    e0stop kills board?
    341
    • pro3d
      pro3d last edited by
      Something blew on my board when I tried to add a simple filament switch. I did manage to attach gnd to 3.3V and + to gnd... Does this kill the whole thing? It now seams totally dead and I can find no burnt fuses
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      alankilian 1 Reply Last reply Reply Quote 0
      • alankilian
        alankilian @pro3d last edited by
        @pro3d Can you describe:
        • How you hooked up the switch?
        • Which Duet board?
        • What kind of switch?
        Did you check the fuses?
        Do any LEDs light up?
        pro3d 1 Reply Last reply Reply Quote 0
          https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
          See how far you can get.
          • pro3d
            pro3d @alankilian last edited by
            @alankilian
            Oh.. sorry for lack of info
            D2 wifi 1.04
            I hooked up gnd to 3.3 and + to gnd and signal to signal.
            Switch is just a standard mechanical endstop switch
            One blue led lights up but everything is dead
            Fuses are all fine
            alankilian weed2all 2 Replies Last reply Reply Quote 0
            • alankilian
              @pro3d You "hooked up gnd to 3.3"?
              That would cause a short-circuit on the 3.3 Volt power supply and could cause either the 5Volt or 3.3 Volt (or both) power supplies to fail.
              • weed2all
                weed2all @pro3d last edited by weed2all
                @pro3d but why? A normal switch(2 pin endstop uses the GND and signal pins on duet board? Why would you use the 3.3V pin?
                probably blew up the 3.3v line and 5v line....
                https://www.thingiverse.com/weed2all/designs
                • pro3d
                  pro3d @weed2all last edited by
                  @weed2all
                  The endstop did have 3 pins. gnd, + and signal. It was a filament detector switch that is basically just a microswitch sof some kind I think. This is how I connected
                  • pro3d
                    @alankilian said in e0stop kills board?:
                    Thank you. I hooked up 3.3 from the4 controller to gnd on the switch
                      Phaedrux Moderator @Phaedrux last edited by
                      @phaedrux said in e0stop kills board?:
                      @pro3d So how far are you able to get? Does the board show up in device manager when connected by USB?
                      • pro3d
                        pro3d @Phaedrux last edited by
                        Hey mr. I hav enot been able to chack anything. I pulled the board and replaced it. I can try to connect by usb soon. There was only one blue led lighting up after the kill
                          Photos of the board may show a blown component. Depending on how extensive the damage was it may be recoverable by a firmware flash...
                          Which LED specifically is lit when connected to power? What's it labeled as?
