    My Mini is not really OK to start with WiFi
    104
    • tecno
      tecno last edited by
      Very often I have to start WiFi via terminal, not so good. Now config.g was missing but as I have backup in my PC it is not so bad. But this terminal job is getting frustrating.
      Cheers
      Bengt
      peter247 1 Reply Last reply Reply Quote 0
      • peter247
        peter247 @tecno last edited by
        @tecno Join the very long queue on the config.g going missing .
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          @tecno Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
          tecno 1 Reply Last reply Reply Quote 0
          • tecno
            tecno @Phaedrux last edited by
            @phaedrux
            as my reseller only has V0.5 and this would be 3rd board I am not really keen to have another V0.5
            Any other solution?
            Cheers
            Bengt
            ps once again today after emergency stop = wifi restart via terminal and config.g was gone
              Phaedrux Moderator @tecno last edited by
              @tecno Have we already replaced it under warranty for you? Who is the reseller?
              • tecno
                @phaedrux
                Bart in Holland
                  @tecno Ah yes. Thanks for jogging my memory. I am seeing what can be done here.
                  o_lampe tecno 2 Replies Last reply Reply Quote 0
                  • o_lampe
                    o_lampe @Phaedrux last edited by
                    @phaedrux
                    Is there a workaround for the (potentially) bad SD-card socket?
                    E.g. add a piece of paper to the SD-card to increase pressure to the contacts?
                    Or check solder points?
                    • tecno
                      @phaedrux said in My Mini is not really OK to start with WiFi:
                      I just learned that Kent at Filament23D has 1.0 in stock if that makes life easier.
                      Cheers
                      Bengt
                        @tecno You should have an email.
                          Phaedrux Moderator @o_lampe last edited by
                          @o_lampe said in My Mini is not really OK to start with WiFi:
                          @phaedrux
                          Well we don't currently know if it's a hardware problem or a firmware problem. Usually with an SD card slot issue the entire card would be unreadable and yet still work fine in a PC. The issue of the config.g disappearing is something new and different. We don't know if it's a problem with the way the config is being saved, or if it's a hardware problem happening during a save. Or something completely different interacting. The first ones that were replaced should be arriving soon for further investigation.
                          • tecno
                            Got one earlier today from Jason assuming that is what you refere to.
                              @tecno Yes, that's me.
