    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.2k
    • OwenDundefined
      OwenD @dc42
      @dc42 So far I have found as soon as DAA is enabled I get a massive layer shift and it stops extruding.
      Currently testing other modes as I had DAA first.'
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta1-inputshaping (2021-07-10)
      Duet WiFi Server Version: 1.26
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta1-inputshaping (2021-07-10 20:57:53) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD
      Used output buffers: 3 of 24 (24 max)
      Static ram: 23932
      Dynamic ram: 79088 of which 208 recycled
      Never used RAM 5684, free system stack 112 words
      Tasks: NETWORK(ready,24.2%,237) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.0%,326) Move(notifyWait,0.1%,283) MAIN(running,69.0%,420) IDLE(ready,6.6%,29), total 100.0%
      Owned mutexes:
      Last reset 01:27:13 ago, cause: software
      Last software reset at 2021-07-10 20:15, reason: User, GCodes spinning, available RAM 8456, slot 2
      Error status: 0x0e
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 17.8, current 18.1, max 18.6
      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/16, heap memory allocated/used/recyclable 2048/2032/1806, gc cycles 9
      Driver 0: position 2996, standstill, SG min/max not available
      Driver 1: position 3081, standstill, SG min/max 0/555
      Driver 2: position 14, standstill, SG min/max 0/130
      Driver 4: position 0, standstill, SG min/max 0/160
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-07-11 09:22:19
      Slowest loop: 8.78ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 8
      SD card longest read time 1.7ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 13, maxWait 91990ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 199, completed moves 196, hiccups 5, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.3
      Segments left: 1
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X151.413 Y31.057 E0.04606" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0 0, running macro
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === Network ===
      Slowest loop: 201.15ms; fastest: 0.09ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1), 1 sessions
      HTTP sessions: 2 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 3
      WiFi firmware version 1.26
      WiFi MAC address bc:dd:c2:89:a0:bb
      WiFi Vcc 3.37, reset reason Power up
      WiFi flash size 4194304, free heap 22112
      WiFi IP address 192.168.1.163
      WiFi signal strength -61dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Socket states: 2 0 4 4 0 0 0 0
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @OwenD
        Can confirm all other input shaping modes worked but daa causes step loss every time.
        Also stops extruding for some reason.
        M122 after canceling
        11/07/2021, 1:27:54 pm	M122
        Used output buffers: 4 of 24 (24 max)
        Static ram: 23932
        Dynamic ram: 79088 of which 16 recycled
        Never used RAM 5156, free system stack 108 words
        Tasks: NETWORK(ready,168.2%,229) ACCEL(notifyWait,0.0%,348) HEAT(delaying,0.3%,326) Move(notifyWait,1.0%,299) MAIN(running,220.9%,420) IDLE(ready,61.3%,29), total 451.7%
        Owned mutexes: WiFi(NETWORK)
        Last reset 02:54:25 ago, cause: power up
        Last software reset at 2021-07-11 09:24, reason: User, GCodes spinning, available RAM 5684, slot 0
        Error status: 0x0e
        Aux0 errors 0,0,0
        MCU temperature: min 16.7, current 24.0, max 26.3
        Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/16, heap memory allocated/used/recyclable 2048/1656/1430, gc cycles 17
        Driver 0: position 0, standstill, SG min/max 0/582
        Driver 1: position 20000, standstill, SG min/max 0/1023
        Driver 2: position 24864, standstill, SG min/max 0/648
        Driver 3: position 0, standstill, SG min/max 0/1023
        Driver 4: position 0, standstill, SG min/max 0/1023
        Date/time: 2021-07-11 13:27:49
        Slowest loop: 318.94ms; fastest: 0.12ms
        === Storage ===
        Free file entries: 9
        SD card longest read time 2.3ms, write time 91.9ms, max retries 0
        DMs created 83, segments created 43, maxWait 158450ms, bed compensation in use: mesh, comp offset 0.000
        === MainDDARing ===
        Scheduled moves 28342, completed moves 28342, hiccups 0, stepErrors 5, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
        === AuxDDARing ===
        Segments left: 0
        File is idle in state(s) 0
        Code queue is empn state(s) 0
        === Network =essions: 2 of 8
        - WiFi -
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 23688
        WiFi signal strength -65dBm, mode 802.11n, reconnections 0, sleep mo
        dc42undefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @OwenD
          @owend I confirm there is a bug in the implementation of DAA. I hope to get time to fix it today.
