    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.1k
      dc42 administrators @skrotz
      @skrotz I have updated the binary at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0 to fix the extrusion issue that I identified.
      Adrian52undefined skrotzundefined 3 Replies Last reply Reply Quote 0
      • Adrian52undefined
        Adrian52 @dc42
        @dc42 just done calibration cubes, with no extruder problems and no hics or step errors, but appears that pa is not working for me with the latest 3.4
        • skrotzundefined
          skrotz @dc42
          @dc42 Unfortunately things look pretty much the same for me with the newest code. Some small extrusion zits or bubbles on the print, and PA doesn't seem like it is working. I did get a few step errors also it looks like, printing out a calibration cube:
          DMs created 83, segments created 35, maxWait 140417ms, bed compensation in use: mesh, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 11545, completed moves 11545, hiccups 2, stepErrors 3, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Things didn't seem or sound better or worse than previously. There are a couple of clunks I've heard during the prints I did on this firmware and the previous one.. I wasn't sure but now that I've done another print I'm fairly certain towards the end of the print in a couple of spots there was a distinct "clunk" noise, at the same place in both prints.
          I will see if I can capture step error data again with this new firmware.
            @skrotz and @Adrian52 please send M115 and report the firmware date/time that it reports.
            skrotzundefined Adrian52undefined 2 Replies Last reply Reply Quote 0
            • skrotzundefined
              skrotz @dc42
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.0beta2-inputshaping ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2021-07-25 09:41:53
              Will try and capture step error data now.
              dc42undefined 1 Reply Last reply Reply Quote 1
              • Adrian52undefined
                Adrian52 @dc42
                @dc42 2021-07-25 09:41:53
                • skrotzundefined
                  skrotz @dc42
                  @dc42 here's the log data with some stepper errors:
                  0725printerlog.txt
                  config.g
                  CFFFP_xyzCalibration_cube_205.gcode
                  on closer inspection the "zits" I'm seeing don't seem related to where the stepper errors occurred. They only seem to happen on the X side of the cube, at occasional points where it is changing direction for the X indented in the cube. It looks like overextrusion as it is a small blob. You have to magnify things to be able to see them, but it's happening a fair bit and is different/worse than RRF 3.3 which looks very clean. It seems to happen in exactly the same place each print, and has been pretty consistent throughout all the various 3.4s I've tried.
                  • sebkritikelundefined
                    sebkritikel
                    Just ran a print off the lasted BIN
                    M115
                    Parts look great, but end of print M122 reports 65 hiccups and 1929 stepErrors
                    M593 P"zvdd" F38.4
                    M572 D0 S0.020
                    config(1).g
                    LOG JP_smallPart1^2021 rifle gps mount-Split1.txt
                    Print file
                    Large(ish?) IDEX - 6HC, 1HCL
                    Stratasys Dimension 1200es to 6HC Conversion
                      @skrotz what PA did you use when you had those step errors? Was everything apart from PA the same as in the config.g file you posted earlier?
                      skrotzundefined 1 Reply Last reply Reply Quote 0
                        dc42 administrators @sebkritikel
                        @sebkritikel thanks, I will run that print on my bench setup.
                        • skrotzundefined
                          skrotz @dc42
                          @dc42 I did have PA enabled, that’s probably the only difference between the config files I posted, I think. The tests with these new firmwares had PA enabled.
                            @skrotz said in RRF 3.4 input shaping preview available:
                            How much PA?
                            • skrotzundefined
                              skrotz @dc42
                              @dc42 M572 D0 S0.12 is my standard PA setting, that's what the config.g had that I have been using for current 3.4 tests.
                              • Adrian52undefined
                                Adrian52
                                Should add that I used daa to compare 3.3 with 3.4, so that an identical config.g could be used for both. I use pa 0.8 with my 700mm bowden. No errors or hiccups with both, but pa not working with 3.4.
                                If I use ei3 with 3.4, I get 2 Step errors with the calibration cube (no hiccups or underruns), and I get 2 filament monitor 'insufficient movement' pauses on layers 97/98 out of 100.
                                  dc42 administrators @Adrian52
                                  @adrian52 @skrotz @sebkritikel I have put a new Duet 2 binary at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0. This fixes the issue with pressure advance and other issues that I was able to reproduce.
                                  CadetCundefined skrotzundefined 2 Replies Last reply Reply Quote 0
                                  • CadetCundefined
                                    CadetC @dc42
                                    @dc42 said in RRF 3.4 input shaping preview available:
                                    As you said, tooboard build in accelerometer now works with SBC
                                    I tried x and y axis - so now I'm going to take on IS 😉
                                    G1 X-50 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000
                                    G1 y-50 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 y50 F20000
                                      dc42 administrators @CadetC
                                      @cadetc currently I favour doing a sharp move and collecting data after it has completed. This removes motor and belt noise from the accelerometer output, making it easier to see what is going on. Here is a sample command for the X axis, for a machine set up with X0 Y0 being bed centre:
                                      G1 X-100 F3000 G4 S1 G1 X0 F20000 M400 M956 Pxxx A0 S1000
                                      CadetCundefined 1 Reply Last reply Reply Quote 1
                                      • skrotzundefined
                                        skrotz @dc42
                                        @dc42 with PA enabled the "clunking" noise has returned, usually when printing the infill portion. Disabling PA stopped the clunking, and oddly produced a small layer shift in the X direction and an even smaller one in Y. Definitely some strange extrusion or positioning errors on the part of the print with PA on. With PA off things seemed like previous builds, with some extrusion bubbles or zits in the exact same places as before (these don't happen in 3.3 with PA off). M122 reported some hiccups and errors:
                                        DMs created 83, segments created 35, maxWait 50682ms, bed compensation in use: mesh, comp offset 0.000
                                        === MainDDARing ===
                                        Scheduled moves 11545, completed moves 11545, hiccups 1028, stepErrors 5, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                        === AuxDDARing ===
                                        This was all the same config and gcode as uploaded before. If helpful I could get a debug log later of the stepper errors.
                                        botundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                        • botundefined
                                          bot @skrotz
                                          @skrotz which slicer are you using?
                                          Could be gcode related.
                                          E.g., stock prusaslicer is horrible at producing accurate gcode for very short movements. This pops up a lot in parts of infill.
                                          *not actually a robot
                                            @skrotz are you certain that the clunking doesn't happen using RRF 3.3 with the same gcode?
                                            Edit: I just spotted that you had some step errors - odd that I didn't. I'll check the configuration and run your print again.
