    600 PPR 5v rotary encoder filament monitor help
    509
    • CNCModellerundefined
      CNCModeller
      Hi All,
      Just trying to get my DIY filament monitor running but I'm getting a no calibration data statement. I've used these encoders on several Arduino projects and haven't had a single hiccup until now.
      This is my config file entry:-
      M591 D0 P7 C"io4.in" S1 R1:1000 L0.0523 E0.1
      L0.0523 = 10mm drive wheel, at 600ppr = 10 x 3.14 / 600
      Prior to extrusion (200mm)
      23/05/2021, 14:34:51 m591 d0
      Pulse-type filament monitor on pin io4.in, enabled, sensitivity 0.052mm/pulse, allowed movement 1% to 1000%, check every 0.1mm, no data received
      After 200m extrusion
      23/05/2021, 14:35:30 m591 d0
      Pulse-type filament monitor on pin io4.in, enabled, sensitivity 0.052mm/pulse, allowed movement 1% to 1000%, check every 0.1mm, no calibration data
      This is the encoder:-
      https://www.amazon.co.uk/gp/product/B015GYY7XU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
      Output
      AB two -phase quadrature output rectangular pulse ,the circuit output is NPN open collector output type ,the output of this type can and with internal pull-up resistor is directly connected MCU or PLC ,such as 51 single or Mitsubishi PLC (PLC input mode should be connected to 0V switch function).
      The Encoder is connected on IO_4 as follows:
      5V_Ext - Enc Vcc
      GND - Enc V0
      io4.in - Enc Phase A
      From the encoder output description above do I need a pullup resistor on io4.in?
      General Arrangements
      Any constructive thoughts would be much appreciated.
      Cheers
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      alankilianundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @CNCModeller
        @cncmodeller Yes, you can try just turning on the built-in pullup by adding a '^' character when you define the pin used.
        Pin configuration documentation
        M591 D0 P7 C"^io4.in" S1 R1:1000 L0.0523 E0.1
        CNCModellerundefined 1 Reply Last reply Reply Quote 0
          CNCModeller @alankilian
          @alankilian said in 600 PPR 5v rotary encoder filament monitor help:
          Thanks @alankilian, unfortunately no change after setting the pullup resistor as you suggested... bugger lol
          Not sure where to go from here...
          Will put my thinking cap on...
          Many thanks
          Barry M
          Wanhao D4S: Duet2
          K40 Laser, Duet2
          Wanhao D5S
          alankilianundefined 1 Reply Last reply Reply Quote 0
            @cncmodeller
            5V_Ext - Enc Vcc
            5V_Ext is not a sourse of 5 Volts. It's an INPUT for external 5 Volt power supply. There's a diode in the way so you cannot power the encoder from that pin.
            Try a different source of 5 Volts.
              @alankilian
              There's definitely 5v on that pin, I've just checked with my multimeter.
              And the documentation says the IO 0 thru 4 supply 5v.
              Or am I missing something here?
              Wanhao D4S: Duet2
              K40 Laser, Duet2
              Wanhao D5S
                @cncmodeller Oh, I see, I was thinking you had connected to 5V_EXT_IN.
                Sorry.
                I'm out of ideas.
                Can you connect an LED or something to the encoder output and see if it blinks when you turn the encoder? That would verify it's getting power and producing a signal.
                  Sorry.
                  I'm out of ideas.
                  Good idea, I'll give it a go tomorrow evening. 🙂
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                  Alex.crundefined 1 Reply Last reply Reply Quote 0
                  • Alex.crundefined
                    Alex.cr @CNCModeller
                    @cncmodeller how did you perform your 200 mm extrusion to test the encoder? It sounds like you just commanded the extruder move manually.
                    The filament monitor code only works when running a job through the SD card. If you haven’t, try running a print and when you are a few layers in check with M591 as you did before.
                    Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                    CNCModellerundefined 2 Replies Last reply Reply Quote 1
                      CNCModeller @Alex.cr
                      @alex-cr thanks, I'll check it out.
                      The monitor may have been working as I had a print pause last night, but unfortunately I don't know why as DWC stopped working too. I have another thread following that up.
                      Many thanks
                      Barry M
                      Wanhao D4S: Duet2
                      K40 Laser, Duet2
                      Wanhao D5S
                      • o_lampeundefined
                        o_lampe @CNCModeller
                        @cncmodeller said in 600 PPR 5v rotary encoder filament monitor help:
                        The Wiki doesn't specify if it expects a positive or negative pulse for a P7 sensor?
                        Did you try to invert the pin with "!"?
                        The default value for 'E' is 3mm, are you sure it accepts 0.1mm? Maybe the polling frequency is too high then?
                        OTOH your R-values are pretty 'generous', this doesn't make sense with the fine E-polling.
                        Another thing I'm worried about is the L-value. It's already truncated to 0.052. How can you calibrate it, when the last digit is already cut off?
                          CNCModeller @o_lampe
                          @o_lampe said in 600 PPR 5v rotary encoder filament monitor help:
                          @o_lampe I'm now getting the following response which is great:
                          24/05/2021, 13:15:01 m591 d0
                          Pulse-type filament monitor on pin io4.in, enabled, sensitivity 0.052mm/pulse, allowed movement 1% to 1000%, check every 0.1mm, measured sensitivity 0.058mm/pulse, measured minimum 63%, maximum 150% over 441.9mm
                          I get where you are coming from, a couple of more decimal places for the calibration value may be necessary given the resolution of the encoder.
                          I'm going to set the sensitivity to 0.058mm/pulse and see how far out it is on my next test print.
                          Many thanks folks, glad this is working now 🙂
                          All the best
                          Barry M
                          Wanhao D4S: Duet2
                          K40 Laser, Duet2
                          Wanhao D5S
                            @alex-cr said in 600 PPR 5v rotary encoder filament monitor help:
                            @Alex-cr you were right... its responding now I've tried it during a test print. Thanks very much for your input, very helpful! 🙂
                            Barry M
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
                            alankilianundefined 1 Reply Last reply Reply Quote 1
                              @cncmodeller GREAT NEWS Barry!
                              I was stumped. It seemed like you had everything right (which you did) and I learned something new from this thread.
