    Replacement ball studs - reseller?
    235
    • vwegert
      vwegert last edited by
      Hi all,
      I'm using the Haydn Huntley arms on a smart effector with the mounting system bought via the Duet3D store several years ago. Recently I've noticed something bad has apparently happened. A ring of black gunk appeared on the chrome balls, and when I removed and cleaned the joints, I could see that somehow the chrome (?) plating of the balls has been abraded to a significant portion.
      Long story short - I need new replacements (2x sets of 6 https://www.duet3d.com/DuetAddons/BallStudEnds), but I have a hard time finding a reseller in Europe, if possible Germany. Does anyone know of a reseller that has these items in stock?
      (Also - will I have to replace the rods as well? I hope not....)
      Thanks
      Volker
      o_lampe DeadNewbie 2 Replies Last reply Reply Quote 0
      • o_lampe
        o_lampe @vwegert last edited by
        @vwegert said in Replacement ball studs - reseller?:
        Hallo Volker,
        If you also see a spot on the magnet, your Delrin sleeves are bad. I'm located in 'Kassel' and I have a few parts (mags, sleeves, balls) laying around, so you could build your own rods. But equal length is very important. I made a rig, but it wasn't perfect.
        Alles weitere dann gern per PM
        Olaf
        • vwegert
          Here are some images from the effector side (after cleaning the lubricant and black gunk):
          and the carriage side:
          The other rods look similar.
            dc42 administrators @vwegert last edited by
            Perhaps you should get in touch with Haydn and ask him for advice? https://www.magballarms.com/
            apak 1 Reply Last reply Reply Quote 0
            • apak
              apak @dc42 last edited by
              Here a bunch of spanish guys are using this ptfe tape on our hayden´s arms.
              photo_2021-06-01_11-15-21.jpg photo_2021-06-01_11-15-22.jpg photo_2021-06-01_11-15-23.jpg photo_2021-06-01_11-15-24.jpg
              vwegert 1 Reply Last reply Reply Quote 2
              • vwegert
                vwegert @apak last edited by
                @apak Do you have any experience with using UHMW PE tape instead of teflon?
                • DeadNewbie
                  DeadNewbie @vwegert last edited by
                  @vwegert I found them here, sorry for the delay.
                  https://filament23d.dk/en-gb/haydn-huntley-s-ball-stud-ends-for-magball-delta-arms-haydn-huntley-s-ball-stud-ends-for-magball-delta-arms
                  • o_lampe
                    o_lampe last edited by
                    The magnets seem to be nickel plated and the ballstuds are chrome plated. Easy to see where's more wear.
                    The tape solution seems the best workaround. (maybe punch a hole in the center of the tape to avoid contact to the magnet?)
