    No WiFi this morning !?
    Using Duet Controllers
    1.4k
    • tecnoundefined
      tecno @tecno
      @tecno
      Now X and Y are moving in wrong direction (I know the did work OK with that copy of config.g
      What is going on here?
      • o_lampeundefined
        o_lampe @tecno
        @tecno said in No WiFi this morning !?:
        Check the forum, there are others with SD-Card issues on Duet Mini5. Might be a bad batch or soldering issues?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @o_lampe
          @jay_s_uk
          Got it all sorted out .................. phuu 😉
          How do I ge a backup of 0:/system ?
          How to move firmware files to 0:/firmware ?
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            jay_s_uk @tecno
            @tecno you can either tick the little check box at the top of the system files tab and then right click and download as zip or you can use something like FTP to download everything. There is a utility for this here
            To move things to the firmware folder its going to be a case of deleting whatever is present in system and let the firmware handle it going forwards. Or pull the sd card and manually move the files over
            • tecnoundefined
              tecno
              @jay_s_uk
              Right clikck > download does not exist here! Did read about it but nothing here. That would someting I prefere rather that be using RFM.
              Is this a bug in latest RC ?
              ps. Why do I get ERROR down in right corner when I want to Submit?? I have to restart forum
                jay_s_uk
                @tecno I get that restart error sometimes when submitting
                latest RC
                Make sure you right click in the area of the files, not on the tick box itself
                tecnoundefined 1 Reply Last reply Reply Quote 1
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                  This is what I get
                    jay_s_uk @tecno
                    @tecno you can't download directories as part of the zip. uncheck them and you should be good to go
                    • tecnoundefined
                      tecno @jay_s_uk
                      @jay_s_uk
                      Thank you very much Jay, much appreciated!
                        Phaedrux Moderator @tecno
                        WiFi firmware version 1.24beta2-05b1
                        Your wifi server version needs to be updated.
                        Place this bin file in your firmware folder and then boot up and send M997 S1 to re-flash the wifi module.
                        https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWiFiServer.bin
                        Then check M122 again it should show the wifi server version as 1.26.
                        tecnoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • tecnoundefined
                          tecno @Phaedrux
                          Well here I am again with no connection with my Mini 5+ other that terminal connects but accepts no commands at all !
                          Urgent help needed how to proceed .
                          • o_lampeundefined
                            o_lampe @tecno
                            @tecno
                            You might need a USB hub to have enough power to feed the Duet? Just guessing...
                            What kind of commands did you try?
                            • tecnoundefined
                              tecno @o_lampe
                              @o_lampe
                              Power via printers PSU
                              M552 to check if WiFi is active or not
                              • o_lampeundefined
                                o_lampe @tecno
                                @tecno
                                Fair enough. What about M115 or M122? Just to see, if the SD-card has been read or not
                                • tecnoundefined
                                  tecno
                                  @o_lampe
                                  In red, terminal response to what ever command is sent
                                  Warning : x bytes not sent anymore
                                  • tecnoundefined
                                    tecno
                                    Anyone to help me?
                                      jay_s_uk @tecno
                                      @tecno sounds like you lost your config.g again?
                                      • tecnoundefined
                                        tecno @jay_s_uk
                                        @jay_s_uk
                                        Maybe, how do I get the board to respond?
                                          jay_s_uk @tecno
                                          @tecno well i suggest following this https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_Check_the_voltage_indication_LEDs
                                          check your sd card to see if config.g is there and what its contents is
                                          • tecnoundefined
                                            tecno @jay_s_uk
                                            @jay_s_uk
                                            LED's are lit
                                            config.g is there and all looks familiar
