    No WiFi this morning !?
    Using Duet Controllers
    1.4k
    • tecnoundefined
      tecno @jay_s_uk
      @jay_s_uk
      Thank you very much Jay, much appreciated!
        Phaedrux Moderator @tecno
        @tecno said in No WiFi this morning !?:
        WiFi firmware version 1.24beta2-05b1
        Your wifi server version needs to be updated.
        Place this bin file in your firmware folder and then boot up and send M997 S1 to re-flash the wifi module.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWiFiServer.bin
        Then check M122 again it should show the wifi server version as 1.26.
        tecnoundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        • tecnoundefined
          tecno @Phaedrux
          Well here I am again with no connection with my Mini 5+ other that terminal connects but accepts no commands at all !
          Urgent help needed how to proceed .
          • o_lampeundefined
            o_lampe @tecno
            @tecno
            You might need a USB hub to have enough power to feed the Duet? Just guessing...
            What kind of commands did you try?
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @o_lampe
              @o_lampe
              Power via printers PSU
              M552 to check if WiFi is active or not
              • o_lampeundefined
                o_lampe @tecno
                @tecno
                Fair enough. What about M115 or M122? Just to see, if the SD-card has been read or not
                • tecnoundefined
                  tecno
                  @o_lampe
                  In red, terminal response to what ever command is sent
                  Warning : x bytes not sent anymore
                  • tecnoundefined
                    tecno
                    Anyone to help me?
                      jay_s_uk @tecno
                      @tecno sounds like you lost your config.g again?
                      • tecnoundefined
                        tecno @jay_s_uk
                        @jay_s_uk
                        Maybe, how do I get the board to respond?
                          jay_s_uk @tecno
                          @tecno well i suggest following this https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_Check_the_voltage_indication_LEDs
                          check your sd card to see if config.g is there and what its contents is
                          • tecnoundefined
                            tecno @jay_s_uk
                            @jay_s_uk
                            LED's are lit
                            config.g is there and all looks familiar
                              jay_s_uk @tecno
                              @tecno send these over USB
                              M552 S0
                              M552 S1
                              let us know what the output is
                              • tecnoundefined
                                tecno @jay_s_uk
                                @jay_s_uk
                                As I wrote earlier this morning:
                                  jay_s_uk @tecno
                                  @tecno no idea then. never seen that warning, especially not in red. all terminal programs I use are black and white
                                  • tecnoundefined
                                    tecno @jay_s_uk
                                    @jay_s_uk
                                    YAT
                                    But.... now the bloody bord is working with another IP
                                    How do I set fixed IP ??
                                      jay_s_uk @tecno
                                      @tecno using M587 https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                                      or the better way is to reserve the IP at the router side
                                      • tecnoundefined
                                        tecno @jay_s_uk
                                        @jay_s_uk
                                        Thanks Jay!
                                        Went M587 way as my router is not so friendly 😉
                                          droftarts administrators @tecno
                                          @tecno Did both config.g and config.g.bak disappear, or did you have a config.g that was blank? Did you edit config.g before last reset/power off? See my reply here https://forum.duet3d.com/post/233267
                                          • tecnoundefined
                                            tecno @droftarts
                                            @droftarts
                                            Today everything was on the card, it just didn´t boot. So card out to see what was there and back was all it took to start working with another IP