            dc42 administrators @dc42
            I have updated the binaries at https://www.dropbox.com/sh/l020weqx7pijv84/AACFM3knhVXQ1hKu6NyKOfx6a?dl=0 again:
            • Fixed a bug that caused incorrect movements when DAA input shaping was selected
            • Fixed a bug that sometimes caused incorrect extrusion on CAN-connected extruders when pressure advance was used
            • Fixed a bug that caused a filament error pause to lock up if the pause.g file used certain commands in combination, e.g. a M106 command followed by a tool change
            • Increased Duet 3 MB6HC Ethernet task stack size by 50 words
            • Fixed a bug that caused a crash when the slicer labeled objects using M486 and there were more than 20 (Duet 2) or 40 (Duet 3) objects on the build plate. Unlike the other ones, this bug is also present in RRF 3.3 stable and 3.4.0beta1.
            I have tested that movement with DAA enabled is now working; however on my delta printer, when printing the test piece it's much less effective at reducing ringing than the other shaping methods. I have also tested with pressure advance set to 0.5.
            CadetCundefined 1 Reply Last reply Reply Quote 0
            • CadetCundefined
              CadetC @dc42
              I got Duet3 + toolboard ver1.1 installed - Today i have upgraded to 3.4.0beta1-inputshaping (2021-07-11) - i have then used latest binaries to be able use accelerometer in SBC configuration. -when i try to G1 X-50 G4 S2 M956 P121.0 S1000 A0 G4 P10 G1 X50 F20000 i received Error: M956: Accelerometer not found but when i send M120 B121 in response i got : Accelerometer detected: yes, status: 00
              Is this got any thing to toolboard still being: Duet TOOL1LC firmware version 3.3 (2021-06-15 16:12:58)? is there any files to upgrade TOOL1LC to 3.4 firmware?
                dc42 administrators @CadetC
                @cadetc you don't need to upgrade the tool board firmware. I assume you have verified that you are running DSF 3.4.0b1 on the Pi. We are looking into a possible cause of the problem you are having with M956.
                • CadetCundefined
                  CadetC @dc42
                  Info copied from DWC : Machine specific-General :
                  Board: Duet 3 MB6HC (MB6HC)
                  DSF Version: 3.4-b1
                  Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0beta1-inputshaping (2021-07-11)
                  Thanks,
                  • Frederikundefined
                    Frederik
                    @dc42 here the same error , accelerometer detected but when trying to perform a data collect, it says acceleromter not found
                    m122
                    RepRapFirmware for Duet 3 MB6HC version 3.4.0beta1 (2021-07-10 16:20:28) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                    Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT
                    Used output buffers: 1 of 40 (10 max)
                    Static ram: 150904
                    Dynamic ram: 62912 of which 24 recycled
                    Never used RAM 140352, free system stack 146 words
                    Tasks: SBC(ready,0.7%,308) HEAT(delaying,0.0%,325) Move(notifyWait,0.0%,266) CanReceiv(notifyWait,0.0%,774) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,339) TMC(notifyWait,7.4%,59) MAIN(running,91.8%,922) IDLE(ready,0.0%,29), total 100.0%
                    Owned mutexes: HTTP(MAIN)
                    Last reset 00:40:04 ago, cause: software
                    Last software reset at 2021-07-11 15:33, reason: User, none spinning, available RAM 137420, slot 0
                    Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                    Error status: 0x00
                    Step timer max interval 172
                    MCU temperature: min 31.1, current 33.9, max 47.4
                    Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                    Driver 0: position 41808, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/425
                    Driver 1: position -25728, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/995
                    Driver 2: position 3893, standstill, reads 41390, writes 20 timeouts 0, SG min/max 0/852
                    Driver 3: position 0, standstill, reads 41391, writes 20 timeouts 0, SG min/max 0/280
                    Driver 4: position 0, standstill, reads 41391, writes 20 timeouts 0, SG min/max 0/825
                    Driver 5: position 0, standstill, reads 41399, writes 12 timeouts 0, SG min/max 0/0
                    Date/time: 2021-07-11 16:13:58
                    Slowest loop: 56.12ms; fastest: 0.04ms
                    === Storage ===
                    Free file entries: 10
                    DMs created 125, maxWait 1844035ms, bed compensation in use: none, comp offset 0.000
                    === MainDDARing ===
