    4 endstops for 4 z stepper motor and 3D Touch possible?
    Firmware installation
    640
    • Duncanundefined
      Duncan
      I have Duet 3 MB6HC and 4 stepper motors for Z axis connected to the board... I read that it's not possible with Reprapfirmware to have two endstops for one motor (for negative and positive maximum positions)... but is it possible to have one endstop for max positive movement for example in each of them and one 3D Touch for homming Z to negative position and calibrate bed?
      Thanks
      • chrishammundefined
        chrishamm administrators @Duncan
        @duncan Yes, that should be supported. When you set up the Z endstop , combine the different input ports with + like
        M574 P"^io2.in+^io3.in+^io4.in+^io5.in" Z1 S1
        Note that the order of endstops should match the order of configured drivers.
        Duet software engineer
          Multiple endstops in RRF3 as described here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
          Using a probe as well is easy as well. The Endstops are used during G1 H1 homing moves and the probe is used when G30 is called. So you have control over how things are homed in your homing files.
          • Duncanundefined
            Duncan
            @phaedrux @chrishamm
            Thank you for the information, I opened other issue about endstops that I can only get them working on input 1 on the mainboard... because if I can't solve that I can't get this working anyway
            • Duncanundefined
              Duncan
              Hello again, endstops are working now... but I have problems with the Z endstops, this is my config.g
              M552 P0.0.0.0 S1                                        ; enable network and acquire dynamic address via DHCP
              M586 P0 S1                                              ; enable HTTP
              M586 P1 S0                                              ; disable FTP
              M586 P2 S0                                              ; disable Telnet
              M584 X40.0 Y41.0 Z1:2:4:5 E20.0				; J- configuramos los motores X, Y, Z y E en cada posición de la placa principal o placas externas.
              M671 X1115:1115:-15:-15 Y1360:-260:-260:1360 S0.5	; J- configuramos la posición de los husillos respecto el origen (0,0) de la cama (no de los finales de carrera)
              ;M584 X40.0						; set X driver
              ;M584 Y41.0 					; set Y driver
              ;M584 Z1:2:4:5 					; set Z driver
              ;M584 E20.0						; set E driver
              M569 P0 S0                                           ; physical drive 0.0 goes forwards
              M569 P1 S0                                           ; physical drive 0.1 goes forwards
              M569 P2 S0                                           ; physical drive 0.2 goes forwards
              M569 P3 S0                                           ; physical drive 0.3 goes forwards
              M569 P4 S0                                           ; physical drive 0.4 goes forwards
              M569 P5 S0										; physical drive 0.5 goes forwards
              G4 S1 													;wait for expansion boards to start
              M569 P40.0 S1 R0 T2.7										; change enable polarity, active = disable drive
              M569 P41.0 S0 R0 T2.7
              M569 P20.0 S1
                                				; set drive mapping
              M350 X16 Y16 Z32 E16 I1                           			; configure microstepping with interpolation
              M92 X133.333 Y133.333 Z1280 E420.00	         			; set steps per mm
              M566 X900.00 Y900.00 Z12 E120.00			       		; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180 E1200.00					; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z100.00 E250.00		    			; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z3000 E800 I30		                    		; set motor currents (mA) and motor idle factor in per cent
              G21 									; TRABAJO EN MM
              G90 									; TRABAJO EN CORDENADAS ABSOLUTAS
              M84 S30                                                 		; Set idle timeout
              M208 X-50 Y-27 Z0 S1                                       		; set axis minima
              M208 X1100 Y1100 Z1000 S0                                  		; set axis maxima
              M574 X1 S1 P"io0.in"                                ; configure active-high endstop for low end on X via pin io0.in
              M574 Y1 S1 P"io1.in"                                ; configure active-high endstop for low end on Y via pin io1.in
              M574 Z1 S1 P"io3.in+io4.in+io5.in+io6.in" 		    ; configuramos finales de carrera eje Z según orden de motores
              M950 S0 C"20.io0.out"                           ; create servo pin 0 for BLTouch
              M558 P9 C"^20.io0.in" H10 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X20 Y40 Z0                          ; set Z probe trigger value, offset and trigger height
              M557 X50:1100 Y70:1100 S500                     ; define mesh grid
              ;M308 S0 P"temp0" Y"thermistor" B4725 C7.06e-8            ; configure sensor 0 as thermistor on pin temp0
              ;M950 H0 C"out0" T0                                      ; create bed heater output on out0 and map it to sensor 0
              ;M307 H0 B1 S1.00                                        ; enable bang-bang mode for the bed heater and set PWM limit
              ;M140 H0                                                 ; map heated bed to heater 0
              ;M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
              M308 S0 P"20.temp0" Y"thermistor" B4725 C7.06e-8             ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"20.out0" T0                                      ; create nozzle heater output on out1 and map it to sensor 1
              M307 H0 B0 S1.00                                        ; disable bang-bang mode for heater  and set PWM limit
              M950 F0 C"20.out1" Q500                                    ; create fan 0 on pin out7 and set its frequency
              M106 P0 S255 H0 T50
              M106 P0 S0; Herramienta 2 PCF
              M563 P0 D0 H1 F0                                        ; define tool 0
              G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
              ;G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
              ;M556 S100 X0 Y0 Z0 ; Put your axis compensation here
              ;M912 P9 S0 ; Put your CPU temperature sensor correction here
              ;M501 ; Run config-override.g
              ;T0 ; Select the first head
              M575 P1 S1 B57600                                       ; enable support for PanelDue
              M564 H0
              M302 P1
              My bed.g
              ; bed.g
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 31 2020 15:45:57 GMT+0800
              ;M561 ; clear any bed transform
              ;G28 XY
              ;G29  ; probe the bed and enable compensation
              G28
              G30 P0 X1100 Y1360 Z-99999 		; calibra junto motor (1)
              G30 P1 X1100 Y30 Z-99999		; calibra junto motor (2)
              G30 P2 X20 Y30 Z-99999			; calibra junto motor (4)
              G30 P3 X20 Y1360 Z-99999		; calibra junto motor (5)
              and home.z
              ; homez.g
              ; called to home the Z axis
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Sep 04 2020 14:49:01 GMT+0800 (中国标准时间)
              G91              ; relative positioning
              G1 H2 Z10 F6000   ; lift Z relative to current position
              ;G1 H2 X510 Y510 F6000 ; go to first probe point
              G1 H1 Z-99999
              G90              ; absolute positioning
              G30              ; home Z by probing the bed - activar 3D Touch
              The problem I have now is that I can't see endstops 3, 4, 5 and 6 in Object Model, but io2.in appears to be activated somehow... and always true... so when I try to home z the motor in position 4 is not moving... and I really have no clue why is happening that.
