servo wiring with external power source to the duet2
639
  • undefined
    Dericka
    Hey all, im looking for a wiring diagram on how to correctly connect a servo motor to a duet2 with an external power source.
    I want to connect a buck step down module like LM2596 to the 24V power supply and use it to power a 5V servo and also connect the duet2 to the same 24V power supply and control the servo via the duet2.
    I grateful to all for the help.
    undefined 1 Reply Last reply 18 Apr 2021, 04:30 Reply Quote 0
    • undefined
      zapta @Dericka
      @dericka, does this help? https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pins
      undefined 1 Reply Last reply 18 Apr 2021, 04:46 Reply Quote 0
      • undefined
        Dericka @zapta
        @zapta I have already read through this page. Unfortunately, I could not find any information on how to properly connect an external power source for the servo.
        undefined undefined 2 Replies Last reply 18 Apr 2021, 07:33 Reply Quote 0
        • undefined
          o_lampe @Dericka
          @dericka
          Connect
          • servoGND with GND (doesn't matter where, since the buckdown converter uses common GND already) (*)
          • servo Vin with 5V
          • servo signal with Duet output pin
          *) if you want to go safe, wire DuetGND to ConverterGND and then connect ServoGND with DuetGND, but as I wrote above, the GNDs should be common already.
          • undefined
            Dericka
            My current solution looks like this. I left the jumper "JUMPER: INT 5V EN" plugged in.
            undefined 1 Reply Last reply 18 Apr 2021, 23:03 Reply Quote 0
            • undefined
              zapta @Dericka
              @dericka, since the (-) input and output fo the buck converter are shorted, you seem to have a ground loop.
              undefined 1 Reply Last reply 19 Apr 2021, 00:25 Reply Quote 0
              • undefined
                Dericka @zapta
                @zapta OK, I hope I have understood correctly
                undefined 1 Reply Last reply 19 Apr 2021, 03:33 Reply Quote 0
                • undefined
                  zapta @Dericka
                  @dericka, I would keep the ground wire between the duet and the buck converter and remove the one between the power supply and the buck converter. Motivation: this will result in cleaner signal to the servo since it's ground is more related to the Duet's.
                  Any expert here wants to chime in?
                  • undefined
                    zapta @Dericka
                    @dericka said in servo wiring with external power source to the duet2:
                    @Phaedrux , since the doc has a long discussion of power issues and mentions that "Both issues can be avoided by powering the servo from a separate +5 supply.", maybe adding a recommended wiring diagram there may help. Just a suggestion.
                    undefined 1 Reply Last reply 20 Apr 2021, 12:47 Reply Quote 3
                    • undefined
                      Dericka @zapta
                      @zapta @Phaedrux
                      That would be great and help me a lot!
                      1 out of 10
