    How can I create a toggle macro?
    Gcode meta commands
    1.4k
    • PaulHewundefined
      PaulHew
      I have chamber lights on my Printer.
      I have a macro to turn the lights off which is presented on the PanelDue.
      As you know the PanelDue front screen is limited to 4 macros, iirc.
      How can I use one button / macro to turn on or off the lights as a toggle.
      They are connected to Out1 on my Mini 5+, my config.g turns them on when I boot the printer.
      I would guess that the firmware is clever enough to know if 'Out1' was on or off, but the problem is I am not clever enough to write code to read the state and then send its opposite state.
      Could someone help, please.
      Regards,
      Paul.
      (If it was Crestron Simpl, they have a module for it!)
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      o_lampeundefined 1 Reply Last reply Reply Quote 1
      • o_lampeundefined
        o_lampe @PaulHew
        @paulhew
        A"blind" approach would be to invert a boolean variable everytime you call the macro
        in config.g:
           global lights = false
        in macro
           set global.lights != global.lights   ; invert the variable
           out1 = global.lights   ; send the new value to the output
        This code is provided without testing, so there might be errors. But you get the idea..
        jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 1
          jay_s_uk @o_lampe
          You can check in the object model if the output is on or off and then do the opposite
            dc42 administrators @o_lampe
            You can read the current state of an output from the object model, it's "state.gpout[n].pwm". So you can do it without using a global variable.
            Edit: jay beat me to it!
            Yaoundefined 1 Reply Last reply Reply Quote 1
            • PaulHewundefined
              PaulHew
              @dc42 said in How can I create a toggle macro?:
              state.gpout
              Appreciate the input you have given, maybe I need to start at the beginning.
              This is my config for my Lights
              ;Lights
              M950 F10 C"out1"
              M106 P10 S0 H-1 C"Front Lights"
              M106 P10 S1
              It looks correct, it works. Personally it would be better if it was an on/off and not PWM'd, Do not think I require mood lighting on my chamber lights 😉
              So after enabling Object Model Browser, I found F10 under Fans and it shows the correct info as in my config.
              I change the lights on and off and it changes 'actualValue'
              Not being as clever as you guys but willing to learn, how do I query 'Fan.10' actualValue'?
              I sort of understand the 'if' part
              if 'actualValue' = 1
              then set to 0
              Elif 'actualValue' = 0
              set to 1
              Personally, it would be handy if there were some basic 'Meta Guides' to help us understand how to write queries and some simple ones we could implement to advance our learning.
              Like if the printer is not homed, then home it and how to turn on /off lights with a one button macro!
              Much like you have done with the RRF configurator, it explains the function which has helped me learn a lot.
              I did search for the "state.gpout[n].pwm" and variations in the dozuki and could not find any reference to it.
              Again, Thanks in advance.
              OwenDundefined 1 Reply Last reply Reply Quote 0
              • OwenDundefined
                OwenD @PaulHew
                @paulhew said in How can I create a toggle macro?:
                state.gpout
                ;Lights
                M950 F10 C"out1"
                M106 P10 S1
                then set to 0
                set to 1
                try here
                https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
                If you look through the meta commands topic section of the forum there are many examples which should help you understand.
                https://forum.duet3d.com/category/34/gcode-meta-commands
                You have to use the object model to reference the proper name & syntax for the GPIO output, fan or whatever.
                In our case, you're using a fan output, not a GPIO pin.
                So you need to look in the fans section of the object browser.
                Fan outputs are PWM capable, so that you can set a fan to any speed.
                In your case, you can just set it to 0 or 1 using M106.
                A GPIO output would be set by M42
                in terms of code you could have something like
                if fans[10].actualValue = 1
                	M106 P10 S0
                else
                	M106 P10 S1
                This example is only meant for an LED connected to a fan ouput that is only ever set full on, or full off.
                PaulHewundefined 1 Reply Last reply Reply Quote 4
                • PaulHewundefined
                  PaulHew @OwenD
                  @owend said in How can I create a toggle macro?:
                  Thank You for your reply.
                  I did not know there was a Meta Commands section in the forum.