                    Scheduled moves 13, completed moves 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                    === AuxDDARing ===
                    Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                    Heater 1 is on, I-accum = 0.0
                    Segments left: 0
                    Telnet* is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Extruder 0: no data received
                    === CAN ===
                    Messages queued 21655, received 30029, lost 0, longest wait 5ms for reply type 6024, peak Tx sync delay 169, free buffers 49 (min 48), ts 12021/12020/0
                    Tx timeouts 0,0,0,0,0,0
                    === SBC interface ===
                    State: 4, failed transfers: 0, checksum errors: 0
                    Last transfer: 2ms ago
                    RX/TX seq numbers: 29527/29527
                    SPI underruns 0, overruns 0
                    Disconnects: 0, timeouts: 0, IAP RAM available 0x2c7a4
                    Buffer RX/TX: 0/0-0
                    === Duet Control Server ===
                    Duet Control Server v3.4-b1
                    Code buffer space: 4096
                    Configured SPI speed: 8000000Hz
                    Full transfers per second: 39.59, max wait times: 49.2ms/0.0ms
                    Codes per second: 0.04
                    Maximum length of RX/TX data transfers: 3196/800
                    m122 b121
                    Diagnostics for board 121:
                    Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                    Never used RAM 2108, free system stack 2789 words
                    Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,117) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                    Last reset 00:01:14 ago, cause: VDD brownout
                    Last software reset data not available
                    Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 18391, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0
                    Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                    Peak sync jitter 0/5, peak Rx sync delay 192, resyncs 0/0, no step interrupt scheduled
                    VIN: 24.4V
                    MCU temperature: min 37.5C, current 39.0C, max 39.0C
                    Ticks since heat task active 2, ADC conversions started 74496, completed 74495, timed out 0, errs 0
                    Last sensors broadcast 0x00000002 found 1 6 ticks ago, loop time 0
                    CAN messages queued 492, send timeouts 0, received 339, lost 0, free buffers 37, min 37, error reg 0
                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                    I2C bus errors 0, naks 0, other errors 0
                    Interrupt 5726621 to 0us, poll 9 to 432us
                    Driver 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                    m122 b121
                    Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,113) CanAsync(notifyWait,0.0%,61) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.8%,57) MAIN(running,92.0%,352) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
                    Last reset 00:43:34 ago, cause: software
                    Driver 0: position 0, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 23, reads 5309, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0
                    Peak sync jitter 0/6, peak Rx sync delay 212, resyncs 0/0, no step interrupt scheduled
                    VIN: 24.4V
                    MCU temperature: min 38.8C, current 40.0C, max 40.3C
                    Ticks since heat task active 129, ADC conversions started 2614124, completed 2614122, timed out 0, errs 0
                    Last sensors broadcast 0x00000002 found 1 134 ticks ago, loop time 0
                    CAN messages queued 8362, send timeouts 0, received 6006, lost 0, free buffers 37, min 37, error reg 0
                    Interrupt 5726621 to 0us, poll 9 to 433us
                    regards
                      dc42 administrators @Frederik
                      @frederik thanks, we have identified the cause. Fixing it will require a change to DSF on the Pi.
                      Meanwhile, you should be able to send the command to the Duet from an attached PanelDue if you have one, or via USB.
                      • Argoundefined
                        Argo @dc42
                        Measurement without input shaping (Y axis):
                        With ZVD input shaping:
                        The print results to also show that it is working. 🙂
                        I also have no issues with PA nor was it necessary to recalibrate PA.
                        Is it planned to to be able to use different shapers and frequencies per axis or to use an "automatic frequency and shaper finder" in conjunction with the accelerometer (like Klipper does)?
