    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    25.2k
    • CadetCundefined
      CadetC @dc42
      @dc42 said in RRF 3.4 input shaping preview available:
      @cadetc said in RRF 3.4 input shaping preview available:
      I've identified and fixed some issues affecting extrusion with pressure advannce, and updated the binaries at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0 again.
      Same problem as with previous binaries - after starting a print, the status immediately shows that the print is 100% complete - when I click emergency stop, DWC hangs up and I have to physically cut power to reset the printer
      Did you check for error messages in the console?
      no error codes
      • CadetCundefined
        CadetC @dc42
        no error codes -All in all, the print sequence is OK, first the table heats up, then noozle and the print starts - even though the status from the very beginning shows the print as 100% complete - I think there is a bug with the layer count so DWC indicates the print as 100% complete
        • CadetCundefined
          CadetC
          When I made a downgrade to an earlier beta then it is OK - the problem appeared in the beta version released today
          • skrotzundefined
            skrotz @dc42
            @dc42 Yes with input shaping disabled but PA enabled I am getting the clunking noises, different from RRF 3.3.
              dc42 administrators @CadetC
              Please provide the print file and your config.g file.
              CadetCundefined 1 Reply Last reply Reply Quote 0
              • chrishammundefined
                chrishamm administrators @CadetC
                @cadetc RRF 3.4-b2pre isn't compatible with the DSF version from the unstable package feed. We'll update the package feed as soon as the remaining issues with IS/PA are confirmed to be fixed.
                Duet software engineer
                • CadetCundefined
                  CadetC @dc42
                  Below my config.g and print file
                  tension, cover, bltouch_32m.g
                  config (5).g
                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 20:39:32 GMT+0200 (czas środkowoeuropejski letni)
                  G90                                                  ; send absolute coordinates...
                  M83                                                  ; ...but relative extruder moves
                  M550 P"Duet 3"                                       ; set printer name
                  M669 K1                                              ; select CoreXY mode
                  G4 S5                                                ;wait for expansion boards to start
                  M569 P0.5 S0                                         ; x axis physical drive 0.5 goes forward
                  M569 P0.4 S0                                         ; y axis physical drive 0.4 goes forward
                  M569 P0.2 S1                                         ; Fron right bed physical drive 0.2 goes forwards
                  M569 P121.0 S1                                       ;extruder  physical drive 121.0 goes forwards
                  M569 P0.0 S1                                         ; Front left bed physical drive 0.0 goes forwards
                  M569 P0.1 S1                                         ; Rear bed physical drive 0.1 goes forwards
                  M584 X0.5 Y0.4 Z0.0:0.1:0.2 E121.0                       ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                              ; configure microstepping with interpolation
                  M92 X160.00 Y160.00 Z800.00 E409.00                  ; set steps per mm
                  M566 X1200.00 Y1200.00 Z30.00 E1200.00               ; set maximum instantaneous speed changes (mm/min)
                  M203 X30000.00 Y30000.00 Z1800.00 E3000.00           ; set maximum speeds (mm/min)
                  M201 X6000.00 Y6000.00 Z200.00 E2000.00              ; set accelerations (mm/s^2)
                  M906 X2000 Y2000 Z1200 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                              ; Set idle timeout
                  M671 X-27.4:147.5:322.4 Y-4.5:324.5:-4.5 S20
                  M208 X0 Y0 Z0 S1                                     ; set axis minima
                  M208 X290 Y280 Z290 S0                               ; set axis maxima
                  M955 P121.0 I41
                  M574 X2 S1 P"121.io1.in"                             ; configure active-high endstop for high end on X via pin 121.io1.in
                  M574 Y1 S1 P"io1.in"                                 ; configure active-high endstop for low end on Y via pin io1.in
                  M574 Z1 S2                                           ; configure Z-probe endstop for low end on Z
                  M950 S0 C"121.io0.out"                               ; create servo pin 0 for BLTouch
                  M558 P9 C"^121.io0.in" H15 F240 T9000                ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X-1  Y-32 Z2.50                             ; set Z probe trigger value, offset and trigger height
                  M557 X10:290 Y3:290 S30                              ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138         ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0                                   ; create bed heater output on out0 and map it to sensor 0
                  M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                              ; map heated bed to heater 0
                  M143 H0 S130                                         ; set temperature limit for heater 0 to 130C
                  M308 S1 P"121.temp0" Y"thermistor" T100000 B4138     ; configure sensor 1 as thermistor on pin 121.temp0
                  M950 H1 C"121.out0" T1                               ; create nozzle heater output on 121.out0 and map it to sensor 1
                  M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S300                                         ; set temperature limit for heater 1 to 300C
                  M950 F0 C"out7" Q25000                                 ; create fan 0 on pin out7 and set its frequency
                  M106 P0 S0 H-1                                       ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"121.out2" Q500                             ; create fan 1 on pin 121.out2 and set its frequency
                  M106 P1 S1 H1 T45                                    ; set fan 1 value. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                                     ; define tool 0
                  G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
                  G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
                  T0					                                 ; select first hot end
                  M572 D0 S0.022                                       ;enable pressure advance value of 0.022
                  M575 P1 S1 B57600                                    ; enable support for PanelDue
                  M501                                                 ; load saved parameters from non-volatile memory
                  M911 S22 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  I have no problems with the July 28 beta bin
                  Duet3Firmware_MB6HC-28-07.bin
                  Print status problem started with the August 1 beta bin
                  Duet3Firmware_MB6HC-1-08.bin
                  Problem lays with incompatibilie DSF - only surprised me why works with ver. 28-07 but not with ver. 1-08
                    @cadetc thanks.
                    • JenPetundefined
                      JenPet @dc42
                      @dc42 I have also tested new version but can't see any improvement
                        dc42 administrators @JenPet
                        @jenpet I have just found one cause of the issue with PA. I'll have a new binary soon.
                          @JenPet @skrotz @MikeS I have updated the binaries at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0. This version does not give rise to hiccups in my tests.
                          JenPetundefined skrotzundefined Adrian52undefined 4 Replies Last reply Reply Quote 0
                          • JenPetundefined
                            JenPet @dc42
                            @dc42 PA is still not working for me.
                            DMs created 83, segments created 42, maxWait 206756ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 2700, completed moves 2700, hiccups 0, stepErrors 578, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                            === AuxDDARing ===
                              @jenpet please check the firmware date using M115, which should be this afternoon.
                              To reproduce this, I will need your config.g file and the GCode file you are printing.
                              JenPetundefined 1 Reply Last reply Reply Quote 0
                              • JenPetundefined
                                JenPet @dc42
                                @dc42 Firmware date is ok
                                M115
                                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.0beta2-inputshaping ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-08-02 16:26:18
                                config.g
                                40x40x40_Cube_140mms0.08.gcode
                                • skrotzundefined
                                  skrotz @dc42
                                  @dc42 just starting a print but definite improvement so far. Clunkiness is at least greatly reduced, if not gone. Will see how the print looks in a bit. Sounds much more normal.
                                    @jenpet I don't see any M572 command in config.g. Are you running without pressure advance?
                                    • JenPetundefined
                                      JenPet @dc42
                                      @dc42 M572 is in the start script of gcode
                                      dc42undefined 2 Replies Last reply Reply Quote 0
                                        @jenpet ok, I am running your file now.
                                        • Adrian52undefined
                                          Adrian52 @dc42
                                          @dc42 just completed cal cube with ei3 and 0.8 pa, no clunking, nice finish - 0 hiccups, 0 errors, 0 underruns. Brilliant - thank you.
                                            @jenpet I am getting the step errors now. Looking into it.