                  I have learnt and understand a little more now, thank you.
                  Regards,
                  Paul.
                  • Yaoundefined
                    Yao @dc42
                    @dc42 is something like this (led toggle on/off with if-else macro) also possible for OUT1 on duet3 board ?
                    I can't seem to get it to work...
                    Thanks.
                    • OwenDundefined
                      OwenD @Yao
                      @yao
                      Yes it is.
                      Please post what you have so far.
                      Both config.g and macro so we know how you're configuring the pin and how you're controlling it.
                      Yaoundefined 1 Reply Last reply Reply Quote 0
                      • Yaoundefined
                        Yao @OwenD
                        @owend Hi, thanks for your response,
                        in the config:
                        ; white led chamber light ALL
                        M950 P25 C"out1" ;use main out1 for full Chamber light
                        M42 P25 S0.5 ;on 50%
                        this can be adjusted with:
                        ; chamber lights hi
                        M42 P25 S1
                        ; chamber lights low
                        M42 P25 S0.02
                        I was trying:
                        if out1[25].actualValue >= 0.8
                        M42 P25 S0.02
                        else
                        M42 P25 S1
                        whatever I try i get unknow value 'out1'
                        • OwenDundefined
                          OwenD @Yao
                          @yao
                          What board are you using?
                          On my Duet 2 running RRF3.4 , the output port limit seems to be 20.
                          Do you really need it to be 25?
                          Try using a lower number
                          And your code should look like
                          if state.gpOut[nn].pwm >= 0.8
                          • Yaoundefined
                            Yao @OwenD
                            @owend !!! that works!
                            I am running a duet3. my lights start at P20.
                            originally from the 3HC (hence the P20 range) but I ran out of connections so moved back to the main. for clarity for myself I kept the lights within the P20 range.
                            using the following now:
                            if state.gpOut[25].pwm >= 0.8
                            M42 P25 S0.02
                            else
                            M42 P25 S{state.gpOut[25].pwm + 0.2}
                            I now have 5 steps to full brightness and then it toggles to almost off.
                            Thanks for this. I have to investigate more into correct names and designations for usage of pins. I am not C minded, more of a mechanical guy. It amazes me every time how garbled the expression stackups need to be..
                            what does the 'pwm' mean? and why does it need to be there?
                            • OwenDundefined
                              OwenD @Yao
                              @yao
                              Is not really that complicated
                              It's a hierarchical structure no different to your street address. Country/state/city/street/number/unit
                              These are not official designations but...
                              State - refers to functions on the board you might normally monitor
                              GPout[] - refers to the GP output pins as a whole (analogous with your street). It's an array, so you need a port number to identify an individual pin (house number)
                              pwm - refers to the PWM (pulse width modulation) value of that pin. You need that because the pin may have many different properties that are applied. e.g (name, inversion etc). Just as a street number may have one or 100 dwellings. If you don't address the right one, your letter may not get there.
                              If you use the object model browser it becomes easy and you can copy the correct syntax with the button provided.
                              Yaoundefined 1 Reply Last reply Reply Quote 2
                              • Yaoundefined
                                Yao @OwenD
                                @owend @owend Never had such a clear explanation is this!
                                But, is there a clear 'roadmap' where i can find all these specific DUET adresses, numbers, extensions and designations?
                                Where can I find the 'object model browser' :
                                this ?: https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation#overview
                                I can't find the specific addresses you mention in that list.
                                M409 gives me an empty list of strings...
                                • OwenDundefined
                                  OwenD @Yao
                                  @yao
                                  This post shows you how to look at the object model browser
                                  https://forum.duet3d.com/post/277538
                                  apakundefined 1 Reply Last reply Reply Quote 1
                                  • apakundefined
                                    apak @OwenD
                                    some where I found this some time ago
                                    Macro "leds on/off"
                                    if state.gpOut[1].pwm == 1
                                       M42 P1 S0
                                    else
                                       M42 P1 S1
                                    in config files
                                    ; LEDS
                                    M950 P1 C"e1heat" Q500							;use heater 1 outupt for LED
                                    M42 P1 S1										; turn off LEDS
