    BLTouch won`t home
    Accessories and Add-ons
    954
    • Chrabbanundefined
      Chrabban
      Hello everyone, i havent used my 3D printer for about a year. I wanted to get back into it and wanted to know if there was any firmware upgrades, and yes there was. 3.1.1. and now my BLTouch dosent work. i even did a total reset and used the RRF Config tool. but i couldn't get it to work.
      before the update it looked like this
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z1.842 ; set Z probe trigger value, offset and trigger height
      M557 X20:280 Y75:270 S20 ; define mesh grid
      and now after the Config tool it is like this
      M558 P1 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      I have tried a few things that i have seen from othere threds or youtube videos, it might be a very easy thing that is wrong but i just cant get it to work. The probe is on Z-prob in
      i hope someone got the time to help
      have a nice day all.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @Chrabban
        @chrabban said in BLTouch won`t home:
        M558 P1
        That is the wrong probe type
        Should be
        M558 P9
        (UTC+1)
        Chrabbanundefined 1 Reply Last reply Reply Quote 0
        • Chrabbanundefined
          Chrabban @DIY-O-Sphere
          @diy-o-sphere said in BLTouch won`t home:
          M558 P9
          sadly it didet work, something els might be wrong then
            Can you post your full config.g?
            Also send M122 and M98 P"config.g" and post the results.
            Also post your homeall.g
            What exactly doesn't work?
            Does the pin drop and retract at power on?
            If you send M401 and M402 does the pin deploy and retract?
            • Chrabbanundefined
              Chrabban @Phaedrux
              @phaedrux
              At startup it does that lite out-in-out-in and then stays in and shines red. i also get an error about Z-stop
              M401 and M402 dosent work
              here is the M122
              2021-05-02 11:46:28 M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-917DA-G4MS8-6JKD2-3SN6M-TTVR9
              Used output buffers: 3 of 24 (14 max)
              Static ram: 23460
              Dynamic ram: 73460 of which 24 recycled
              Never used RAM 15136, free system stack 191 words
              Tasks: NETWORK(ready,179) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:01:28 ago, cause: power up
              Last software reset at 2021-05-01 23:11, reason: User, GCodes spinning, available RAM 15104, slot 1
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 22.4, current 27.1, max 27.6
              Supply voltage: min 11.8, current 11.9, max 12.0, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max not available
              Driver 1: position 0, standstill, SG min/max not available
              Driver 2: position 0, standstill, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-05-02 11:46:25
              Cache data hit count 106020349
              Slowest loop: 8.54ms; fastest: 0.21ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 3.9ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 17.49ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.25
                WiFi MAC address 60:01:94:2e:d5:7f
                WiFi Vcc 3.33, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 23920
                WiFi IP address 192.168.0.12
                WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
              And
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Error: Bad command: Z-Probe
              I might have changed something in this trying to fix it
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid)
              G91 ; relative positioning
              G1 H2 Z5 F12000 ; lift Z relative to current position
              G1 H1 X-305 Y-275 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F12000 ; go back a few mm
              G1 H1 X-305 Y-275 F360 ; move slowly to X and Y axis endstops once more (second pass)
              G1 H1 Z-405 F360 ; move Z down stopping at the endstop
              G90 ; absolute positioning
              G92 Z1 ; set Z position to axis minimum (you may want to adjust this)
              G1 Z5 F200 ; lift Z relative to current position
              Chrabbanundefined DIY-O-Sphereundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
              • Chrabbanundefined
                Chrabban @Chrabban
                What dosent work is that it cant home, ethere with home all or by it self after X and Y is homed. dont know if the Bed-levelling works or not sens i cant home it
                  @chrabban
                  Please post content of
                  retractprobe.g and deployprobe.g
                  Edit:
                  deployprobe.g
                  content should be:
                  M280 P0 S10
                  retractprobe.g
                  content should be:
                  M280 P0 S90
                  (UTC+1)
                    That's wrong for the Bl-touch
                    replace that with
                    G1 X150 Y130 F6000        ; go to first bed probe point and home Z
                    G30                     ; home Z by probing the bed
                    Please also post content of homez.g
                    Edit:
                    But that alone will not solve the issue, you first have to get the probe to react to M401 and M402
                    (UTC+1)
                    • Chrabbanundefined
                      @diy-o-sphere
                      Tnx for all the help, i will be home in a few hours i will test it then 🙂
                        Phaedrux Moderator @Chrabban
                        Post your config.g. You're probably missing a ; to comment out a line.
                        This is setup to use an endstop, not the probe. Replace those lines with
                        G1 X150 Y150 F6000 ; move probe to center of bed
                        G30 ; probe the bed with the probe
                        And your deployprobe.g and retractprobe.g files need to be in the /sys/ folder with the correct commands in them.
                        EDIT: @DIY-O-Sphere has ya covered.
                        • Chrabbanundefined
                          Chrabban @Phaedrux
                          @phaedrux Hello, i tried it and now it will home the Z axis but when the probe have probed the middle of the bed it just starts to go up and up and up 😛 any ideas ? 🙂 The M401 and M402 works also by the way 🙂
                            @chrabban
                            Please provide the config. g
                            (UTC+1)
                            Chrabbanundefined 1 Reply Last reply Reply Quote 1
                            • Chrabbanundefined
                              @diy-o-sphere
                              here it is
                              M550 P"CR-10" ; set printer name
                              M552 S1 ; enable network
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M569 P0 S0 ; physical drive 0 goes backwards
                              M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
                              M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                              M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S20 ; Set idle timeout
                              M208 X300 Y270 Z400 S0 ; set axis maxima
                              Z-Probe
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                              M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
                              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                              M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                              M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
                              T0 ; select first tool
                                Add that at the end of the section
                                M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
                                (UTC+1)
                                  What does your homeall look like now?
                                  • Chrabbanundefined
                                    Chrabban @Phaedrux
                                    @phaedrux it looks like this 🙂
                                    ; homeall.g
                                    • Chrabbanundefined
                                      @diy-o-sphere
                                      now when it tries to home Z it goes upp insted of down to check bed lvl and wont stop, this worked before but it whold run away after the bed lvl check
                                        I don't suppose you could show a video of what it's doing?
                                          Can't get why....
                                          Just one point to look at later on: Bltouch offset
                                          X0 Y0 can't be right, means Bltouch is mounted in the center of the nozzle
                                          (UTC+1)
                                          • Chrabbanundefined
                                            Chrabban @Phaedrux
                                            @phaedrux
                                            sorry for the late awnser, sick kids has taken almost all of my time.
                                            well it just homes y and x then goes to the center and goes of into space 😛 it dosent do anything els
