    Can deform 4mm print glass
    241
    • peter247
      peter247 last edited by
      Hi , building up my blv cube and doing a little setting up , homing , offsets , levelling etc.
      This is my first test of mesh levelling with the 4mm aluminium plate which came with my cr10s pro v1 and it's glass which replaced it.
      ( It is just a test waiting for a ALUMINIUM TOOLING PLATE .)
      This is cold and the aluminium plate is no way level , BUT is this the glass or have I got a mechanical error somewhere ?
      Still missing some screws so can't print yet , which should tell me if I've got z problems.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      Martin1454 deckingman 2 Replies Last reply Reply Quote 0
      • Martin1454
        Martin1454 @peter247 last edited by
        @peter247 What type of probe do you have? the result looks acceptable, but if anything my guess is on the probe or mechanical issue
        peter247 1 Reply Last reply Reply Quote 0
        • peter247
          peter247 @Martin1454 last edited by
          @martin1454 Bltouch
          jens55 1 Reply Last reply Reply Quote 0
          • jens55
            jens55 @peter247 last edited by
            @peter247, for a standard off the shelf printer, this is about as good as it gets, Be happy !
              @peter247 what type of machine is the CR10S pro V1? Does the bed move in Y, or the gantry? If the gantry moves in both X and Y then I think the Y gantry is sagging a little.
              • deckingman
                deckingman @peter247 last edited by
                @peter247 said in Can deform 4mm print glass:
                .................................. This is cold and the aluminium plate is no way level , BUT is this the glass or have I got a mechanical error somewhere ?....................
                It's pretty close, but it's impossible to discriminate between the gantry sagging or the glass being bowed by looking at the height map. I find a precision straight edge is invaluable. With one of those and good lighting, it's quite easy to determine if the glass (or aluminium plate) is flat or not. If you don't want to spend too much money, look for a plasterers feather edge - something like this https://www.amazon.co.uk/Faithfull-Feather-Edge-Scale-Fe48/dp/B0001IWKOA/ref=asc_df_B0001IWKOA/?tag=googshopuk-21&linkCode=df0&hvadid=309808827530&hvpos=&hvnetw=g&hvrand=2730341869416505663&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046150&hvtargid=pla-588189221888&psc=1&th=1&psc=1
                • peter247
                  peter247 @dc42 last edited by peter247
                  @dc42 The cr10s pro v1 moves the Y axis , But I'm just use it for it's metal plate , so the cr10s pro is just used for parts until I get something better, for this core xy I'm working on .
                  Not sure how much sag you can get with linear rails ?
                  • peter247
                    peter247 @jens55 last edited by
                    @jens55 It is worse than off the self , it's a self build so there is a million ways I could have built it wrong.
                    But it is a start and I haven't finished building it yet, waiting for screws which hold the extruder in place, etc .
                    It was just a question of can the printer's glass bed bow than much ?
                    dc42 jens55 2 Replies Last reply Reply Quote 0
                      dc42 administrators @peter247 last edited by dc42
                      Do you mean that it moves the bed in the Y axis?
                      It's more likely that the Y gantry (if it has one) is sagging in the middle, especially if it is carrying the weight of the X motor.
                      • peter247
                        @dc42 the height map is from this :
                        https://www.blvprojects.com/blv-mgn-cube-3d-printer
                        • jens55
                          Neither one of my two operational printers has a build bed that flat. I would be very happy indeed with that outcome. Mind you both are bed slingers so several levels below what you are building ....
                          Yes, a glass bed can bow that much. Rotate the glass 90 degrees and do another bed probe to see if the hump moves with the glass.
                          Phaedrux peter247 2 Replies Last reply Reply Quote 1
                            Phaedrux Moderator @jens55 last edited by
                            @jens55 said in Can deform 4mm print glass:
                            • peter247
                              @jens55 Not sure if this is my only problem .
                              It was a fitting what I had in hand to test it out and my countersunk screws was a little short so could not fit a nut to hold the screw in place , So I think that the glass bed may have been resting on the screws edges and not the bed it's self .
                              Now I have got all my remaining screw I hope it is time to do a test print , which should show up any z wobble and out of squareness.
                              • peter247
                                peter247 @peter247 last edited by
                                @jens55 @dc42 @deckingman
