20.03.2021, 10:42:43	M591 d0
                        20.03.2021, 10:42:34	M591 d0
                        20.03.2021, 10:42:31	M591 d0 s1
                        20.03.2021, 10:42:24	M591 d0
                        Duet3D rotating magnet filament monitor v1 on pin 21.io1.in, disabled, sensitivity 28.80mm/rev, allow 30% to 160%, check every 3.0mm, no data received
                        20.03.2021, 10:42:21	M591 d0 s0
                        All settings are higher in this thread.
                        I ran 170 hours long print. I should have tried to install the old firmware, something is wrong here 😞
                        And a couple of screenshots to tread:
                        • Depundefined
                          Dep
                          And I already had it. But at that moment
                          I had one of the extruders disabled on the CAN bus and errors were pouring in. I thought it was because of this.
                          Last time min was -107% the extruder ended up stuck, but the printer kept printing in air all night.
                          In general, the filament monitor does not work on this firmware.
                          • Depundefined
                            Dep
                            I installed 3.2.2 firmware - the errors disappeared, the mesh is working, the filament monitor is working.
                            The printer is printing 5 hours, the flight is normal. So pay attention to what I wrote above.
                              So it's all working fine in 3.2.2 but has problems with 3.3beta2?
                              If so I will remove the Solved tag as it still needs to be investigated.
                              • Depundefined
                                Dep
                                The errors that fell on the screen and the problem with the filament sensor disappeared immediately. So yes, this is a beta issue.
                                As for the mesh calibration, I still do not understand. Now it seems to be working. But it somehow still worked on beta. I recalibrated many times, so I got completely confused.
                                • oliofundefined
                                  oliof
                                  FWIW I see those errors too with a Paneldue, so I removed it for the time being. Machine is down for other reasons right now, so I forgot to report it.
                                    Next time one of you get these "Bad command" messages on PanelDue, please run M122 from the DWC console or USB. I am especially interested in what value it reports for "Aux0 errors".
                                    Depundefined psychotik2k3undefined 2 Replies Last reply Reply Quote 0
                                      dc42 administrators @Dep
                                      Another dangerous bug!
                                      M558 K0 H5 A5 F120
                                      Works as it should
                                      M558 K0 H5 A5 F120: 120
                                      Also works as it should
                                      M558 K0 H5 A5 F120: 60
                                      Broke today probe.
                                      The bed goes up and breaks the probe. And continue to rise.
                                      I checked it several times.
                                      What type of probe is it? Some types of probe (e.g. Smart Effector and piezo probes) don't work at low speeds.
                                      • Depundefined
                                        Dep
                                        Simple micro switch.
                                        • Depundefined
                                          Dep @dc42
                                          @dc42 I can't yet, because I installed version 3.2.2 and the messages disappeared.
                                          • psychotik2k3undefined
                                            psychotik2k3 @dc42
                                            @dc42 here it is:
                                            24/05/2021, 22:20:04	M122
                                            RepRapFirmware for Duet 3 MB6HC version 3.3RC2 (2021-05-11 14:55:28) running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                            Board ID: 08DJM-956BA-NA3TN-6JTD8-3S86J-1UB2T
                                            Used output buffers: 1 of 40 (40 max)
                                            Static ram: 150680
                                            Dynamic ram: 93532 of which 108 recycled
                                            Never used RAM 107016, free system stack 120 words
                                            Tasks: NETWORK(ready,445.1%,226) ETHERNET(notifyWait,1.3%,124) HEAT(delaying,0.2%,295) Move(notifyWait,0.6%,242) CanReceiv(notifyWait,0.3%,773) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.1%,341) TMC(notifyWait,128.2%,59) MAIN(running,312.5%,619) IDLE(ready,0.0%,29), total 888.3%
                                            Owned mutexes:
                                            Last reset 03:22:59 ago, cause: software
                                            Last software reset at 2021-05-24 18:57, reason: User, GCodes spinning, available RAM 110188, slot 0
                                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                            Error status: 0x04
                                            Aux0 errors 9,9,9
                                            Aux1 errors 0,0,0
                                            Step timer max interval 133
                                            MCU temperature: min 40.4, current 42.5, max 43.1
                                            Supply voltage: min 23.3, current 23.7, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                            12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
                                            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/40/40, gc cycles 0
                                            Driver 0: position 12600, standstill, reads 41045, writes 30 timeouts 0, SG min/max 0/212
                                            Driver 1: position -22000, standstill, reads 41046, writes 30 timeouts 0, SG min/max 0/212
                                            Driver 2: position 4272, standstill, reads 41046, writes 30 timeouts 0, SG min/max 0/173
                                            Driver 3: position 0, standstill, reads 41046, writes 30 timeouts 0, SG min/max 0/168
                                            Driver 4: position 0, standstill, reads 41065, writes 11 timeouts 0, SG min/max 0/0
                                            Driver 5: position 0, standstill, reads 41066, writes 11 timeouts 0, SG min/max 0/0
                                            Date/time: 2021-05-24 22:18:43
                                            Slowest loop: 13.29ms; fastest: 0.05ms
                                            === Storage ===
                                            Free file entries: 10
                                            SD card 0 detected, interface speed: 25.0MBytes/sec
                                            SD card longest read time 2.2ms, write time 2.0ms, max retries 0
                                            DMs created 125, maxWait 8863916ms, bed compensation in use: mesh, comp offset 0.038
                                            === MainDDARing ===
                                            Scheduled moves 410, completed moves 410, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                                            === AuxDDARing ===
                                            Segments left: 0
                                            Movement lock held by null
                                            HTTP is idle in state(s) 0
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Trigger is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            SBC is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Aux2 is idle in state(s) 0
                                            Code queue is empty.
                                            === CAN ===
                                            Messages queued 110176, send timeouts 0, received 146584, lost 0, longest wait 2ms for reply type 6018, peak Tx sync delay 284, free buffers 49 (min 48)
                                            === Network ===
                                            Slowest loop: 5.93ms; fastest: 0.02ms
                                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                                            HTTP sessions: 1 of 8
                                            - Ethernet -
                                            State: active
                                            Error counts: 0 0 1 0 0
                                            Socket states: 5 2 2 2 2 0 0 0
                                            psychotik2k3undefined 1 Reply Last reply Reply Quote 0
