    New Duet 2 Ethernet USB problems
    589
    • frankfisk4undefined
      frankfisk4
      I recently purchased a Duet2 from Matter Hackers.
      The USB port is not functioning I cannot load firmware.
      The setup directions couldn't be simpler I can only assume the port is damaged.
      Anyone had this issue?
        Most likely it's either the USB cable or USB port on the PC that isn't able to work with the Duet. Try different USB cable and port, or different PC entirely.
        And you can go through this guide to identify what else is working or not.
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        frankfisk4undefined 1 Reply Last reply Reply Quote 0
          frankfisk4 @Phaedrux
          I've gone through all the steps to connect and reset the card.
          It is still unresponsive.
          With USB power applied all the lights light up and stay on, 5.0, 3.3 volt and DIAG.
          The next step is to erase the firmware.
          Should I proceed?
            Before you erase the firmware check the device manager to see what shows up.
            Have you tried using YAT yet to see if it will respond to commands?
            @frankfisk4 said in New Duet 2 Ethernet USB problems:
            This is very vague. What exactly are you trying to do and what exactly is happening?
            Have you gone through this?
            https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
              Yes Sir,
              I've had another ethernet duet connected to this PC and it worked fine.
              I tried YAT with no success.
              I am trying to go through Getting connected. This is where the problem is.
              I am trying to load the firmware and I have no USB connectivity.
              I've tried several ports and 3 different cables.
                Again, before trying to do anything with the firmware let's see if it's actually working. The board should ship with firmware on it and will have gone through testing before it leaves the factory. If you pull the SD card and check it on your PC you can open the config.g file in the /sys/ folder. Inside there should be a command M552 S1 that will have the network obtain a DHCP IP address. Then you just need to connect your ethernet cable and connect it to your router and it should be ready to connect to in your browser at http://duet.local assuming that the printer name set in the config.g is also duet.
                  I pulled the SD card and checked it on my PC.
                  The config.g file does not open and windows asks for the program to open it.
                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @frankfisk4
                    @frankfisk4 open it with notepad, it's just a plain text file
                    i3 clone with a bunch of mods
                      frankfisk4 @engikeneer
                      Hi here is what the text file says.
                      ; Default config.g template for Duet 2
                      ; Replace this with a proper configuration file (e.g from https://configtool.reprapfirmware.org)
                      ;enable UART for testing
                      M575 P1 B57600 S1
                      ; test network enable
                      M552 P192.168.1.14
                      M552 S1
                      ; Display initial welcome message
                      M291 P"Please go to <a href=""https://www.duet3d.com/StartHere"" target=""_blank"">this</a> page for further instructions on how to set it up." R"Welcome to your new Duet 2!" S1 T0@engikeneer
                      dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        dc42 administrators @frankfisk4
                        @frankfisk4 are you able to communicate with your other board using YAT and the same USB cable? If so, then please fit the Erase jumper to the non-responsive board, press the Reset button, and see if the Bossa port appears on the PC in Device Manager ->Ports. If it doesn't then I will approve a warranty replacement.
                          Phaedrux Moderator @frankfisk4
                          M552 P192.168.1.14
                          Can you also change that address to a valid unoccupied address on your network and then try to reach it from a browser or ping while an ethernet cable is connected to the Duet?
                          On the SD card there should also be a folder called /www/ that has some web files in it.
                            frankfisk4 @dc42
                            Hi, that printer was sold long ago but I'm using it's original USB cable and the one that came with the new duet.
                            I am still unable to communicate with the board using YAT and any combination of the 3 USB cords or 4 USB PC ports I have access to.
                            Should I erase the board as you outlined?
                              Go for it. Hopefully it will wake up this time.
                                I did as instructed. Now the2nd LED is on next to to USB port and no Bossa port appears in the device manager.
                                Where do I go from here?
                                Thanks
                                  Can you communicate with it via YAT now?
                                    No and it doesn't show in the device menu either.
                                      Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                        Thank you for the help.
                                        The new DUET WIFI showed up today and installed as per instructions.
                                        Thanks
                                        Frank
