    Accelerometer Usage
    Beta Firmware
    25
    191
    19.9k
    • StaticRedundefined
      StaticRed @dc42
      @dc42 Nope no chance. I wired it to io1. Same thing. I tested all connections with a multimeter and they work. But sadly my board cant build up a connection to the accelerometer. Is there something like a debug mode, which may teaches me more about what exactly the problem is?
      StaticRedundefined 1 Reply Last reply Reply Quote -1
        StaticRed @StaticRed
        @staticred seems like it still did record some data at some point.
        But it does not make sense that that is the z axis. Because the board is mounted flat on the toolhead. Really strange
          dc42 administrators @StaticRed
          @staticred I will re-test accelerometer with Duet 3 Mini later today or tomorrow.
          What did the raw data look like, before you clicked Analyse?
          StaticRedundefined 1 Reply Last reply Reply Quote 0
            StaticRed @dc42
            @dc42 Thank you alot!
            This is what the raw data looked like
            dc42undefined 2 Replies Last reply Reply Quote 0
              @staticred the raw data looks OK except for the spikes and drops, assuming that you collected that data while the machine was stationary. My guess is that those spikes/drops were where the firmware was unable to extract the data from the accelerometer fast enough. You can check this by looking at the end of the .csv file to see if there is a message about this. I think the DWC accelerometer plugin may report it too. See the notes at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Retrieving_the_data to see what you can do about it; or just try re-running it a few times to see if you can get a clean run.
              The analysis isn't valid if the data contains dropouts. To get a useful analysis you need to do a suitable move while the data is being collected as described at https://duet3d.dozuki.com/Wiki/Accelerometers#Section_Using_accelerometers.
                @staticred I just connected a LIS3DH board to my Duet 3 Mini5+ WiFi and it is working as expected. I used connector IO2 to connect the CS and INT lines.
                  StaticRed @dc42
                  @dc42 thank you for all the infos. I will tomorrow (after upgrading to my new orbiter extruder) solder all the wires to the lis3DH and also make proper connections. Maybe just a faulty cable caused it.
                    For anyone having problems getting an SPI-connected accelerometer to work:
                    I have found that capacitive coupling between the SDO and CS signals in the cable can cause a glitch on CS when the accelerometer replied to a read register request, and this glitch stops the accelerometer sending any more data. This is especially likely if those two signals, which use adjacent pins on the Adafruit LIS3DH board, use adjacent conductors in a flat cable. I was able to work around this by putting a 1K resistor in series with SDO at the accelerometer end of the cable.
                    • Ducati87undefined
                      Ducati87
                      I'm having an issue with the connection. I used a CAT7 ethernet cable but nothing works. Every time I try to launch the command, the accelerator is not found. Any suggest about which cable I should use? Thankt you.
                      SIamundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • SIamundefined
                        SIam @Ducati87
                        @ducati87 I use a USB3 cable and have no problems since then
                        https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released/68?_=1624809172098
                        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                        Duet WiFi 1.02 or later + DueX5
                        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                        Duet WiFi Server: 1.26
                        Duet Web Control 3.4.0beta4 (2021-09-27)
                        Ducati87undefined 1 Reply Last reply Reply Quote 0
                        • Ducati87undefined
                          Ducati87 @SIam
                          @siam Thank you Slam, I will try it 🙂
                            dc42 administrators @Ducati87
                            @ducati87 said in Accelerometer Usage:
                            See my reply immediately before your post.
                            • Ducati87undefined
                              Ducati87 @dc42
                              @dc42 what do you mean for "in series with SDO at the accelerometer end of the cable"?
                                @ducati87 I mean connect the resistor between the SDO pin of the accelerometer board and the wire that goes to MISO on the Duet, instead of connecting the wire directly to the SDO pin.
                                Ducati87undefined 2 Replies Last reply Reply Quote 1
                                • Ducati87undefined
                                  Ducati87 @dc42
                                  @dc42 perfect thank you!
                                    StaticRed @dc42
                                    @dc42 i will definetly try that out. I had firstly swap my board because of that early production process. While doing that i also swapped my z axis, now need to reconfigure than, and then can test the lis3dh again.
                                    • Ducati87undefined
                                      Ducati87 @dc42
                                      @dc42 said in Accelerometer Usage:
                                      in spite of the 1K resistor, the accelerometer is not found. I checked the cable on my duet daughter board and everything seems to be ok. Any suggest? Thank you.
                                        @ducati87 thanks for trying. I've no more suggestion yet, but I will get back to this when I have time. What sort of cable are you using, and how long is it? Photos of the two ends please.
                                        MikeSundefined 1 Reply Last reply Reply Quote 0
                                        • MikeSundefined
                                          MikeS @dc42
                                          @dc42 i'm in the same situation as @Ducati87 . Here's the thread where i have asked for help and post a photo of the wiring https://forum.duet3d.com/topic/24099/accelerometer-on-duet2wifi-duex5-expansion/3
                                          • CCS86undefined
                                            CCS86
                                            Same boat here.
                                            M955 P0 >>>> "Accelerometer not found"
                                            M955 P0 C"exp.pa22+exp.pa21" >>>> "Accelerometer not found on specified port"
                                            • Running RRF3.3 Stable
                                            • Wired with a VGA cable. I could probably take about 12" out of the cable length. I left it longer to keep the second ferrite noise filter in place.
                                            dc42undefined tekstyleundefined 2 Replies Last reply Reply Quote 0
