    Tool missing after update to firmware 3.3
    • FelixHundefined
      FelixH
      Hi all,
      I was about to post another totally unrelated problem I am experiencing, but I decided to update the firmware to the latest stable release just to try it out and see if the issue got resolved by itself... and then I run into the problem stated on the thread title.
      After upgrading to Firmware Version 3.3, the hotend tool on the web interface just vanished and if I run the macro I have to set the hotend temperature, it doesn't work. On the Paneldue display I can see a temperature displayed, but if I try to set a temperature, it tells me "Tool 0 not found".
      I am on a Duet WiFi 2, by the way. Here is the relevant section of the config.g file:
      Any help will be appreciated. I haven't used my machines for quite some time and I am significantly rusty...
      ; Bed Heaters/Thermistors
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C0 R4700 	; Define thermistor
      M950 H0 C"bedheat" T0                                           ; Link pin name with heater
      M307 H0 B0 S1.00				                ; Disable bang-bang mode for the bed heater and set PWM limit
      M140 H0								; Links everything on the GUI
      M143 H0 S95                                       		; Set temperature limit for heater 0 to 95C
      ; HotEnd Heaters/Thermistors
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 R4725 	  ; Define thermistor
      M950 H1 C"e0heat" T1						  ; Link pin name with heater
      M143 H1 S290							  ; Set temperature limit for heater 1 to 290C
      ; Bed / HotEnd Autotunes
      M307 H1 R2.212 C274.1 D8.07 S1.00 V24.2          ; Hotend Autotune  //Changed
      M307 H0 R0.729 C235.0 D3.27 S1.00                  ; Bed Autotune //Changed. Silicone heated bed.
      M950 F0 C"fan0" Q500
      M106 P0 S0 H-1                        		   ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M950 F1 C"fan1" Q500
      M106 P1 S0.85 H1 T45                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
      JoergS5undefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @FelixH
        @felixh maybe you need T0 at the end of the config, document says "After a reset tools will not start heating until they are selected. ".
          jay_s_uk @FelixH
          @felixh have you got the driver for the extruder mapped in M584?
          FelixHundefined 1 Reply Last reply Reply Quote 0
          • FelixHundefined
            FelixH @jay_s_uk
            @JoergS5 thanks, T0 is at the very end of the config.g file, not shown on the snippet above.
            @jay_s_uk that seems to have been the issue, apparently. I added the example line shown on the wiki and it appears to work ok:
            M584 X0 Y1 Z2:3 E4:5:6
            I wonder why did it work without that line previously...
              In the notes from 3.3 release
              Upgrade notes:
              All extruders must be declared explicitly using M584. In previous firmware versions, one default extruder was assign to driver 3.
              https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
              • FelixHundefined
                FelixH @Phaedrux
                @phaedrux ... I guess I should start reading the release notes from now on... thanks!
