    Accelerometer Usage
    Beta Firmware
    25
    191
    20.0k
      dc42 administrators @CCS86
      @ccs86 I can't see anything wrong with the wiring or configuration command; so I guess it's an issue of cable length. How long is the cable? A 900mm long multicore cable is working OK for me on a Duet WiFi.
      Have you tried temporarily unplugging the PT100 daughter board?
      CCS86undefined 1 Reply Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @dc42
        @dc42 said in Accelerometer Usage:
        I just tried unplugging the daughterboard and still not finding the accelerometer.
        I may try re-wiring with a CAT6 cable, if there aren't any other easier steps to take.
        Phaedruxundefined Ducati87undefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @CCS86
          @ccs86 Are you using a Maestro board?
          • CCS86undefined
            CCS86 @Phaedrux
            @phaedrux said in Accelerometer Usage:
            Yes.
            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
              @ccs86 said in Accelerometer Usage:
              Yes.
              The lack of floating point unit makes accelerometer usage problematic. I didn't even think there was a build for the Maestro.
                @ccs86 when we are happy with the performance of input shaping on boards that have floating point hardware, we will look at the feasibility of doing a build for the Maestro.
                • CCS86undefined
                  CCS86 @Phaedrux
                  Yes.
                  It is my understanding that accelerometer usage is okay, with the potential issue being in running input shaper. I'd still like to start measuring with the accelerometer for a baseline and for mechanically trying to improve resonance.
                  @dc42 Can confirm if that is the case.
                    @ccs86 confirmed. Accelerometers should work with the Maestro, but I haven't tested that combination.
                    • Ducati87undefined
                      Ducati87 @CCS86
                      @ccs86 I'm using a CAT7 cable but it not working...I don't know how to fix the problem.
                        dc42 administrators @Ducati87
                        @ducati87 I plan to test accelerometer support on the Maestro next week.
                        StaticRedundefined 1 Reply Last reply Reply Quote 0
                        • StaticRedundefined
                          StaticRed @dc42
                          @dc42 hey so i got now everything working on my board. Also using now the resistor. But now what should i do with the data? How can i now use input shaper? I mean i can view it an hit analyze, but then? Not sure what i should do next.
                            @ducati87 I can confirm that accelerometer support does work on the Maestro. I have update https://duet3d.dozuki.com/Wiki/Accelerometers to include a photo showing the wiring I used. The ribbon cable is 1m long.
                            I also successfully ran an accelerometer using exp.pa21 and exp.pa22 for the CS and INT signals instead of TWD0 and TWCK0.
                            jay_s_ukundefined CCS86undefined 2 Replies Last reply Reply Quote 1
                              jay_s_uk @dc42
                              @dc42 can an accelerometer be connected to a 3HC?
                                dc42 administrators @jay_s_uk
                                @jay_s_uk said in Accelerometer Usage:
                                Not yet, but I will probably add support for that at some point.
                                  jay_s_uk @dc42
                                  @dc42 ok thanks. Would be helpful as I currently run all my tools off a 3HC and that's where all my wiring goes back to. Its also on the opposite side of my printer to the 6HC.
                                  • CCS86undefined
                                    CCS86 @dc42
                                    Any ideas on what to try next?
                                    I am running:
                                    • CAT6 cable, less than 1m length.
                                    • CS is run on a conductor with an unused pair (CS on orange, nothing on orange/wht)
                                    • 1k resistor on SDO
                                    • CS >>> EXP_0
                                    • INT >>> EXP_1
                                    • M955 P0 C"exp.pa21+exp.pa22"
                                    Not found....
                                      @ccs86 try using the temp daughterboard connector instead of the 12864_EXP2 connector. If you have a temperature daughterboard installed, you can connect to the pins on top of it.
                                      • CCS86undefined
                                        CCS86 @dc42
                                        I just tried like this and still get the not found error:
                                        M955 P0 C"twd0+twck0"
                                        (I assume that is a typo in your dozuki edit: Unknown pin name 'twcl0')
                                        (orange is CS... wht/grn is INT)
                                        o_lampeundefined CCS86undefined 2 Replies Last reply Reply Quote 0
                                        • o_lampeundefined
                                          o_lampe @CCS86
                                          @ccs86
                                          do you have evidence that the accelerator board is OK?
                                          • CCS86undefined
                                            CCS86 @o_lampe
                                            @o_lampe said in Accelerometer Usage:
                                            @ccs86
                                            The green light comes on, so that's a start. I'm not sure what else I might be able to test with my multimeter.
