    No WiFi this morning !?
    Using Duet Controllers
    1.4k
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk
      Maybe, how do I get the board to respond?
        jay_s_uk @tecno
        @tecno well i suggest following this https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_Check_the_voltage_indication_LEDs
        check your sd card to see if config.g is there and what its contents is
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @jay_s_uk
          @jay_s_uk
          LED's are lit
          config.g is there and all looks familiar
            jay_s_uk @tecno
            @tecno send these over USB
            M552 S0
            M552 S1
            let us know what the output is
            • tecnoundefined
              tecno @jay_s_uk
              @jay_s_uk
              As I wrote earlier this morning:
              In red, terminal response to what ever command is sent
              Warning : x bytes not sent anymore
                jay_s_uk @tecno
                @tecno no idea then. never seen that warning, especially not in red. all terminal programs I use are black and white
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                  YAT
                  But.... now the bloody bord is working with another IP
                  How do I set fixed IP ??
                    jay_s_uk @tecno
                    @tecno using M587 https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                    or the better way is to reserve the IP at the router side
                    • tecnoundefined
                      tecno @jay_s_uk
                      @jay_s_uk
                      Thanks Jay!
                      Went M587 way as my router is not so friendly 😉
                        droftarts administrators @tecno
                        @tecno Did both config.g and config.g.bak disappear, or did you have a config.g that was blank? Did you edit config.g before last reset/power off? See my reply here https://forum.duet3d.com/post/233267
                        • tecnoundefined
                          tecno @droftarts
                          @droftarts
                          Today everything was on the card, it just didn´t boot. So card out to see what was there and back was all it took to start working with another IP
                            @tecno Have you replaced the SD card? And can you have a close look at the SD card socket, see https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
                            • tecnoundefined
                              tecno @droftarts
                              @droftarts
                              No
                              Will take a look next time I dig out the printer from its cabinette.
                                Phaedrux Moderator @Phaedrux
                                @phaedrux said in No WiFi this morning !?:
                                @tecno said in No WiFi this morning !?:
                                WiFi firmware version 1.24beta2-05b1
                                Your wifi server version needs to be updated.
                                Place this bin file in your firmware folder and then boot up and send M997 S1 to re-flash the wifi module.
                                https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWiFiServer.bin
                                Then check M122 again it should show the wifi server version as 1.26.
                                Were you able to update the wifi server?
                                • tecnoundefined
                                  tecno @Phaedrux
                                  @phaedrux
