    Why does the forum add {1} into CODE
    Off Topic
    • OwenDundefined
      OwenD
      I've found that often when copying and pasting things into CODE blocks, the forum adds {1} into areas where there is a line break.
      But not always?
      I've tried setting my the temp editor to use Linux style line breaks (CR) instead of (CR/LF), but I can't seem to crack what the cause is and more importantly how to avoid it?
        That's a good question. Sometimes it seems to do it, and sometimes not.
        If you have a sample of copy and paste that can reliably cause it can you upload that file?
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @Phaedrux
          @phaedrux
          I think I've worked it out.
          It's a bug in the syntax highlighter.
          It seems to occur on any line break following a quoted string "some text"
          This is original where some lines have quoted text as is required.
          if move.axes[0].homed !=true || move.axes[1].homed !=true || move.axes[2].homed !=true
          	echo "Homing"
          	M291 P"Homing required.  Please wait" R"Homing" S1 T3
          	G28 ; home all if required
          echo "Creating cold bed map"
          M291 P"Creating cold bed map" R"Cold Map" S1 T3
          G29 S0 ; create bed mesh
          if result !=0
          	M140 S0 R0 ; set active and standby temps to zero
          	M140 S-276 ; turn off bed
          	abort "Failed to create height map"
          G29 S3 P{var.ColdBedMap} ; save mesh to separate file
          if result !=0
          G29 S2 ; clear height map
          echo "Heating for nextmap"
          M291 P"Heating for next map" R"Heating" S1 T3
          M190 R{var.LowTemp}
          M116 H0 S{var.TempTolerance}; wait for any temp changes on bed to be within X degrees of target
          echo "waiting for temp to stabilise"
          G4 S{var.SoakTime}
          echo "Creating low temp bed map"
          M291 P"Creating low temp bed map" R"Low Temp Map" S1 T3
          VS
          This is same code with all " charectors replaced by *
          	echo *Homing*
          	M291 P*Homing required.  Please wait* R*Homing* S1 T3
          echo *Creating cold bed map*
          M291 P*Creating cold bed map* R*Cold Map* S1 T3
          if result !=0
          	abort *Failed to create height map*
          if result !=0
          echo *Heating for nextmap*
          M291 P*Heating for next map* R*Heating* S1 T3
          M190 R{var.LowTemp}
          echo *waiting for temp to stabilise*
          G4 S{var.SoakTime}
          echo *Creating low temp bed map*
          M291 P*Creating low temp bed map* R*Low Temp Map* S1 T3
          OwenDundefined 1 Reply Last reply Reply Quote 1
          • OwenDundefined
            OwenD @OwenD
            @owend
            In further news, I recalled that you can set the syntax file the highlighter used
            e.g
            ```perl
            gcode here
            This seems to fix the issue using pretty much any syntax language file I could guess
            e.g.
            bash
            perl
            python
            json
            Perhaps it would be wise to change the default that the forum uses to avoid this issue.
            This one uses perl
            	echo "Homing"
            if result !=0
            if result !=0
            M190 R{var.LowTemp}
            G4 S{var.SoakTime}
            droftartsundefined o_lampeundefined 2 Replies Last reply Reply Quote 2
              droftarts administrators @OwenD
              @owend thanks for working this out! It’s been bugging me for a while. Perhaps @T3P3Tony can do something about it?
              • o_lampeundefined
                o_lampe @OwenD
                @owend
                Good catch Owen!
                I read lately, that some guy wrote a gcode syntax highlighter for the forum. I didn't knew what that meant, so forgot mostly about it. Would be interesting to try that one in this context.
                //edit found him
                • T3P3Tonyundefined
                  T3P3Tony administrators
                  @droftarts et al
                  I have worked out a work around for this - it should prevent future code blocks from having the issue - but will not go back and replace existing code in existing posts.
                  I think this is limited to some keywords within the quotes as well as the quotes them selves and is a bug with the SQL and PHP autodetection highlighter line numbers are set:
                  Turn of line number for SQL and PHP:
                  so since we don't post SQL/PHP on this forum then turning off the line numbering wont impact anyone .
                  If the autodetection detects your post code as SQL/PHP then force it to be JSON or something
                  "special words & order: map, create "
                  arbitrary text
                  www.duet3d.com
