    Hybrid direct bowden, how to set up?
    1.3k
    • solo3dundefined
      solo3d
      I'd like to use 2 different extruders, with 2 motors and 2 drivers and one hotend.
      The point is to use a very small stepper, for the direct extruder and a larger one, for the bowden. The extruders have 3:1 and 4:1 ratio, so I will be using 2 drivers. I understand people questioning such an idea, but I have some reasons for that.
      My question is, is there any simple solution, to map 2 motors to 1 tool, to work simultaneously.
      Thank you.
      zaptaundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian
        @solo3d See in the GCODE page:
        • M567
        • M568
        • Mixing hotend settings for Duet2
        • zaptaundefined
          zapta @solo3d
          @solo3d said in Hybrid direct bowden, how to set up?:
          Do you plan to extrude with both of them simultaneously or sometimes with one and other times with the other?
          solo3dundefined 1 Reply Last reply Reply Quote 0
          • solo3dundefined
            solo3d @zapta
            @zapta both always on.
            zaptaundefined 1 Reply Last reply Reply Quote 0
            • o_lampeundefined
              o_lampe @solo3d
              What is the mixing ratio between the two motors?
              In mixing mode it can happen, that the stronger motor pushes molten filament up in the other path. They are actually fighting against each other. Both motors small wouldn't be enough torque?
              • solo3dundefined
                solo3d @o_lampe
                @o_lampe Don't think I made it clear. The dual extruder set up is to drive the single filament line. The purpose is, that the light motor used with the direct extruder is helped by the other extruder, at the other end of the bowden. Basically they are working as a single unit, just helping each other. The problem is, the extruders have the different ratiosand will require different steps per mm values, so I can't just connect the motors in series.
                dragonnundefined 1 Reply Last reply Reply Quote 0
                • dragonnundefined
                  dragonn @solo3d
                  @solo3d I am doing something like that and using mixing hotends but they is a big problem with that - it is almost impossible to setup the steps/per mm or mixing ration perfectly right.
                  I think the only solution would be that the bowden extruder uses rubber wheels some kind and pushes a litte bit faster then the direct extruder. When setup right it would just slip over the filament when they is no space to push it.
                  • o_lampeundefined
                    o_lampe @solo3d
                    OK, understood.
                    What are the diameters of the drive wheels? Are they same or does it get really wicked with different diameters?
                    • solo3dundefined
                      solo3d @o_lampe
                      @o_lampe both are mbg gears, one is belt driven 4:1, the other is the regular 3:1
                      • o_lampeundefined
                        o_lampe @solo3d
                        If only it was 3:1, but AFAIK it's 50:17 (2.95:1) or 50:16 (3.125:1)
                        • solo3dundefined
                          solo3d @o_lampe
                          Ok thanks. Sounds like it will be much easier to get another extruder, with the matching ratio.
                          MaxGyverundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                          • MaxGyverundefined
                            MaxGyver @solo3d
                            @solo3d
                            Hey, I have tried exactly what you are describing with some success. I have switched back to just using a single extruder because I had some printing artifacts and needed to make sure that this is not caused by the hybrid extruder setup.
                            So I have to recall my setup steps from memory here:
                            1. setup two separate extruder motors in your config.g with their respective driver assignments, voltages, acceleration, jerk and e-steps depending on the gear ratio of each extruder.
                            2. create your tool and tell it to use extruder drive 1 and 2
                            ; tool 0
                            M563 P0 D0:1 H1 F1 ; tool 0 uses extruder drive 1 and 2 , heater1 and fan1
                            M568 P0 R0 S0 ; Set active and standby temperatures
                            1. Set tool mix ratios to 100% so that both extruders are used.
                            M567 P0 E1.00:1.00 ; Set tool mix ratios of tool1 to 100% for extruder 1 and 2
                            -Max
                            • zaptaundefined
                              zapta @solo3d
                              For mixing, the resident expert is @deckingman.
                              His blog is here, may give you some ideas. Also on youtube with same username. https://somei3deas.wordpress.com/author/deckingman/
                              • deckingmanundefined
                                deckingman @solo3d
                                @solo3d I saw my name mentioned so I'll jump in here. As I understand it, you want to use the extruders in a "push pull" arrangement yes? To be clear, your hot end has a single filament input and a single nozzle output yes? If those assumptions are correct, then the method that @MaxGyver posted above is correct.
                                That is to say, you define the steps per mm for each extruder which will take care of the fact that they have different gear ratios. You do this in one single M92 command using a colon separator. So for example, if the first extruder has 400 steps per mm and the second has 500 steps per mm then the command would be M92 E400:500.
                                From this point on, the first extruder will be D0 and the second extruder will be D1. So then you define the tool to use both extruders and the single heater i.e (assuming you want to use tool 0) M563 P0 D0:1 H1. Then you set the mixing ratio to use 100% of each extruder so M567 P0 E1.00:1.00.
                                • solo3dundefined
                                  solo3d
                                  Thanks to all who responded!
                                  All working now!