              Any ideas? Thanks!
                Are you perhaps getting some interference with the wiring for that endstop?
                How can you tell that io2.in is always activated?
                Duncanundefined 1 Reply Last reply Reply Quote 0
                • Duncanundefined
                  Duncan @Phaedrux
                  @phaedrux because triggered is = true always and I have nothing connected to io2.in or any line in configuration with io2.in...
                  That's why I don't understand why appears the 2 port on endstops if I'm setting the Z with io3, io4, io5, and io6 inputs for the 4 stepper motors.
                    jay_s_uk @Duncan
                    @duncan the number 2 doesn't correspond to IO2, it corresponds to the 3 endstop created for the system (when the numbering starts at 0). In this instance, thats your endstop(s) for z
                    • Duncanundefined
                      Duncan @jay_s_uk
                      @jay_s_uk but I have 4 endstops defined
                      So it's not possible to see the status of each endstop when we use more than one for one axis?
                      Then I think the problem is that the one on io5.in that is the motor number 4
                      appears to be always triggered...
                        jay_s_uk @Duncan
                        @duncan they are for a global axis though, not 4 individual axes.
                        If you unplug the endstop on IO5 does it no longer show as triggered?
                        Does it then show as triggered when pressing each endstop?
                        If it does show as not triggered when IO5 is connected then I would be investigating the wiring on that endstop
                        • Duncanundefined
                          Duncan @jay_s_uk
                          @jay_s_uk when I disconnect one endstop from the board is always triggered to true in normal case.
                          I tried disconnecting io5 and remains true, and disconnected all other 3 endstops and is true (that's normal), it was supposed to be false if they're connected and all working good.
                          So I really don't know where is the error, because the config file seems to be ok as far as I know...
                            jay_s_uk @Duncan
                            @duncan what type of endstops are they?
                            How do you have the cables connected?
                            can you post a photo of the wiring at the endstop end?
                            • Duncanundefined
                              Duncan @jay_s_uk
                              @jay_s_uk endstops are this https://www.digikey.es/product-detail/es/panasonic-industrial-automation-sales/PM-Y44/1110-2019-ND/3899551
                              the connection is this: ccm_sensor_en.jpg
                              brown +V -> 5V_EXT
                              blue 0V - > GND
                              black output 1 LIGHT ON -> ioX.in
                              Wiring should be ok because X and Y axis are working fine... problem seems to be on the use of 4 pcs of endstops for one axis...
                              • oliofundefined
                                oliof
                                Is this correct? Do you have X and Y on separate toolboards?
                                  jay_s_uk @Duncan
                                  @duncan are they all getting 5v and do the lights all go fully off (or on) when activated and not just dim?
                                  • Duncanundefined
                                    Duncan @oliof
                                    @oliof yes, I have two extension boards, those motors and endstops are working fine, they have their own external control drivers.
                                    @jay_s_uk yes, lights are working ok, now I have a differente situation I'm going to explain.
                                    I put a backup of the config files before using 4 endstops for Z axis and only the probe for Z that was working fine, so machine was working good. Then I updated only the config.g with the one defined with 4 endstops and still good... all motors of Z moving and homming with the probe...
                                    When I put the latest homez.g file the problem was again in the machine, so I made this change:
                                    This is the homez.g with the initial problems
                                    ; homez.g
                                    G1 H1 Z-99999
                                    ;G91             ; relative positioning
                                    ;G1 Z10 F100      ; lift Z relative to current positiond
                                    ;G90             ; absolute positioning
                                    This is the actual homez.g working somehow...
                                    ; homez.g
                                    G1 H2 Z10 F300   ; lift Z relative to current position
                                    G1 X510 Y510 F10000 ; go to first probe point
                                    G1 H1 Z-99999
                                    ;G1 X510 Y510 F3000 ; go to first probe point
                                    ;G1 Z10 F300      ; lift Z relative to current positiond
                                    So the only main change is that I put G90 before the first probe point movement and Z axis moving down looking for endstops... (but not for the probe touching).
                                    So I'm going to test now if once the machine hits the 4 endstops then go for the probe to touch the bed, that it's my objective, because I want to use the 4 endstops to calibrate the machine at the same heigh and then the probe for fine compensation of the bed.
                                    But I don't know if that will work if all the movement on Z is on negative direction or I should put the 4 endstops on Z positive and probe for Z negative...