                          @argo the automatic shaper recommendation generator is under development.
                          • skrotzundefined
                            skrotz @dc42
                            @dc42 I mis-typed, I meant that PA clunked unless I took it down to 0.04 (not 0.4), reducing it from my usual 0.12 value. Sorry about that.
                            I've grabbed the latest firmware and still have that same result of clunking with PA at or above 0.04 or so. My extruder is attached to E0 on the duet2, I have a pretty standard railcore setup, so I have z steppers on a duex5 but X/Y and E0 are on the duet2 wifi.
                            Aside from the PA clunking, everything else so far seems fine, things were printing ok with DAA, and now with zvdd in some quick tests.
                              dc42 administrators @Argo
                              @argo, as you have a fairly broad resonance, ZVDD will probably work better than ZVD.
                              Argoundefined Dudek23undefined 2 Replies Last reply Reply Quote 0
                                dc42 administrators @skrotz
                                @skrotz said in RRF 3.4 input shaping preview available:
                                Interesting, my Duet WiFi powered delta normally runs at PA 0.2 and has been fine. My tool changer didn't have the correct extrusion with the earlier firmware, but that uses a tool board and it is running fine now with the later firmware.
                                skrotzundefined 1 Reply Last reply Reply Quote 0
                                • skrotzundefined
                                  skrotz @dc42
                                  @dc42 definitely some extruder weirdness for me that I don't get on 3.3.
                                  I only had PA on briefly (the clunking is disconcerting) on a test print of a calibration cube but did notice this from M122:
                                  DMs created 83, segments created 35, maxWait 135339ms, bed compensation in use: mesh, comp offset 0.000
                                  === MainDDARing ===
                                  Scheduled moves 11522, completed moves 11522, hiccups 511, stepErrors 2, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                  === AuxDDARing ===
                                  my extruder motor is the standard LDO one in a filastruder railcore kit, used as a direct drive.
                                    @skrotz thanks.The step errors are not right. Please can you connect a laptop to the Duet via USB, load a terminal emulator (e.g. YAT), and send M111 S1 P4. That will enable Move debugging. Then run that print. For each step error recorded you should get a few lines of DDA and DM printout in the terminal. Post those lines here.
                                    Also please post the print file and your config.g.
                                    • Argoundefined
                                      Argo @dc42
                                      Using the same frequency with ZVDD or other shaper is giving me worse results. I don‘t think I can just use the measured ringing frequency with shapers other than ZVD?
                                      • skrotzundefined
                                        skrotz @dc42
                                        @dc42 it took a bit of finagling to get things hooked up to the PC, but so far even though I heard the clunking it didn't output anything on the terminal at that point even with the debug enabled. I may be able to try again later, is there anything else I could/should enable? an M122 after stopping showed "hiccups" but no stepper errors at that point. I only did a small amount of the print though, I had to stop as I think I injected something via the terminal at the wrong time and caused some problems.
                                        I've included my config file and the gcode I'm printing.
                                        config.g
                                        CFFFP_xyzCalibration_cube_195.gcode
                                          @skrotz please can you try again, this time wait until M122 shows some step errors, as it did in your previous M122 that you posted here.
                                          Some extduders do sound clunky when used with pressure advance, however it shouldn't be different in the latest 3.4 with input shaping compared to 3.3.
                                          skrotzundefined 2 Replies Last reply Reply Quote 0
                                          • OwenDundefined
                                            OwenD
                                            Just an update.
                                            Upgraded to the latest binary.
                                            This time the print completed with no apparent missed step issues, or clunking including during sectioins using DAA.
                                            No step errors in the M122 report, but a couple of hiccups.
                                            	M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta1-inputshaping (2021-07-11 11:04:56) running on Duet WiFi 1.02 or later
                                            === MainDDARing ===
                                            Scheduled moves 34420, completed moves 34420, hiccups 4, stepErrors 0, LaErrors 0, Underruns [0, 0, 6], CDDA state -1
                                            === AuxDDARing ===
                                            Nothing of note shows up in the M111 debug log.
                                            Too late in the night to evaluate the results in regards to print quality of each mode.
