    using a Thyristor Module for heatbed?
    406
    • tazlaundefined
      tazla
      Hi would it work to use a
      SKKT 57/12E Thyristor Module with the duet 6hc?
      using 24v output from Out0, to control 220vac
      https://www.tme.eu/en/details/skkt57_12e/thyristor-modules/semikron/skkt-57-12e/
      //sven
      jens55undefined 1 Reply Last reply Reply Quote 0
      • jens55undefined
        jens55 @tazla
        @tazla, what advantage does this module give you that a standard SSR does not ?
        tazlaundefined 1 Reply Last reply Reply Quote 0
        • tazlaundefined
          tazla @jens55
          @jens55 not more than i can get them for free but i never used any so i dont know how they work
          • jens55undefined
            jens55 @tazla
            @tazla, gotcha. 'Free' is a powerful motivator 🙂
            My take on the situation as far as I understand it (not very far)- the standard SSR has isolation between the trigger circuit and the power circuit (4 terminals). A Thyristor is a three terminal device that would rely on the same ground between trigger and the power circuit.
            I would not attempt to use this device. SSR's are proven to work perfectly.
            In addition, I think a Thyristor can switch off current at any point in the AC wave cycle which in the application of a heated bed controller could generate all kinds of EMI.
              Given the generally low cost of applicable DC-AC SSR units I don't think it's worth it.
              • tazlaundefined
                tazla @Phaedrux
                @phaedrux ok then i use a ssr to be safe
                • jens55undefined
                  jens55 @tazla
                  @tazla, good choice !
                  • o_lampeundefined
                    o_lampe @jens55
                    @jens55 said in using a Thyristor Module for heatbed?:
                    IIRC it's the opposite way: they have a 'zero-crossing' detector to switch OFF at 0V, but depending on the PWM switch ON at any voltage.
                    Nevertheless, they might be an interesting option for 24V - 60V AC consumers. The PSU would be more economic. (no rectifier losses)
                    Just a minor point for most of us.
                    • gloomyandyundefined
                      gloomyandy
                      I'm pretty sure that a Thyristor (unlike a Triac) will only conduct the voltage in one direction, so if this module really is just a Thyristor you will only get half of the AC waveform.
                        dc42 administrators @gloomyandy
                        @gloomyandy yes a thyristor conducts one way only. They can be used in conjunction with bridge rectifiers to control AC, but triacs have less voltage drop than this arrangement; so triacs are more commonly used when AC needs to be switched. For switching high current AC, a pair of back-to-back thyristors is another option.
                        • o_lampeundefined
                          o_lampe
                          Right, I confused that. And I'm almost sure it's a Triac that has 'zero-crossing' detection.
                          I forgot that I have Alzheimers 😉
                            dc42 administrators @o_lampe
                            @o_lampe said in using a Thyristor Module for heatbed?:
                            All triacs turn off at zero crossing. Most DC-AC SSRs have additional circuitry so that they only turn on just after the zero crossing too.
